4 Replies Latest reply on Jun 29, 2016 2:19 AM by Dirk Becker
    Applescript: Script Menu Actions not calling sub-routines referenced within a handler.
    dylw Level 1
      OK this is driving my nuts, I thought I had a good handle on these handlers , but I guess not.
      I am running several scripts I have written via submenus in InDesign. I have, essentially, got the functionality working except it breaks whenever an invoked handler which is attached to a script menu item needs to call a sub-routine. I have attached a sample of the script I am writing below to demonstrate what I mean, go straight down to the bottom "on myMenuAction()" for the tricky area, it completely ignores the second statement because of the referenced sub-routine.
      Any help on this will be greatly appreciated by me, and the team that will benefit from this script if I get it running properly.
      tell application "Adobe InDesign CC 2015"
        --Prepare the Menu Item
        try
        set aMenuAction to script menu action "Menu Action Test"
        on error
        set aMenuAction to make script menu action with properties {title:"Menu Action Test"}
        end try
        --Make the event listener attached to the Menu Item created
        tell aMenuAction
        --If the script menu action already existed then remove it and start again
        if (count event listeners) > 0 then
        tell every event listener to delete
        end if
        make event listener with properties {event type:"onInvoke", handler:my myMenuAction}
        end tell
        --Draw the Menu in InDesign
        tell menu "$ID/Main"
        --Insert the Menu Name
        try
        set myMenuName to submenu "Menu Test"
        on error
        set myMenuName to make submenu with properties {title:"Menu Test"}
        end try
        --Add all the Menu Actions
        tell myMenuName
        try
        set aMenuActionName to menu item "Menu Action Test"
        on error
        set aMenuActionName to make menu item with properties {associated menu action:aMenuAction}
        end try
        end tell
        end tell
      end tell
      on theCurrentDay()
        set TodaysDay to the weekday of the (current date)
        return TodaysDay
      end theCurrentDay
      on myMenuAction()
        display dialog "Hello World" --This works because there is no sub-routine involved
        display dialog "Hello World, today is " & my theCurrentDay() --This doesn't work because a sub-routine is called
        end tell
      end myMenuAction
