31 Replies Latest reply on May 14, 2018 1:59 AM by Henry Griin
    No more display of multiple images simultaneously in Camera Raw 9.4 ACR
    OdiugOdiug Level 1
      I gone crazy while i have updated my Photoshop and realize that the new Camera Raw opens each raw serately and not together like before!
      The function that i have the Browser on the left, where i can edit all together or transfer the settings is gone!
      This function is for me existentially, while i have tons of pics that have nearly the same settings.
      Edit each separately was a horror for me!!
      What can i do and when not, where do i geht the old Camera Raw?
      Thanks and regards
      Guido
        • 1. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
          I did not have a  problem like that with ACR 9.4 and ACR 9.5 seems OK too.
          • 2. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
            OdiugOdiug Level 1
            Ouch, where do you get that left browser window?
            I did not have that!
            How did you open up the pics together?
            I do it in that way that i drag and drop it on the first Photoshop Screen or go to open and select 4 pics.
            After that one ACR is opening and only one instance.
            After finishing and click open the raw, another ACR Window with the next raw is opening!
            And so on if all other are opened.
            So i see no option to blend that browserwindow in like you have!
            Please can you say me what i do wrong while i have so much pics to correct?
            Thanks and regards Guido
            • 3. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
              OdiugOdiug Level 1
              At this moment i try to open all within Acdsee with the Export function of it and select all and click open in Photoshop!
              Now all pics opened with the left window like ever before.
              But whats that? Is that a new feature, i never have seen that before?
              • 4. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                Open Photoshop then use menu File>Open select all the RAW files you want to process in the Open Files dialog then click open in the bottom of the open dialog.  Then the ACR  dialog will open like I posted. It is not a new feature.  You can also select many thumbnails in the bridge and open them in ACR.   However,  I rarely use the bridge.
                2 people found this helpful
                • 5. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                  OdiugOdiug Level 1
                  Thank you!
                  I ask for a new feature while before some updates ago, ACR opened all together if i put them in ps via drag and drop, yet opens each separate only.
                  • 6. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                    ssprengel Adobe Community Professional & MVP
                    Bridge is Adobe's "ACDsee-type browser" in that you can see thumbnails of images in a folder and hit the space bar and see each shown full screen and arrow back and forth.  If you open Bridge on a folder and select the images you want to open, then right-click and choose Open in Camera Raw you'll see all the images in the filmstrip at the left of ACR.  Bridge has always worked this way.
                    If ACDsee somehow, now, acts differently, I wouldn't expect Adobe to accommodate this third-party app when they change how things work with PS and ACR.
                    I think there is a bug, now, with LR when you use it to process multiple images with a PS droplet, that only the first one gets passed in, so maybe whatever change caused that also caused ACDsee to work differently, and maybe if Adobe changes things so droplets work with multiple files, again, then maybe ACDsee will start to work how it used to, too, but unless this change in ACR's behavior was between ACR 9.4 and ACR 9.5 then there's probably something different happening with why ACDsee works differently, now.
                    • 7. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                      OdiugOdiug Level 1
                      Sorry but something you missinterpretate completely.
                      - I know Bridge since the first day.
                      - I do not say that it has something to do with acdesee, i only tell how i do it in my workflow, but you can do tis scenario in every kind of Browser type gui like windows explorer.
                      - I do not tell that only the first pic will open only, i say every one for its own instance behind each other.
                      - No prog has a bug, Adobe change the way it works, so if you want open more pics at the same time, you have to do it over that specific dropmenu.
                      The Problem was solved by JJMack, thank you.
                      Guido
                      • 8. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                        The problem was solved by replacing ACDsee with PS in your workflow, ok.  I was suggesting Bridge, instead, since it is more like ACDsee's thumbnail grid and slideshow features, but ok, you like PS / File / Open.
                        Adobe did change something, yes, but if it also affected droplets from Lightroom then maybe what they changed was a mistake and they'll put it back, and maybe it'll affect using a third-party app as your file-browser, too.
                        • 10. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                          ACR 9.4 is not the current version of ACR for the Adobe Creative Cloud versions of Photoshop ACR 9.1.1 is  for CS6 and CC, CC 2014 and CC 2015 ACR 9.6 is current.  However if you have ACR 9.4 installed for Bridge CC and Photoshop CC versions you should be able to process multiple RAW files with ACR 9.4.  ACR 9.6 can even merge RAW files to HDR and Panoramas.
