13 Replies Latest reply on Aug 19, 2016 3:11 AM by MadAqua
    Weird ColdFusion 2016 error
    majorsaab21
      I installed CF 2016 last night and will randomly start getting "java.lang.NullPointerException" on every page.  Also, I'm getting CF errors on pages when I don't include the "www." in the URL.  For instance, if you go to
      http://wrestlinginc.com/temp/test2.cfm
      You will get an error, details are below. It's the exact same file as if you add the "www.", which comes up fine:
      http://www.wrestlinginc.com/temp/test2.cfm
      Here is the error from the error log:
      "Error","ajp-nio-8016-exec-4","03/18/16","14:45:49","www_wrestlinginc_prod","'' The specific sequence of files included or processed is: XXXXXXXXXXXXXXXXXX\test2.cfm'' "
      Any help would be greatly appreciated. I'm getting close to going back to CF10
        • 1. Re: Weird ColdFusion 2016 error
          Carl Von Stetten Adobe Community Professional & MVP
          Could it be an issue with "Cache web server paths"?  What is that set to in CF Administrator (under the Caching section)?
          • 2. Re: Weird ColdFusion 2016 error
            Vikram_k1810 Adobe Employee
            @majorsaab21
            Could you please post log entries from coldfusion-error and exception logs for our investigation?
            Path: ColdFusion2016\cfusion\logs
            Vikram
            • 3. Re: Weird ColdFusion 2016 error
              majorsaab21 Level 1
              Odd, so when I turn sessionManagement off in Application.cfc, it works fine. Does that make sense? Here is the full error from the exception log:
              "Error","ajp-nio-8016-exec-6","03/18/16","14:51:10","prod","'' The specific sequence of files included or processed is: XXXXXXXXXXXXXXXXX\test2.cfm'' "
                at coldfusion.runtime.AppHelper.isValidCFID(AppHelper.java:463)
                at coldfusion.runtime.AppHelper.getClientIDs(AppHelper.java:299)
                at coldfusion.runtime.AppHelper.handleClientIDs(AppHelper.java:204)
                at coldfusion.runtime.AppHelper.ValidateClientAndSession(AppHelper.java:1195)
                at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:408)
                at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:43)
                at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
                at coldfusion.filter.PathFilter.invoke(PathFilter.java:142)
                at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
                at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
                at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
                at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:60)
                at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
                at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
                at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
                at coldfusion.CfmServlet.service(CfmServlet.java:219)
                at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
                at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:291)
                at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
                at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
                at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
                at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:239)
                at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
                at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
                at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
                at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
                at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
                at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
                at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
                at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:532)
                at org.apache.coyote.ajp.AbstractAjpProcessor.process(AbstractAjpProcessor.java:874)
                at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.jav a:673)
                at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1500)
                at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1456)
                at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
                at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
                at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
                at java.lang.Thread.run(Thread.java:745)
              • 4. Re: Weird ColdFusion 2016 error
                Have you tried creating a new test page and check if you see the same errors with sessionManagement enabled. You could also check  "Cache web server paths" under CF admin as suggested by Carl.
                • 5. Re: Weird ColdFusion 2016 error
                  MadAqua
                  The problem is the client CFID value. In CF2016 it a combination of numbers and letters. In previous CF-Versions it seams to be only a numeric value (in CF9 it is only a number like : '10900'). When it is only a number and not a combination of numbers and letters, the server comes up with a nullPointer exception '
                  java.lang.NullPointerException at coldfusion.runtime.AppHelper.isValidCFID.......... bla
                  When you delete your cookie everything is all right, but this is not a solution for your website/application visitors.
                  Reset cookie is impossible (no valid session exists)
                  Set cookie is impossible  <cfcookie name="CFID" expires="now">   <cfcookie name="CFToken" expires="now"> no access to cookie possible.
                  No solution found. I'll contact the support soon.
                  • 6. Re: Weird ColdFusion 2016 error
                    Sean Coyne Level 2
                    I have found this to be the case as well.  Deleting the cookie clears the error but obviously we can't have every visitor do this.  Please post back if you get anywhere with support.
                    • 7. Re: Weird ColdFusion 2016 error
                      MadAqua Level 1
                      I'll contact the support team. I'll inform you, if we have an solution.
                      regards
                      • 8. Re: Weird ColdFusion 2016 error
                        cvbostel
                        Has anyone heard back from support on this issue? We are running into it as well. It clears up when we delete the CFID and CFTOKEN session variables, but obviously we can't advise our clients to do that. I'm just wondering if anyone has heard back from Adobe on this issue.
                        Thanks!
                        • 9. Re: Weird ColdFusion 2016 error
                          MadAqua Level 1
                          Hi, they informed me that the issue requires a Support Plan (Platinum Support) to be purchased, after which they would be able to assist me with a solution. This is not acceptable in my view, because this is not an error of an application. It is an Server issue. You have no chance to avoid this error. The only chance is to disable the cookie's/session management. This could not the solution for premium purchase software.  We'll wait for an answer again.
                          • 10. Re: Weird ColdFusion 2016 error
                            WolfShade Level 4
                            Does Adobe ever wonder why ColdFusion is losing popularity?  Does Adobe care?  Did ColdFusion spoil Adobe's plans to create a server-side scripting solution, or something?
                            What's going on, Adobe?  You release CF12 (aka CF2016), and from what I've been reading, so far, there are a large number of bugs and other issues that need to be addressed.  But gotta make the customer pay for it, right?  I mean, we can't have the shareholders lose money, right?
                            Every day, Lucee looks better and better.
                            ^_^
                            • 11. Re: Weird ColdFusion 2016 error
                              BKBK Adobe Community Professional & MVP
                              Could you share your Application.cfc code with us?
                              • 12. Re: Weird ColdFusion 2016 error
                                MadAqua Level 1
                                no Session -> no cookie --> no bug --> no nullpointer exception
                                The best way to check this, is an lamp/wamp environment with CF9 and CF2016(ACF12) on tomcat8 on port 8080 and 8180. Then change the rewriting (apache/nginx) from CF9(8080) to CF2016(8180).
                                Then you'll see whats happen. Kill cookie on CF2016 then it will be al fine, but how do you tell all your clients to kill their cookie.
                                The Application.cfc is not the reason for the buggy sessionrotate/cookie handling.
