3 Replies Latest reply on Apr 22, 2006 8:29 PM by Newsgroup_User
    Jump To Frame and Play in Separate Movie
    raymbarr
      I have two completely separate .swf files being loaded into a web page. MovieA.swf is set to play on load and movieB.swf is set to be stopped on load.
      On the click of a button within movieA, I'm trying to get movieA.swf to tell movieB.swf to go to a certain frame and play.
      I've been searching on Google for hours now and not really found anything that works.
      Within movieA I've tried the following:
      on (release) {
      gotoAndPlay("_root.movieB", "15");
      OR
      on (release) {
      gotoAndPlay("movieB", "15");
      When I do this it just seems to play movieA. Note I also haven't found a way to "name" a movie. So I'm just calling the file name (movieA.swf) and I realize that's probably not right.
      It seems like it would be a common thing to do... anyone have any code that might work?
      Thank you,
      Raym
        • 1. Re: Jump To Frame and Play in Separate Movie
          Level 7
          "raymbarr" <webforumsuser@macromedia.com> wrote in message news:e2ehgu$b09$1@forums.macromedia.com...
          If they are separate on the web page (not one loaded by the other) then you cannot use code in one to refer to the other except
          through a linkup code called localConnection.
          There are some examples of localConnection on my website..
          http://members.cox.net/4my2dogs/flash/
          tralfaz
          • 2. Jump To Frame and Play in Separate Movie
            raymbarr Level 1
            Awesome! That worked! Thank you so much.
            http://www.imagineave.com/web/index-3d.html
            (click the first or second picture - I haven't hooked up the rest yet). Basically the bottom movie tells the top movie (which starts off transparent) to go to a frame and play).
            I've been trying to get that for hours! Whooohooo!
            One thing I noticed - you're using
            on (release) {
            sendFrameNumber(2);
            Is there a way to try "sendFrameLabel("slide1");
            so that you can refer to frame labels rather than frame numbers in case I later move things around in the movie?
            That's so great! I'm thrilled. Thanks!
            Raym
            • 3. Re: Jump To Frame and Play in Separate Movie
              Level 7
              "raymbarr" <webforumsuser@macromedia.com> wrote in message news:e2emk3$gan$1@forums.macromedia.com...
              > on (release) {
              > sendFrameNumber(2);
              > so that you can refer to slide numbers rather than frame numbers in the other
              > movie?
              > Raym
              Glad it helped. You can send and receive any kind of parameter so if you send a string like "gallery" then on the receiving end you
              can use that string as a label jump..
              // in the sending swf
              // connection name: lc_test
              // function to call: testme
              // parameter to send: string "gallery"
              outgoing_lc = new LocalConnection();
              outgoing_lc.send("lc_test", "testme", "gallery");
              delete outgoing_lc;
              // in the receiver swf file..
              // connection name: "lc_test"
              // function: testme
              // incoming string variable into: someLabelString
              incoming_lc = new LocalConnection();
              incoming_lc.connect("lc_test");
              incoming_lc.testme = function (someLabelString)
              gotoAndPlay(someLabelString);