                          • 11. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                            MadManChan2000 Adobe Employee
                            Camera Raw is a plug-in for a host application such as Photoshop and Bridge.  Editing of multiple files simultaneously in ACR is best done by using the facilities within these host apps.  For example, with Photoshop open, you can just drag-and-drop multiple files from the Finder/Explorer into Ps.  Or, as many have suggested above, you can use Bridge directly to edit multiple files in ACR.
                            • 12. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                              brad.magnus Level 1
                              I experienced this issue today. I grabbed 20 or so raw photos, opened Ps and tried to drag and drop them to open. No filmstrip area was visible, one at a time editing for that many images is a little crazy. So I ended Ps from the task manager. I tried the open dialogue as suggested, no dice. On accident though (I gave up and was going to just do 1 at a time), I had 1 image open after editing it and without thinking grabbed the next 3-4 images and dragged them in. CR popped up with film strip. All that to say with at least one open document, CR opened as I expected.
                              • 13. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                What OS, Photoshop and ACR versione do you have installed? I just dragged 4 raw file from windows 10 file explorer and dropped them on Photoshop CC 2015  i had open and ACR 9.6 open them in a file strip. I canceled out of ACR 9.6 closed CC 2015 open CC 2015.5 dropped then on cc 2015.5 and once again ACR 9.6 opened them in a strop. Same with CC 2014 an CC. With CS6 ACR 9.1.1 opened them in a file strip. With CS2 ACR 3.0 open them in a file strip.
                                I closed CS2 opened CC 2015.5 and dropped 60 8MP Canon D20 CR2 file on Photoshop ACR 9.6 open all 60 Raw File in a film strip.
                                • 14. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                  brad.magnus Level 1
                                  I'm on Windows 10. Updated all apps this week. Ps CC 2015.5 and ACR 9.6 (or Camera Raw CC says "up to date" in the CC app). In your example you already have one image open... Which is what I was saying I did and the film strip worked as expected. Just to give a visual example here's a screen shot of only one image at a time, with nothing open in Ps.
                                  But if I have at least one document open, ACR opens up with the film strip. See here:
                                  Here's the system info
                                  • 15. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                    PS CC 2015.5 ACR 9.6 is opening multiple DNG images drug-and-dropped onto an empty PS document area from Windows 7 Explorer or from Windows 10 Explorer, with PS open in the Photography workspace in each:
                                    Here are a few of my PS Prefs settings panels, so you can compare to see if any of these are different, since some deal with placing or Opening, first Camera Raw prefs, then PS:
                                    Looking at my Windows 10 System Information, I am using BIOS MODE UEFI not Legacy, have Secure Boot ON, and have Hyber-V Virtualization Enabled in Firmware Yes but otherwise, except for the manufacturer-specific things, the settings are the same.  My Windows 7 computer has two monitors, my Windows 10 computer has 1.
                                    • 16. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                      It does not matter if I have a document open in Photoshop or not,  Here is what I see my settings and my CC 2015.5 menu Help>System info...
                                      Adobe Photoshop Version: 2015.1.2 20160113.r.355 2016/01/13:23:59:59 CL 1059143  x64
                                      Operating System: Windows 10 64-bit
                                      Version: 10 or greater
                                      System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
                                      Physical processor count: 12
                                      Logical processor count: 24
                                      Processor speed: 1995 MHz
                                      Built-in memory: 40886 MB
                                      Free memory: 32785 MB
                                      Memory available to Photoshop: 37035 MB
                                      Memory used by Photoshop: 85 %
                                      Modifier Palette: Enabled.
                                      Design Space: Disabled.
                                      Artboards: Enabled.
                                      3D Multitone Printing: Disabled.
                                      Highbeam: Enabled.
                                      Image tile size: 1028K
                                      Image cache levels: 6
                                      Font Preview: Medium
                                      TextComposer: Latin
                                      Display: 1
                                      Display Bounds: top=0, left=0, bottom=1080, right=1920
                                      Display: 2
                                      Display Bounds: top=0, left=-1360, bottom=768, right=0
                                      OpenGL Drawing: Enabled.
