4 Replies Latest reply on Mar 18, 2016 9:23 AM by resdesign
    buttons hover and toggle
    kristiw15289990
      I am trying to create a button that will have normal, rollover and pressed state. I can get the button to toggle between normal and pressed state with a mouse click, but I can not get the hover to work. I am also able to create a button with a normal and rollover state, but it won't toggle to the pressed state.
      To clarify what I mean by pressed state: If I select the button, the appearance changes and when the mouse leaves the button it stays in that state until I select the button again. Currently, I can select the button and change states, but once the mouse leaves the button, it changes back to the normal state.
        • 1. Re: buttons hover and toggle
          resdesign Adobe Community Professional & MVP
          buttons with different states are a little tricky. You might want to add a variable to check the states. something like this:
          The button has three labels - on, over, pressed
          in compositionReady
          var state = 0;
          sym.$('button').bind('mouseenter', function(){
            sym.getSymbol("button").stop('over');
          sym.$('button').bind('mouseleave', function(){
            if(state==0){
                sym.getSymbol("button").stop('on');
            }else if (state==1){
                sym.getSymbol("button").stop('pressed');
            state=0;
          sym.$('button').bind('mousedown', function(){
                state=1;
          • 3. Re: buttons hover and toggle
            kristiw15289990 Level 1
            Thanks so much for your help! I was able to get the button to function the way I needed it with a few minor adjustments to your code.
            var state = 0;
              if(state==0){
              state=1;
                 if(state==0){
                  state=1;
              state=0;
            • 4. Re: buttons hover and toggle
              Great. Good luck on your project.
