My Mac uses El Capitan operating system. When I try to open CS4 apps it says install Java Legacy SE6 Runtime File, and where do I find this?
Mylenium
Mylenium
Michael,
You should be able to get round the issue altogether without the legacy version (and its security implications), by following this:
http://oliverdowling.com.au/2014/03/28/java-se-8-on-mac-os-x/
It is even more thoroughly described in this thread, see post #3 on by gator soup:
https://forums.adobe.com/thread/1706469
Here are download sites for Java SE6 if you wish/must:
Win:
http://www.oracle.com/technetwork/java/javase/downloads/java-archive-downloads-javase6-419409.html
Mac:
http://support.apple.com/kb/DL1572
Some have found that the page may turn up blank to start with, so it may be necessary to reload the page.
Others have found that it may depend on browser. Specifically, a switch from Safari has solved it in one case.
Apple has taken down the download, so has oracle so what am I to do with my CS6 Master Suite?
Revert your Mac to an older operating system if you want to use older softwre
not an option. Company work flow makes heavy use of Dropbox, OS update was required to continue to run.
Then look into the option by Oliver Dowling that Jacob references. You only need to make a couple of folders with the right names in the right places to fool AI into thinking you have the right Java installed.
The links that weren't functioning yesterday morning are up and running again. Problem solved.
Thank you for sharing, Francis, good to know; you could still use the newer (and presumably safer) version, by applying the other option, as mentioned by Larry.
