17 Replies Latest reply on Apr 19, 2016 10:49 AM by SeanMcCormack
    Lightroom is converting black and white images to color for no reason, how to stop this.
    ninjapimp Level 1
      I have a sony a7rm2, I took a bunch of pictures in black and white.
      when I import them into Lightroom 6.4 on my imac 10.11.3 this images import as expected in black and white
      but when I go to library module the preview boxes start to change from black and white to color?
      it does this for every single image
      I recently deleted my Preferences file because it was converting all images from color to black and white??? after deleting the Pref file this seemed to have stopped but now another bug has crept into. PHotos which were originally shot in black n white now convert ot color
      there are zero develop preset on import set. my prefences has no options set to tone or convert.
      is there a way to stop this or prevent LR from making these changes?
      ever since i upgraded to 6.2 I have had a string on complicated bugs that come in all flavors, some new and some old. the new ones seem appear on a weekly basis.
        • 1. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
          99jon Adobe Community Professional & MVP
          It may be best to establish your own import preset for B&W to give you a good starting point, otherwise the Adobe defaults will be applied.
          • 2. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
            dj_paige Level 9
            If these are RAW photos, you cannot stop them from being shown in Lightroom as color. The momentary B&W is because Lightroom reads the embedded JPG preview in the RAW file, which is B&W, and then it goes ahead and renders the RAW photo, producing a color result.
            • 3. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
              ninjapimp Level 1
              ah ok bummer. i feared that would be the case.
              i specifically shot those images in B&W because they would be better suited in that format
              now that LR has made them all color....i have sort of lsot the frame of mind, meaning i dont quite now which were which.
              it just means I now need to spend time sorting thru those that are better in B&W
              really LR needs to detect this and elave em be but because its reading RAW it has no choice. again I feel this is failure on the part of Adobe and not adapting to a photography work flow.
              when I import images, I dump them from camera to hard drive - so i have no real way of knowing what or type of images. i go on trips and come back with gigs.
              my expectation is lightroom imports them so then I can name, sort and group them into stacks but all thats is a bit ruined when it auto converts and i dont have a way to prevent that.
              sure I could import with a preset, i find that cumbersome with hundreds of images, wadding thru them all.
              i work faster if i can just import them all as they are than work on the other things, provided they remain in their state shot.
              thx for the input.
              • 4. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                dj_paige Level 9
                It's not a failure, it was a deliberate decision to not read the camera settings in the file that would indicate you took the photo in B&W and try to render the photo as the camera saw it.
                It was a deliberate decision to allow you to use the tools provided by Lightroom, instead of the tools provided by the camera, to modify your photo.
                If you want the camera's rendering (which would be B&W), you'd have to use the manufacturer's software.
                • 5. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                  WobertC Adobe Community Professional
                  Simple-
                  Select all in Grid view
                  Press 'V'
                  • 6. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                    Jao vdL Adobe Community Professional & MVP
                    If you want them to remain as you shot, shoot jpeg. If you shoot raw, you are not shooting black and white ever. The raw file records the raw data from your sensor which encodes color information. The black and white setting in camera just writes a bit of metadata in your raw file as an instruction for the camera maker's raw software to render this image as black and white. Unfortunately, Lightroom cannot read this proprietary metadata (like picture styles or other rendering instructions) that your camera wrote in your file as it is undocumented and different for every camera. The only way to read the metadata from your camera is to use the raw engine that the camera maker makes and that's not possible inside a third party program that has its own raw processing engine and be consistent about that. Adobe could try to reverse engineer all the metadata settings in raw files from all makers but they didn't and made the decision to treat raw for what it is: raw. One thing to do is to shoot raw+jpeg if you want to know which images you shot using the black and white picture style. Make sure to turn on the treat jpeg files next to raw as separate images setting if you go that route.
                    P.S. there is actually a third party tool that tries to do this. I can't remember its name but I remember it was a forum member here that created it. I think it only worked for some Nikon and Canon cameras though. That person basically reverse engineered some of the in-camera settings and approximated them using Lightroom settings.
                    • 7. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                      idsquared2 Level 1
                      I agree with the original post.
                      When I shoot with a black and white in-camera process, I want to both view the image in the library as I shot it AND have the RAW capture available for manipulation. BUT, I want to see what I was seeing when I took the picture in the library. That's critical to those of us who shoot in black and white.
                      It's called "work flow."
                      • 8. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                        It's not going to happen, I'm afraid. Lightroom doesn't read in-camera settings, and that's what the black and white setting is when you set it in the camera. Lightroom has an excellent set of tools for converting your images to black-and-white. If, as you say, it is critical that you have black-and-white directly from the camera, then Lightroom isn't going to work for you.