                                      OpenGL Allow Old GPUs: Not Detected.
                                      OpenGL Drawing Mode: Advanced
                                      OpenGL Allow Normal Mode: True.
                                      OpenGL Allow Advanced Mode: True.
                                      AIFCoreInitialized=1
                                      AIFOGLInitialized=1
                                      OGLContextCreated=1
                                      NumGLGPUs=1
                                      NumCLGPUs=1
                                      glgpu[0].GLVersion="3.0"
                                      glgpu[0].IsIntegratedGLGPU=0
                                      glgpu[0].GLMemoryMB=2048
                                      glgpu[0].GLName="NVIDIA Quadro 4000"
                                      glgpu[0].GLVendor="NVIDIA Corporation"
                                      glgpu[0].GLVendorID=4318
                                      glgpu[0].GLDriverVersion="10.18.13.6839"
                                      glgpu[0].GLRectTextureSize=16384
                                      glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
                                      glgpu[0].GLRendererID=1757
                                      glgpu[0].HasGLNPOTSupport=1
                                      glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um ,nvwgf2um,nvwgf2um"
                                      glgpu[0].GLDriverDate="20160602000000.000000-000"
                                      glgpu[0].CanCompileProgramGLSL=1
                                      glgpu[0].GLFrameBufferOK=1
                                      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                                      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                                      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                                      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                                      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                                      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                                      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                                      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                                      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                                      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                                      clgpu[0].CLPlatformVersion="1.2"
                                      clgpu[0].CLDeviceVersion="1.1 CUDA"
                                      clgpu[0].IsIntegratedCLGPU=0
                                      clgpu[0].CLMemoryMB=2048
                                      clgpu[0].CLName="Quadro 4000"
                                      clgpu[0].CLVendor="NVIDIA Corporation"
                                      clgpu[0].CLVendorID=4318
                                      clgpu[0].CLDriverVersion="368.39"
                                      clgpu[0].CUDASupported=1
                                      clgpu[0].CUDAVersion="8.0.0"
                                      clgpu[0].CLBandwidth=7.49599e+010
                                      clgpu[0].CLCompute=191.68
                                      License Type: Subscription
                                      Serial number: 90970090970448917498
                                      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2015\
                                      Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
                                      Photoshop scratch has async I/O enabled
                                      Scratch volume(s):
                                        F:\, 465.2G, 213.7G free
                                        C:\, 224.2G, 122.8G free
                                      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\Plug-Ins\
                                      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Plug-ins\
                                      Installed components:
                                         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                                         ACE.dll   ACE 2015/09/09-18:52:48   79.567158   79.567158
                                         AdbePM.dll   PatchMatch 0000/00/00-00:00:00   1.   1.
                                         AdobeLinguistic.dll   Adobe Linguisitc Library   9.0.0
                                         AdobeOwl.dll   Adobe Owl   5.2.9
                                         AdobePDFL.dll   PDFL 2015/09/12-01:10:45   79.156620   79.156620
                                         AdobePIP.dll   Adobe Product Improvement Program   7.3.1.70
                                         AdobeSVGAGM.dll   AdobeSVGAGM   79.566705   79.566705
                                         AdobeXMP.dll   Adobe XMP Core 2015/09/10-01:10:20   79.158325   79.158325
                                         AdobeXMPFiles.dll   Adobe XMP Files 2015/09/10-01:10:20   79.158325   79.158325
                                         AdobeXMPScript.dll   Adobe XMP Script 2015/09/10-01:10:20   79.158325   79.158325
                                         adobe_caps.dll   Adobe CAPS   9,0,0,28
                                         AGM.dll   AGM 2015/09/09-18:52:48   79.567158   79.567158
                                         ahclient.dll    AdobeHelp Dynamic Link Library   2.0.0.2
                                         AIDE.dll   AIDE 2015/10/15-11:58:31   79.568000   79.568000
                                         amtlib.dll   AMTLib (64 Bit)   9.0.0.89BuildVersion: 9.0; BuildDate: Tue Aug 25 2015 7:30:38)   1.000000
                                         ARE.dll   ARE 2015/09/09-18:52:48   79.567158   79.567158
                                         AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                                         AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                                         Bib.dll   BIB 2015/09/09-18:52:48   79.567158   79.567158
                                         BIBUtils.dll   BIBUtils 2015/09/09-18:52:48   79.567158   79.567158
