7 Replies Latest reply on Mar 21, 2016 8:01 AM by Szalam
    after effects quit all the time
    nmbrest
      my after effects quist all the time while working.
      No save. no warning just closes.
      this is going on my nerve when i dont gett the project finnish
      cuse i have to redo from last save all the time.
        • 2. Re: after effects quit all the time
          nmbrest Level 1
          some windows log messages i found:
          Feil-bucket 120401792642, type 4
          Hendelsesnavn: APPCRASH
          Svar: Ikke tilgjengelig
          Cab-ID: 0
          Problemsignatur:
          P1: AfterFX.exe
          P2: 13.7.0.124
          P3: 56a1ffb8
          P4: dvaui.dll
          P5: 13.7.0.124
          P6: 56a1e6eb
          P7: c000041d
          P8: 0000000000283701
          P9:
          P10:
          Vedlagte filer:
          C:\Users\xxxxxx\AppData\Local\Temp\WER3298.tmp.WERInternalMetadata.xml
          Disse filene er kanskje tilgjengelige her:
          C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_AfterFX.exe_19198e2c794a8e3df7 40f8dee4e74522e0b0b1f5_1276b5fa_3bc1d64a
          Analysesymbol:
          Leter etter løsning en gang til: 0
          Rapport-ID: 40283982-8607-41df-9e83-5632bf23df51
          Rapportstatus: 0
          Hashet bucket: 04691c214fe8402461cdc8235e3ad0f7
          Programnavn med feil: AfterFX.exe, versjon: 13.7.0.124, tidsangivelse: 0x56a1ffb8
          Modulnavn med feil: dvaui.dll, versjon: 13.7.0.124, tidsangivelse: 0x56a1e6eb
          Unntakskode: 0xc000041d
          Feilforskyvning: 0x0000000000283701
          Feil prosess-ID: 0x6d54
          Feil starttid for program: 0x01d180995b31f6c4
          Feil programbane: C:\Program Files\Adobe After Effects CC 2015\Support Files\AfterFX.exe
          Feil modulbane: C:\Program Files\Adobe After Effects CC 2015\Support Files\dvaui.dll
          Fullstendig navn på feilpakke:
          Relativ program-ID for feilpakke:
          • 3. Re: after effects quit all the time
            nmbrest Level 1
            • What exact version of After Effects? Include the minor version number---e.g., After Effects CC (12.2.1) or After Effects CS6 (11.0.4). Do not just say "After Effects with the latest updates" or "After Effects CC"; give the specific version number.
            Version 13.7.0.124 latest one atm
            Yes
            • What operating system? This should include specific minor version numbers, like "Mac OSX v10.6.8"---not just "Mac".
            Win10
            • If you are getting error message(s), what is the full text of the error message(s)?
            None at all
            • What were you doing when the problem occurred? What is the exact sequence of steps that you are taking?
            dossent matter, it close when not working and prewive rendring
            • Has this ever worked before? If this worked before by doesn't work now, what has changed on your computer in the intervening time?
            yes, onley time has change and the update to the lastest version
            • Tell us about your computer hardware. Include CPU type and number of processor cores, amount of RAM installed, GPU, number and sizes of connected monitors, number of disk drives, and how any external drives are connected.
            asus z97, i7 4790K 4/8 cores
            32GB ram
            3x monitor (2x24" 1920/1200) (1x 23" 1920/1080),
            HDD OS: SSD 128GB
            HDD cashe SSD 128
            Storage 2x2TB WD BLACK
            • What versions of drivers for your graphics hardware do you have installed (including CUDA driver and driver for display adapter)?
            2xAMD 7870  v15.30.1025.1.1001-151204a-298
            Quadro 2000 v6.14.13.6191
            • Do you have any third-party I/O hardware (e.g., AJA, Matrox, Blackmagic, MOTU)?
            No
            • What kind(s) of source footage? When telling about your source footage, tell us about the codecs, not just the container types. For example, "H.264 in a .mov container", not just "QuickTime".
            • Do you have QuickTime installed. (You should.) If so, what version? The answer should be specific, such as "QuickTime 7.6.2".
            yes 7.7.9
            • What other software are you running?
            • Do you have any third-party effects or codecs installed?
            No
            ram, donno if final, couse i havet got ther there yet
            no
            • Are you using the ray-traced 3D renderer?
            YES
            • If the problem is with output, give your exact output settings (both render setting and output module settings). Screenshots help.
            • 4. Re: after effects quit all the time
              YES
              Try changing your composition to the standard renderer and see if it works without crashing that way. The ray-traced renderer is considered obsolete for a number of reasons. I'd like to rule out an issue with your graphics card causing problems.
              If that doesn't help, try working in CC 2014 (remember, AE CC 2014 can open files created by AE CC 2015 with no issues). See if that continues to work. If you don't have CC 2014 installed, you can install it very easily: How To Find And Install Previous Version Of Adobe Apps In CC 2015
              • 5. Re: after effects quit all the time
                nmbrest Level 1
                how to turn off ray-tracing rendering?
                the option is cpu / gpu. no off option
                Fast Draft:
                Available
                Texture Memory:2440,00 MB
                Ray-tracing:GPU
                OpenGL
                Vendor:ATI Technologies Inc.
                Device:AMD Radeon R9 200 / HD 7900 Series
                Version:3.0.13416 Compatibility Profile Context 15.300.1025.1001
                Total Memory:5,96 GB
                Shader Model:4.0 or later
                CUDA
                Driver Version:8.0
                Devices:1 (Quadro 2000)
                Current Usable Memory:932,00 MB (at application launch)
                Maximum Usable Memory:1,00 GB
                • 6. Re: after effects quit all the time
                  nmbrest Level 1
                  i've turn off everything. still crashing
                  • 7. Re: after effects quit all the time
                    Try using AE CC 2014 and see if it works.
