Hello,
i'm having the same problem when installing Ilustrator CC. Did anyone found solution?
Exit Code: 160
-------------------------------------- Summary --------------------------------------
- 2 fatal error(s), 2 error(s), 1 warnings(s)
FATAL: Error (Code = 160) executing in command 'CreateRegistryKeyCommand' for package: 'AdobeIllustrator19-Core', version:19.2.1.147
FATAL: Error occurred in install of package (Name: AdobeIllustrator19-Core Version: 19.2.1.147). Error code: '160'
ERROR: Failed to delete file: 'C:\Users\admin\AppData\Local\Temp\ETR994E.tmp\AdobeIllustrator19-pl_PL.zip.aamdownload' LastError:32
ERROR: Failed to delete file: 'C:\Users\admin\AppData\Local\Temp\ETR994E.tmp\AdobeIllustrator19-pl_PL.zip.aamdownload.aamd' LastError:32
WARN: Check for Registry permissions. (Creating Registry Key Failed - Start 64-bit:1 root:0 key:.pdf\OpenWithList\Illustrator.exe. Error 5 Odmowa dostÄpu.)
Branching to a new discussion.
Kindly check: Troubleshoot Illustrator CC 2015 log files