                                         boost_date_time.dll   photoshopdva   8.0.0
                                         boost_signals.dll   photoshopdva   8.0.0
                                         boost_system.dll   photoshopdva   8.0.0
                                         boost_threads.dll   photoshopdva   8.0.0
                                         cg.dll   NVIDIA Cg Runtime   3.0.00007
                                         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                                         CIT.dll   Adobe CIT   2.3.7.33275   2.3.7.33275
                                         CITThreading.dll   Adobe CITThreading   2.3.7.33275   2.3.7.33275
                                         CoolType.dll   CoolType 2015/09/09-18:52:48   79.567158   79.567158
                                         dnssd.dll   Bonjour   3,0,0,2
                                         dvaaudiodevice.dll   photoshopdva   8.0.0
                                         dvacore.dll   photoshopdva   8.0.0
                                         dvamarshal.dll   photoshopdva   8.0.0
                                         dvamediatypes.dll   photoshopdva   8.0.0
                                         dvametadata.dll   photoshopdva   8.0.0
                                         dvametadataapi.dll   photoshopdva   8.0.0
                                         dvametadataui.dll   photoshopdva   8.0.0
                                         dvaplayer.dll   photoshopdva   8.0.0
                                         dvatransport.dll   photoshopdva   8.0.0
                                         dvaui.dll   photoshopdva   8.0.0
                                         dvaunittesting.dll   photoshopdva   8.0.0
                                         dynamiclink.dll   photoshopdva   8.0.0
                                         ExtendScript.dll   ExtendScript 2015/04/17-16:55:22   80.1017022   80.1017022
                                         icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                                         icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                                         icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                                         igestep30.dll   IGES Reader   9.3.0.113
                                         imslib.dll   IMSLib DLL   9.0.1.14
                                         JP2KLib.dll   JP2KLib 2015/08/14-01:13:58   79.258941   79.258941
                                         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                                         libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                                         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                                         LogSession.dll   LogSession   7.3.1.70
                                         manta.dll   Manta   1.   1.
                                         mediacoreif.dll   photoshopdva   8.0.0
                                         MPS.dll   MPS 2015/08/14-01:13:58   79.566687   79.566687
                                         pdfsettings.dll   Adobe PDFSettings   1.04
                                         Photoshop.dll   Adobe Photoshop CC 2015   16.1.2
                                         Plugin.dll   Adobe Photoshop CC 2015   16.1.2
                                         PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   6.1.0
                                         PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   6.1.0.164
                                         PSArt.dll   Adobe Photoshop CC 2015   16.1.2
                                         PSViews.dll   Adobe Photoshop CC 2015   16.1.2
                                         SCCore.dll   ScCore 2015/04/17-16:55:22   80.1017022   80.1017022
                                         SVGRE.dll   SVGRE   79.566690   79.566690
                                         svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                                         tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 3, 2015, 0408
                                         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 3, 2015, 0408
                                         TfFontMgr.dll   FontMgr   9.3.0.113
                                         TfKernel.dll   Kernel   9.3.0.113
                                         TFKGEOM.dll   Kernel Geom   9.3.0.113
                                         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                                         updaternotifications.dll   Adobe Updater Notifications Library   9.0.0.15 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   9.0.0.15
                                         VulcanControl.dll   Vulcan Application Control Library   5.2.0.35
                                         VulcanMessage5.dll   Vulcan Message Library   5.2.0.35
                                         WRServices.dll   WRServices Fri Jul 31 2015 07:50:10   Build 0.21834   0.21834
                                         wu3d.dll   U3D Writer   9.3.0.113
                                      Required plug-ins:
                                         3D Studio 16.1.2 (2015.1.2 x001 x003)
                                         Accented Edges 16.1.2
                                         Adaptive Wide Angle 16.1.2
                                         Angled Strokes 16.1.2
                                         Average 16.1.2 (2015.1.2 x001 x003)
                                         Bas Relief 16.1.2
                                         BMP 16.1.2
                                         Camera Raw 9.6
                                         Camera Raw Filter 9.6
                                         Chalk & Charcoal 16.1.2
                                         Charcoal 16.1.2
                                         Chrome 16.1.2
                                         Cineon 16.1.2 (2015.1.2 x001 x003)
                                         Clouds 16.1.2 (2015.1.2 x001 x003)
                                         Collada 16.1.2 (2015.1.2 x001 x003)
                                         Color Halftone 16.1.2
                                         Colored Pencil 16.1.2
