• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
XML to query with inner join
Contributor ,
Mar 18, 2016 Mar 18, 2016
I have a CF page that reads an XML file into a query using <cffile>, XMLParse, and QueryAddrow.
I then do a QoQ on the result, and voila! I have my page.  I cache the query for 8 hours and the XML file is only re-read when that cache expires.  It works well.
My problem now is that the file contains data from three database tables instead of one, so I need to do an inner join on the tables.  But I can't do a QoQ with an inner join.
Does anyone know a way for me to do this?
Views
911
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide , Mar 18, 2016 Mar 18, 2016
Oh, didn't know that.  How about nesting QofQ's?  Join Query1 and Query2 into a new query, then join that to Query 3?
Votes
Translate
Translate
Guide ,
You can effect an inner join using ANSI SQL syntax:
Assuming you have two queries to join, Query1 and Query2, and both tables have a common column "JoinCol" (it's not actually necessary for the column to be named the same in both tables as long as the data relates), you can do:
<cfquery name="JoinQuery" dbtype="query">
     SELECT Query1.Col1, Query1.Col2, Query2.Col1, Query2.Col2
     FROM Query1, Query2
     WHERE Query1.JoinCol = Query2.JoinCol
       AND {some other optional criteria here}
</cfquery>
If you have three queries to join, and the join between Query1 and Query2 is different from the join between Query2 and Query3, then something like this:
     SELECT Query1.Col1, Query1.Col2, Query2.Col1, Query2.Col2, Query3.Col1, Query3.Col2
     FROM Query1, Query2, Query3
     WHERE Query1.JoinColA = Query2.JoinColA
       AND Query2.JoinColB = Query3.JoinColB
</cfquery>
HTH,
-Carl V.
Votes
Translate
Translate
Report
Report
Contributor ,
Curiously, I tried that before.  This is the error I get:
Query Of Queries syntax error.
  Encountered ",. Detected more than two tables in the 'from' list 'cercat', Currently only 2 tables are supported,
Votes
Translate
Translate
Report
Report
Guide ,
Votes
Translate
Translate
Report
Report
Contributor ,
I'll try that as soon as the CF server is back up. You can tell it's COB Friday when you get a 503 on the test server
Votes
Translate
Translate
Report
Report
Contributor ,
Mar 21, 2016 Mar 21, 2016
LATEST
Ok, so this seems to work.  I've tried it with three tables and it gives me exactly what I need.  I don't see why it wouldn't work with additional tables.
Thanks!
Votes
Translate
Translate
Report
Report
Resources
Documentation
