2 Replies Latest reply on May 7, 2007 8:14 AM by lowroller
    Web Service Problems
    lowroller
      I have a couple of questions concerning using Flex and .NET Web Services. Thank you very much for your input!
      1) Inserting a Flex data service in the MXML file...
      According to the article at http://livedocs.adobe.com/flex/1/flex_builder_en/wwhelp/wwhimpl/common/html/wwhelp.htm?con text=Using_Flex_Builder&file=brady610.htm, I should be able to insert a Flex data service control by using Window-->Data menu item. For some reason, I don't have this option in Eclipse. Do I need to install something else or upgrade Flex to be able to access this control?
      2) Flex/.NET Question
      I have built a .NET Web Service which returns data in a DataSet object and I am unable to access the data from Flex. For Flex/.NET compatibility, should I be using a different .NET object to return the data? I have built another .NET service which returns a simple string and Flex was able to interpret it successfully, but Flex doesn't seem to be able to interpret the data in the DataSet object.
