4 Replies Latest reply on Apr 20, 2006 9:17 PM by hushhurt
    simple noob question
    hushhurt
      hello - i am new to actionscript, and i may be completely overlooking something obvious.
      what i am trying to do is access a variable within a different timeline from the main. i create a movieclip, within the mc i create a variable named x, but when i try and trace that variable from the main timeline, it says it is undefined.
      in the movieclip i assign "var x:Number = 5"
      in the main timeline i try and trace the variable with "trace(movieClipName.x)" and get an undefined.
      when i trace the variable from the moveclip timeline - it outputs "5"
      what am i missing here - it seems so easy, but i feel so slow.
      thank you
        • 1. Re: simple noob question
          dex002
          hey dude, the only variables that are available across multiple timelines are _global vars or vars declared in an class.
          this will work if you get it or set it on any timeline:
          _global.x = 5
          Note that you cannot use data typing with _global vars, so this will throw an error:
          var _global x:Number = 5
          • 2. Re: simple noob question
            Level 7
            Probably the movie clip's first frame has not played. A simple solution is
            to access the on the frame after it is attached to the timeline.
            Lon Hosford
            www.lonhosford.com
            May many happy bits flow your way!
            "hushhurt" <webforumsuser@macromedia.com> wrote in message
            news:e29dbg$t2f$1@forums.macromedia.com...
            something obvious.
            from
            but
            undefined.
            thank you
            • 3. Re: simple noob question
              Level 7
              "hushhurt" <webforumsuser@macromedia.com> wrote in message news:e29dbg$t2f$1@forums.macromedia.com...
              > something obvious.
              > undefined.
              Don't declare your variable as 'var' because that makes it a local variable.
              tralfaz
              • 4. Re: simple noob question
                hushhurt Level 1
                sweet - thanks everyone