                                         CompuServe GIF 16.1.2
                                         Conté Crayon 16.1.2
                                         Craquelure 16.1.2
                                         Crop and Straighten Photos 16.1.2 (2015.1.2 x001 x003)
                                         Crop and Straighten Photos Filter 16.1.2
                                         Crosshatch 16.1.2
                                         Crystallize 16.1.2
                                         Cutout 16.1.2
                                         Dark Strokes 16.1.2
                                         De-Interlace 16.1.2
                                         Dicom 16.1.2
                                         Difference Clouds 16.1.2 (2015.1.2 x001 x003)
                                         Diffuse Glow 16.1.2
                                         Displace 16.1.2
                                         Dry Brush 16.1.2
                                         Eazel Acquire 16.1.2 (2015.1.2 x001 x003)
                                         Entropy 16.1.2 (2015.1.2 x001 x003)
                                         Export Color Lookup Tables NO VERSION
                                         Extrude 16.1.2
                                         FastCore Routines 16.1.2 (2015.1.2 x001 x003)
                                         Fibers 16.1.2
                                         Film Grain 16.1.2
                                         Filter Gallery 16.1.2
                                         Flash 3D 16.1.2 (2015.1.2 x001 x003)
                                         Fresco 16.1.2
                                         Glass 16.1.2
                                         Glowing Edges 16.1.2
                                         Google Earth 4 16.1.2 (2015.1.2 x001 x003)
                                         Grain 16.1.2
                                         Graphic Pen 16.1.2
                                         Halftone Pattern 16.1.2
                                         HDRMergeUI 16.1.2
                                         HSB/HSL 16.1.2
                                         IFF Format 16.1.2
                                         IGES 16.1.2 (2015.1.2 x001 x003)
                                         Ink Outlines 16.1.2
                                         JPEG 2000 16.1.2
                                         Kurtosis 16.1.2 (2015.1.2 x001 x003)
                                         Lens Blur 16.1.2
                                         Lens Correction 16.1.2
                                         Lens Flare 16.1.2
                                         Liquify 16.1.2
                                         Matlab Operation 16.1.2 (2015.1.2 x001 x003)
                                         Maximum 16.1.2 (2015.1.2 x001 x003)
                                         Mean 16.1.2 (2015.1.2 x001 x003)
                                         Measurement Core 16.1.2 (2015.1.2 x001 x003)
                                         Median 16.1.2 (2015.1.2 x001 x003)
                                         Mezzotint 16.1.2
                                         Minimum 16.1.2 (2015.1.2 x001 x003)
                                         MMXCore Routines 16.1.2 (2015.1.2 x001 x003)
                                         Mosaic Tiles 16.1.2
                                         Multiprocessor Support 16.1.2 (2015.1.2 x001 x003)
                                         Neon Glow 16.1.2
                                         Note Paper 16.1.2
                                         NTSC Colors 16.1.2 (2015.1.2 x001 x003)
                                         Ocean Ripple 16.1.2
                                         OpenEXR 16.1.2
                                         Paint Daubs 16.1.2
                                         Palette Knife 16.1.2
                                         Patchwork 16.1.2
                                         Paths to Illustrator 16.1.2
                                         PCX 16.1.2 (2015.1.2 x001 x003)
                                         Photocopy 16.1.2
                                         Photoshop 3D Engine 16.1.2 (2015.1.2 x001 x003)
                                         Photoshop Touch 14.0
                                         Picture Package Filter 16.1.2 (2015.1.2 x001 x003)
                                         Pinch 16.1.2
                                         Pixar 16.1.2 (2015.1.2 x001 x003)
                                         Plaster 16.1.2
                                         Plastic Wrap 16.1.2
                                         PLY 16.1.2 (2015.1.2 x001 x003)
                                         PNG 16.1.2
                                         Pointillize 16.1.2
                                         Polar Coordinates 16.1.2
                                         Portable Bit Map 16.1.2 (2015.1.2 x001 x003)
                                         Poster Edges 16.1.2
                                         PRC 16.1.2 (2015.1.2 x001 x003)
                                         Radial Blur 16.1.2
                                         Radiance 16.1.2 (2015.1.2 x001 x003)
                                         Range 16.1.2 (2015.1.2 x001 x003)
                                         Render Color Lookup Grid NO VERSION
                                         Reticulation 16.1.2
                                         Ripple 16.1.2
                                         Rough Pastels 16.1.2
                                         Save for Web 16.1.2
                                         ScriptingSupport 16.1.2
                                         Shake Reduction 16.1.2
                                         Shear 16.1.2
                                         Skewness 16.1.2 (2015.1.2 x001 x003)
                                         Smart Blur 16.1.2
                                         Smudge Stick 16.1.2
                                         Solarize 16.1.2 (2015.1.2 x001 x003)
                                         Spaces 16.1.2
                                         Spatter 16.1.2
                                         Spherize 16.1.2
                                         Sponge 16.1.2
