2 Replies Latest reply on Mar 19, 2016 7:42 AM by beh_gras_beh
    Name PDF as Masterpage Name
    beh_gras_beh Level 1
      Dear Indesign scripters,
      I'm using this script for quite a while now. Thanks to Jongware.
      But is there an way I can name the PDF as the name of the master page it uses? (Like DocumentName+MasterpageNameA+MasterpageNameC.PDF)
      Exporting only selected master pages
      This is my edit from the original post above:
      var mCheckbox = [];
      var expMasterDialog = app.dialogs.add({name:"Welke moeten geëxporteerd worden", canCancel:true});
      with (expMasterDialog)
      with(dialogColumns.add())
        for (i=0; i<app.activeDocument.masterSpreads.length; i++)
         with(dialogRows.add())
          mCheckbox[i] = checkboxControls.add({staticLabel:app.activeDocument.masterSpreads[i].name,checkedState:false});
      if (expMasterDialog.show() == true)
      newRange = '';
      for (i=0; i<app.activeDocument.pages.length; i++)
        if (app.activeDocument.pages[i].appliedMaster &&
         mCheckbox[app.activeDocument.pages[i].appliedMaster.index].checkedState == true)
        var myBaseName = app.activeDocument.pages[i].appliedMaster.name;
         if (newRange) newRange += ',';
         newRange += app.activeDocument.pages[i].name;
      app.pdfExportPreferences.pageRange = newRange;
      // alert (newRange);
      app.activeDocument.exportFile (ExportFormat.PDF_TYPE, File((app.activeDocument.fullName.fsName +'_'+ myBaseName +'!').replace(/(\.indd)?!$/i, '.pdf')), true, app.pdfExportPresets[0]);
      Thanks for anyone who wants to help me out.
        • 1. Re: Name PDF as Masterpage Name
          Doesn't it already do so? Ah wait, I see it only uses the last seen master page name. I guess I was expecting you to use it with a single master page only.
          Fortunately, it's a small change only: construct the myBaseName prefix before looping over the individual pages, not 'inside' that loop.
          var mCheckbox = [];
              var myBaseName = '';
              if (mCheckbox[i].checkedState == true)
              if (myBaseName)
              myBaseName += '+';
              myBaseName += app.activeDocument.masterSpreads[i].name;
            newRange = '';
          This exports a file "export-test" as "export-test_B-Master+C-Master.pdf".
          • 2. Re: Name PDF as Masterpage Name
            That's it!
            I was creating an headache for myself here.
            Thanks a million Jongware!
            Small update that adds folder location and an option to rename the basefile thanks to Jongware:
            if(app.documents.length != 0){
            var myFolder = Folder.selectDialog ("Choose a Folder to Save the PDFs");
            if(myFolder != null){
            myExportPages(myFolder);
            else{
            alert("Please open a document and try again.");
            function myExportPages(myFolder){
            var myPageName, myFilePath, myFile;
            var myDocument = app.activeDocument;
            var myDocumentName = myDocument.name;
            var myDialog = app.dialogs.add();
            with(myDialog.dialogColumns.add().dialogRows.add()){
            staticTexts.add({staticLabel:"Please Modify the Base Name if Necissary:"});
            var myBaseNameField = textEditboxes.add({editContents:myDocumentName,
            minWidth:160});
            var myResult = myDialog.show({name:"ExportPages"});
            if(myResult == true){
            var myBaseName = myBaseNameField.editContents;
            //Remove the dialog box from memory.
            myDialog.destroy();
            var mCheckbox = [];
            var expMasterDialog = app.dialogs.add({name:"Choose a Spread ", canCancel:true});
                var mySpreadName = '';
                if (mySpreadName)
                mySpreadName += '+';
                mySpreadName += app.activeDocument.masterSpreads[i].name;
              newRange = '';
            myFilePath = myFolder + "/" + myBaseName + mySpreadName + "_" + ".pdf";
            myFile = new File(myFilePath);
            myDocument.exportFile(ExportFormat.pdfType, myFile, true, app.pdfExportPresets[0]);
