0 Replies Latest reply on Mar 17, 2016 1:52 PM by caplesd67
    splitting a pdf saves to a temp folder and not the document's original folder
    caplesd67
      When you click on the "Output Options" button on the "Split Document" dialog, you can specify among other things how the output files are named. One option is to e.g. use the bookmark name when you are splitting based on the top level bookmarks:
      • The Same Folder Selected at Start- suppose to save the new PDFs in the same folder as the original PDF
      • The files are also being name differently than the original PDF (part of this is intended by adding label and number after the original name)
      Anyone have a solution to correct
      Running Adobe Acrobat XI
      Windows 7
      Current updates applied