                                         Sprayed Strokes 16.1.2
                                         Stained Glass 16.1.2
                                         Stamp 16.1.2
                                         Standard Deviation 16.1.2 (2015.1.2 x001 x003)
                                         STL 16.1.2 (2015.1.2 x001 x003)
                                         Sumi-e 16.1.2
                                         Summation 16.1.2 (2015.1.2 x001 x003)
                                         Targa 16.1.2
                                         Texturizer 16.1.2
                                         Tiles 16.1.2
                                         Torn Edges 16.1.2
                                         Twirl 16.1.2
                                         U3D 16.1.2 (2015.1.2 x001 x003)
                                         Underpainting 16.1.2
                                         Vanishing Point 16.1.2
                                         Variance 16.1.2 (2015.1.2 x001 x003)
                                         Virtual Reality Modeling Language | VRML 16.1.2 (2015.1.2 x001 x003)
                                         Water Paper 16.1.2
                                         Watercolor 16.1.2
                                         Wave 16.1.2
                                         Wavefront|OBJ 16.1.2 (2015.1.2 x001 x003)
                                         WIA Support 16.1.2 (2015.1.2 x001 x003)
                                         Wind 16.1.2
                                         Wireless Bitmap 16.1.2 (2015.1.2 x001 x003)
                                         ZigZag 16.1.2
                                      Optional and third party plug-ins:
                                         Analog Efex Pro 2 2.0.12.12
                                         BackgroundFilter 2.2.21.12
                                         Color Efex Pro 4 4.3.24.12
                                         CUR (Windows Cursor) NO VERSION
                                         Dfine 2 2.2.21.12
                                         Face Control II 2.00
                                         Fine Touch 3.25
                                         FineStructuresFilter 2.2.21.12
                                         GREYCstoration NO VERSION
                                         HDR Efex Pro 2 2.2.24.12
                                         HotPixelsFilter 2.2.21.12
                                         ICO (Windows Icon) NO VERSION
                                         Import from FastPictureViewer Codec Pack 3.8.0.96
                                         JPEG XR 1, 1, 0, 0
                                         Merge to HDR Efex Pro 2 2.2.24.12
                                         Nik Collection Selective Tool 2.1.28
                                         Reduce Noise 7.0.0.0
                                         ScriptListener 13.0
                                         ShadowsFilter 2.2.21.12
                                         Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12
                                         Sharpener Pro 3: (2) Output Sharpener 3.1.21.12
                                         Silver Efex Pro 2 2.2.24.12
                                         SkinFilter 2.2.21.12
                                         SkyFilter 2.2.21.12
                                         StarFilter Pro 3 3.0.5.1
                                         StrongNoiseFilter 2.2.21.12
                                         SuperPNG 2.0
                                         Viveza 2 2.1.21.12
                                      Plug-ins that failed to load: NONE
                                      Extensions:
                                         Recent Files  1.2.1
                                            C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_2_1_001\index.html
                                         Libraries  2.3.1048
                                            C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_3_1048\index.html
                                         Start  1.2.1
                                         Adobe Color Themes  6.1.0
                                            C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\KulerPanelHTMLBundle\index.html
                                         Export As  2.4.0
                                            C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.webpa.crema\PSPanel\dialog.html
                                         Device Preview  1.1.3
                                            C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.preview\PSPanel\panel.html
                                         Share on Behance  3.0.0
                                            C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.behance.shareonbehance.html\index.html
                                         JSX Launcher  0.1.2
                                            C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\net.sytes.chuwa.jsxlauncher\index.html
                                         com.adobe.preview.loader  1.1.3
                                            C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.preview\PSLoader\loader.html
                                         Export As  2.4.0
                                      Installed TWAIN devices: NONE
                                      • 17. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                        What_Is_Adobe Level 1
                                        I think I know what the issue is:
                                        You're dragging and dropping them in the "Workspace When No Documents Are Open"
                                        Do this: Edit > Preferences > General > Uncheck "Show "Start" Workspaces When No Documents Are Open"
                                        15 people found this helpful
                                        • 18. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                          And now when you open PS it will take you to the blank workspace we're used to seeing in previous versions. You can now drag and drop any number of images and the film strip will be there.
