3 Replies Latest reply on Nov 12, 2006 2:48 AM by Newsgroup_User
    Rounding image edges?
    Level 7
      How do you round the edge of an image (jpg) in fireworks? I've looked up
      tutorials but most of the tutorials seem to be a little long for something
      that seems so easy...
      Best Regards,
      Chris Jumonville
      iMedia Web Design
      503.277.3553
        • 1. Re: Rounding image edges?
          Level 7
          Place a white rounded rectangle on top of your image.
          Select both your image and the rectangle (hold down the shift key)
          Go to Modify, select Mask from the drop down menu, then Group as Mask.
          Peter
          ______________________
          "Chris Jumonville" <verticalterrain@yahoo.com> wrote in message
          news:ej6gfc$6en$1@forums.macromedia.com...
          | Best Regards,
          | Chris Jumonville
          | iMedia Web Design
          | 503.277.3553
          • 2. Re: Rounding image edges?
            Level 7
            Peter,
            Thanks that worked very easily. The only thing is I can't figure out why I
            can't get it to keep the border once I group as mask.
            Best Regards,
            Chris Jumonville
            iMedia Web Design
            503.277.3553
            "PJR" <flash@SLICEreclusivebillionaire.com> wrote in message
            news:ej6m2b$bmv$1@forums.macromedia.com...
            > Peter
            > up
            > something
            > | Best Regards,
            > | Chris Jumonville
            > | iMedia Web Design
            > | 503.277.3553
            • 3. Re: Rounding image edges?
              Level 7
              Hi Chris, You can keep the border, or indeed add one if you don't already
              have one.
              If you locate the layers panel, (Window>Layers if it's not showing).
              You should see your image and a chain icon with your mask next to it.
              Click on the mask icon with the tiny pen icon in the bottom right hand
              corner...
              Now look in the Properties panel at the bottom of the page(at least mine
              is).
              In the Mask section you will see two radio buttons, Grayscale appearance and
              Path Outline and a check box, Show fill and stroke.
              The default setting is Grayscale appearance, change this to Path outline and
              check the Show fill and stroke box and your border should show up or you can
              add one using the Property Inspector.
              Peter
              ____________________________
              news:ej6svt$jtl$1@forums.macromedia.com...
              | Peter,
              I
              | Best Regards,
              | Chris Jumonville
              | iMedia Web Design
              | 503.277.3553
              | > Peter
              | > up
              | > something
              | > | Best Regards,
              | > | Chris Jumonville
              | > | iMedia Web Design
              | > | 503.277.3553
