2 Replies Latest reply on Apr 20, 2006 9:28 PM by pat-h
    Payback cuts bottom of recording
    pat-h
      I have set the recording to an application. I get the border and record my content.
      When it plays back the bottom of the recoding is lost - the player controls have cut that off. However, this is where the application buttons are, so they cannot see what I am doing. Resizing the recording does not work out well either. BY the time I can see everyting, it is blurred/fuzzy.
      I am in my trial period - love the product so far, but need to get around this issue.
      Thanks - pat-h
        • 1. Re: Payback cuts bottom of recording
          Hi pat-h and welcome to the community
          Your post seems to indicate you are possibly recording full screen. Typically, this is not recommended. Is there any way to reduce the size of your application window prior to recording? If not, you are pretty well stuck with the option of resizing later. As you have seen, resizing can make your movie lose clarity and look blurry.
          You can also try choosing a different position for the playback controls. Either that, or remove them entirely and use buttons or images of your own to control playback.
          Hopefully this helps... Rick
          • 2. Re: Payback cuts bottom of recording
            pat-h Level 1
            Rick,
            Thanks Rick, That gave me the idea that I could just move the botttom of the recording frame down just enough for the playback controls to fit. We beginners often don;t see the obvious.
            I lke this product - very easy to use compared to others I am tried.
            Well - I am off to try making questions and answers etc.
            pat-h