                        • 9. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                          Hal P Anderson Level 6
                          Read Jao's post, above. If you want monochrome straight from the camera, you'll need to shoot JPEG (or RAW + JPEG). It ain't gonna happen otherwise.
                          • 10. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                            trshaner Adobe Community Professional & MVP
                            Very simple! After you import all of the images shot in B& W (and some in color?), select them all, click on 'Black & White in the Basic panel, and then 'Sync' with just 'Treatment (Black & White) checked. Now using your much larger system display you can make a better decision as to whether the image file looks better in B&W using the Before/After preview tool. It's a different workflow and in in my opinion a "better" workflow than trying to do this in the field using the in-camera preview. That's the beauty of shooting raw!
                            In the bad old film days we would have cut-off an arm to have this capability when shooting B&W film, rather than use filters that were permanently cooked into the film emulsion. LR has a myriad of controls for "enhancing" or "changing" the look of B&W images that simply is not possible to see in-camera at the time of the shoot. Start with the B&W mix controls in the HSL panel to see what you can create! Heck you may even want change some of the images shot in color to B&W after gaining experience with LRs controls. Shoot raw+JPEG to compare your adjustments with the raw file to the B&W camera JPEG
                            The 10 commandments of Lightroom black and white conversions | Digital Camera World
                            • 11. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                              idsquared2 Level 1
                              Thanks trshaner, that's a workable solution. Also a very interesting exercise to compare raw+jpeg, then compare adjustments to the camera jpeg.
                              I loved the 'bad old film days' and I especially appreciate working with restrictions when I shoot, like with film and filters. It's like writing before word processors, you have to think deeper about the process in front of you. I was just talking to someone this weekend about writing before word processing. I was a better writer!
                              • 12. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                                idsquared2 Level 1
                                actually, Lightroom does display the in-camera profile briefly in grid view, but when I switch to a larger view like loupe, Lightroom then decides to roll back to raw. it's mandatory, no way to stop it.
                                the annoying thing is, the roll back is one image at a time and it slows down the PC.
                                I guess my fujifilm x-t10 stores the jpeg in the raw file, like trshaner said above, maybe that will change when I shoot jpeg+raw
                                • 13. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                                  The LR Import module uses the raw file's embedded preview (As Shot). If you still want to set the in-camera B&W setting for specific pictures you will see them as B&W in the Import module's Grid view. During initial import select just the B&W image files, add the keyword B&W, import the B&W images, and then import the rest of the files using a 2nd import. Make sure to remove keyword 'B&W' or all the files will have that tag! It should take only a few seconds. Use the LR Library Filter to select just the images shot as B&W in-camera and then apply 'Black & White' Treatment in the Basic panel to all of them.
                                  If you shoot raw+JPEG the raw file uses the same embedded preview, nothing changes. What you will have to change is your LR Preferences setting as follows:
                                  You you can add your vote below concerning ability to view the embedded raw file preview as well as Export a JPEG copy of the embedded preview.
                                  View the Embedded jpg saved in Nikon Raw's files in Lightroom | Photoshop Family Customer Community
                                  • 14. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                                    Just Shoot Me Adobe Community Professional
                                    No there is always a JPG file embedded inside all RAW images. That is what you see, the embedded JPG, on the cameras LCD screen when reviewing the images.
                                    The B&W setting in the camera is for JPGs. Raw is RAW and records what the sensor sees which is in color. The only camera that shoots B&W RAW images is the Leica M B&W digital camera. The sensor is B&W so all you get is B&W images from it.
                                    • 15. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                                      idsquared2 Level 1
                                      Thanks again, great info!!! I appreciate  it. This is my learning curve: how to spend as little time as possible in front of the PC, as much as possible outdoors, but still have the raw to work with.
                                      I'll tinker and find the right flow for me. It will be interesting to compare the fujifilm camera profiles to lightroom usability and result without them.
                                      http://whiteriver1979.tumblr.com/
                                      • 16. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                                        You can also try the LR B&W Filter presets or create your own preset to match the B&W Camera JPEG picture style.  Go retro: Convert to B&W | Adobe Photoshop Lightroom CC tutorials
                                        • 17. Re: Lightroom is converting black and white images to color for no reason, how to stop this.
                                          SeanMcCormack Adobe Community Professional
                                          When you create your preset, rather than having it as a default preset, you could use Import Presets to select different things that happen on import. Import Presets are at the bottom on the Import Dialog and allow you to save all the current settings to use again quickly. I shoot nightclubs amongst other things and they want different looks for different nights. Wed is kinda Classic Chrome, Thurs is B&W, and of course for other things I have no Preset applied. So for each setup, I've saved a different Import Preset. So on Wed, I use my Carbon Wed Import Preset. Thurs is Carbon Maze preset.. etc etc. That way you get to use whatever Presets you like and generally the Import Preset list is smaller than the list of Presets, so quicker to navigate.
