3 Replies Latest reply on Mar 21, 2016 6:43 AM by Szalam
    Will not export video?
    MemphisM
      Adobe after effects stop exporting video and now only exports a black mask.
      what happened?
        • 1. Re: Will not export video?
          We have no idea because we don't have any idea what you did. It's either user error or you are not using the most recent version of the software. Nobody can give you and answer to that question without a lot of details of your workflow, your experience level. If this is the first time you have ever used AE then the first thing wrong with your workflow is that you didn't take the time to learn the basics of how to use the software. Basic AE
          If you are an experienced user and have successfully produced a shot in AE then I apologize for not understanding your workflow and coming up with an answer more specific than make sure you know what you are doing and make sure your software is up to date.
          • 2. Re: Will not export video?
            MemphisM Level 1
            I would first have to point out that I have been successfully exporting video both from the render file and through the Adobe media encoder, literally hundreds of files, and then suddenly all I get  is a black screen as the final export product, though I use the same process that I  have always used.
            This now occurs both in exporting from the render file and from the media encoder. I'm wondering if I may have  accidentally hit some function in the layeror panel or the composition panel that blocks my composition from being visible for export.
            I have some skill with Adobe aftereffects, but I am by no means an expert  and certainly have it mastered the technical vocabulary.
            • 3. Re: Will not export video?
              We need more information to help you. FAQ: What information should I provide ?
              Screenshots would be massively helpful.
