3 Replies Latest reply on Apr 20, 2006 12:11 PM by Newsgroup_User
    What happened to the Actionscript crutch?
    Mike_Boas Level 1
      I just upgraded from Flash MX to Flash MX 2004.
      The actionscript area is less user friendly than before. I used to be able to "fill in the blanks" when it came to setting getURL functions like on release and target blank window. I see the same problem with the timeline control functions.
      Is this crutch gone now, or is it hidden? Why would they make the program harder for those of us who don't have actionscript memorized?
        • 1. Re: What happened to the Actionscript crutch?
          TimSymons Level 1
          Mike,
          Yep, Macromedia took out the "normal" editor for ActionScript in the MX 2004 version but so many people complained about it that they put it back in version 8. I really don't understand why they took it out in the first place.
          Not that this helps you, but when you do upgrade to Flash 8 you will have it back.
          Tim
          • 2. Re: What happened to the Actionscript crutch?
            Level 7
            Mike,
            Yup.
            Heh, I suppose that depends on your comfort level with programming. To
            people who prefer to type their code, it became that much less cluttered.
            But I hear ya. I know what you're missing.
            What you're referring to is called Normal Mode (versus the Expert Mode
            of the Actions panel). It is gone in Flash MX 2004 -- back as Script Assist
            in Flash 8.
            That, I can't answer. But for what it's worth, you do still have the
            blue "plus" button that enters ActionScript for you, and the ActionScript
            Language Reference is only ever a keystroke away (F1 key). That may not be
            much of a comfort, but if you really think about it, there isn't a whole lot
            to memorize if you're only using ActionScript for basic navigation like
            gotoAndPlay(), getURL(), and the like. The syntax is always the same, once
            you know it. Functions, such as getURL(), are "action words" -- verbs, if
            you will. You can usually spot them by the parentheses. They do things
            based on what you tell them to, and what you tell them goes into the
            parentheses. The expected format -- like, is it a number, is it a
            string? -- is explained in the AS Language Reference. You can tell at a
            glance by the :Number, :String, and so on in the listing, as well as the
            Parameters heading.
            David
            stiller (at) quip (dot) net
            Dev essays: http://www.quip.net/blog/
            "Luck is the residue of good design."
            • 3. Re: What happened to the Actionscript crutch?
              Mike_Boas Level 1
              Thanks. This is part of why I was hesitant to learn MX 2004 with version 8 coming out. Oh well.
