Why does EntityLoadByExample() ignore relationships?
Sir_Meili Mar 19, 2016 6:15 PMI've been using ORM for a while, but just started getting into using EntityLoadByExample(). I thought this would be great, but I've run into an issue. Say I have an object "Art" and it has a many-to-one relationship to "Artist" (many arts may have the same artist).
So my sample Art object would be like:
component displayname = 'Art' {
property name='artID' fieldtype='id' generator='identity';
property name='title' type='string';
property name='Artist' fieldtype='many-to-one' CFC='Artist' fkcolumn='ArtistID'
My sample Artist Object would be like:
component displayname = 'Artist' {
property name='ArtistID' fieldtype='id' generator='identity';
property name='Name' type='string';
So, lets say I have an artist in my DB:
ArtistID | Name |
1 | Monet |
2 | Rembrandt |
And let's say I have some "Art" in my DB:
ArtID | title | ArtID |
1 | The Water Lily Pond | 1 |
2 | Woman with a Parasol | 1 |
3 | Poppies | 1 |
4 | The Night Watch | 2 |
5 | The Jewish Bride | 2 |
So, I will get the Monet Object:
monet = EntityLoad( 'Artist' , 1 , true );
Then I will create a "new" Art and add in monet as the artist:
myBlankArt = EntityNew( 'Art' , { Artist = monet } );
So, my expectations is that I would be able to run the following code and ONLY get the Art Objects with ArtIDs 1, 2, and 3 (because they have ArtistID 1).
artSearch = EntityLoadByExample( 'Art' , myBlankArt );
However, what happens is I get ALL the Art Objects because it IGNORES the Artist object in my example entity.
Am I complete crazy for expecting this to work? I understand that it might be a limitation of Hibernate, but it is quite frustrating!
I have found a work around by adding the following property to the Art Object:
property name='ArtistID' forumula='select ArtistID';
then adding using the ID in the entity using some somewhat complex code to dynamically pull the objects, then grab their ids,
public function loadByExample( example ) {
local.metaData = getMetaData( arguments.example );
for( local.property in local.metaData.properties ) {
if( structKeyExists( local.property , 'fieldtype' ) && listFind( 'many-to-one,one-to-one' , local.property.fieldType , ',' ) ) {
if( structKeyExists( local.property , 'fkcolumn' ) ) {
local.innerObject = arguments.example.getProperty( local.property.name , arguments.example );
if( !isNull( local.innerObject ) )
local.id = local.innerObject.getPrimaryKey();
if( !isNull( local.id ) )
arguments.example.setProperty( local.property.fkcolumn , local.id , local.newObject );
return EntityLoadByExample( arguments.example );
(note: getProperty and setProperty are methods in my base object that all my ORM objects extend that allow me to send in the name of a property and set/retrieve it instead of using the setter/getter. This is helpful when I am dynamically pulling the objects name)
It just seems like a hassle when the "...ByExample" I feel should do this for you.
