2 Replies Latest reply on Apr 22, 2006 5:01 PM by M4rkeh
    GetPref
    M4rkeh Level 1
      Hi, I'm, using getpref and setpref to save and retrieve nested linear lists. The setpref seems to work ok, because I can find the text file and it contains the information it should. However when the movie restarted it doesnt reload the file. Can someone please take a look at the lingo and tell me whats wrong?
      on startmovie
      ghighscoreslist = getPref("topscores.txt")
      if voidp(ghighscoreslist) then
      set ghighscoreslist = []
      end if
      end
      on exitframe
      go to the frame
      setPref("topscores.txt", string(ghighscoreslist))
      end
      *variables have been declared
      thanks,
      Mark
        • 1. Re: GetPref
          Level 7
          On Sat, 22 Apr 2006 21:27:24 GMT, M4rkeh posted in macromedia.director.lingo:
          Try changing the above to
          ghighscoreslist = value(getPref("topscores.txt"))
          (Need to convert the string back into a list)
          I can't see the code you used to initialize the list (Web forum crapping on
          newsserver), but if it is a property list and if there are any VOIDs in the
          list, value() won't help.
          If this is for a projector, I recommend using the vList or propSave Xtras
          instead. They are both free for this particular feature. Especially if the
          projector will be running from a non-writable medium such as a CD.
          Mark A. Boyd
          Keep-On-Learnin'
          • 2. Re: GetPref
            M4rkeh Level 1
            thanks v much it seems to be working well now