                                          When you opened up one image, what happens is that that image takes you to that workspace, but now you can get to that workspace every time you launch PS.
                                          6 people found this helpful
                                          • 19. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                            smurphy89 Level 1
                                            Nice one!
                                            Good spot. Been having issues with this since transferring over from CS6 to CC.
                                            Thanks.
                                            • 20. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                              click47 Level 1
                                              Bingo!
                                              Problem solved.
                                              Thank you What_Is_Adobe.
                                              • 22. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                aa75312634 Level 1
                                                My preferred method of opening multiple raws, and having them show up with a filmstrip on the left is with the enter key. I can drag and drop to get a filmstrip, but muscle memory still has me pressing the enter key every time. Right now, and after many reinstalls, updates and preference resets, it's still not acting normal after my PS CC 2015.5 and latest Bridge update... Any help?
                                                • 23. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                  kurtywompus Level 1
                                                  Via:  What_Is_Adobe
                                                  ^^^worked for me!
                                                  • 24. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                    catdotgif Level 1
                                                    Thanks for this, I have to say that this is a super confusing way for the program to be designed.    When would I ever want to open twenty raw files sequentially in Camera Raw instead of as a group?   What does "Show "Start" Workspaces When No Documents Are Open" even mean?   Why does a general Photoshop setting change the behavior of Camera Raw when there are separate Camera Raw settings?
                                                    I think this is a badly designed aspect of the interface and I would like it so that if you drag a group of raw files onto Photoshop, it always opens them together in Camera Raw.
                                                    • 25. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                      pmd92886 Level 1
                                                      This did not work for me.  I am used to clicking on "Open", selecting my images to edit and getting a filmstrip in ACR.  After updating to the newest release in CC, I am no longer getting a filmstrip.  Can anyone help with this?  I unchecked as described above and it did nothing.  thanks!
                                                      • 26. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                        Richard Southworth Level 3
                                                        The filmstrip area could be "squished" - look at the far left border of the ACR window, if two gray lines, grab the inner line and pull to the right.
                                                        Here's an example of how it may look before opening up the filmstrip area.  There are multiple files open, but only the top one is displayed, and the filmstrip column is closed.
                                                        And here with the filmstrip column opened up
                                                        Richard Southworth
                                                        • 27. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                          pmd92886 Level 1
                                                          Thanks Richard!
                                                          It turns out that unchecked the box mentioned previously worked after all.
                                                          As soon as I exited PS then opened it again, everything is working perfectly now!
                                                          Thanks again!!
                                                          • 29. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                            brboyer555 Level 1
                                                            This saved my life and my SANITY!!!!  Thank you!
                                                            • 30. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
                                                              lubosr6145017 Level 1
                                                              I have the same problem and thanks to all of you for solving it.
                                                              thx thx thx ;-)
                                                              • 31. Re: No more display of multiple images simultaneously in Camera Raw 9.4 ACR
        Henry Griin Level 1
        Really, Adobe, wow. 2018. Way to go. More good ideas like these, if you may. What next? Download porn unless the user has 'precise cursors' option checked? Ingenious. Creative cloud indeed.
        Rant finished. Thanks for providing the solution.
