1 Reply Latest reply on Mar 17, 2016 12:54 AM by Nanaky
    Error! Check activation
    birgitc77559145
      Nach dem Anklicken des ebook-downloads bekomme ich die Fehlermeldung: Error! Check activation
      Mein PC hat aber nach wie vor die Authorisierungslizenz.
      Was kann ich tun? Muss ich die Authorisierung löschen und neu eingeben? und gehen da nicht alle meine Ordner verloren?
        • 1. Re: Error! Check activation
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
