I want to authorise my computer, adobe digital won't accept my log inand password, says it has been used before, i have now moderated the password 3 times
I have the same issue, i get a message saying that my adobe ID had been used before on a differnt computer and wont allow me to use it on my current computer. I had to replace my old computer due to it dying. Any help would be much appreciated.
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Check if you used only Letters and Numbers in you Password. Digital Edition has Problems with Umlauts and special Characters.
