7 Replies Latest reply on Mar 21, 2016 5:38 AM by ashdflkjh
    Open and close PDF files from a CVS list
    ashdflkjh
      I would like to perform some actions on a list of files. I have them in a CSV file. I can read it in OK in the Console but cannot open them. The paths are correct, I can open one. But in the loop it does not work. Why?
      var oFile = util.readFileIntoStream("/C/test.txt");
      var cFile = util.stringFromStream(oFile, "utf-8");
      var n = cFile.split(",");
      //second part
      for (var i in n) {
        var otherDoc = app.openDoc(n[i]);
        otherDoc.closeDoc();
      undefinedInvalid Location "/D/test.pdf". File or folder does not exist.
      NotAllowedError: Security settings prevent access to this property or method.
      App.openDoc:2:Console undefined:Exec
      undefined
        • 1. Re: Open and close PDF files from a CVS list
          Are you sure the file path is correct?
          What happens when you run just this code from the console:
          app.openDoc("/D/test.pdf");
          • 2. Re: Open and close PDF files from a CVS list
            ashdflkjh Level 1
            If I run it in a fresh console window it works as a single line. After I try the loop it does not. I thought maybe this is some security restriction on iteration...
            I am generally struggling with accessing files. The idea is to list all files in a directory, then manually remove some files on the list, then perform some operations on the remaining files. If I am missing a better way, I am all ears.
            • 3. Re: Open and close PDF files from a CVS list
              ashdflkjh Level 1
              Here is the evidence try67
              var oFile = util.readFileIntoStream("/C/test/test.txt");
              var n = cFile.split("\n");
              console.println(n);
              /C/test/test.pdf
              true
              for (var i in n) {
              Invalid Location "/C/test/test.pdf". File or folder does not exist.
              undefined
              • 4. Re: Open and close PDF files from a CVS list
                This doesn't really prove anything... Can you open this file path directly, as I asked?
                Also, change this line:
                console.println(n);
                To:
                console.println(n.toSource());
                And see what the output is... My guess is you're not removing all of the line-breaks from the input file.
                • 5. Re: Open and close PDF files from a CVS list
                  ashdflkjh Level 1
                  Thanks, try67
                  //opening directly
                  var otherDoc = app.openDoc("/C/test/test.pdf");
                  undefined
                  //and the file opens
                  //running this second
                  console.println(n.toSource());["\uFEFF/C/test/test.pdf"]
                  true
                  //now running this
                  for (var i in n) {
                  }Invalid Location "/C/test/test.pdf". File or folder does not exist.
                  undefined
                  //i guess this looks like you are right. then how can i output a list of file and read them back into an array with those breaks removed?
                  • 6. Re: Open and close PDF files from a CVS list
                    OK, it's actually not a line-break, but something called BOM, which appears as the first character of some UTF-8 text files, especially those created on a Mac.
                    All you have to do is remove it from the strings. You can use something like this in your loop:
                    var filePath = n[i].replace("\uFEFF", "");
                    var otherDoc = app.openDoc(filePath);
                    You're benefiting from my experience here because I recently encountered this same issue and it took me several hours of frustration to solve it...
                    • 7. Re: Open and close PDF files from a CVS list
                      ashdflkjh Level 1
                      I see. Many thanks try67 !!! Here is how it looks now, as I was getting line breaks in multi-line files too
                      for (var i in n) {
                        var otherDoc = app.openDoc(n[i].replace(/(\r\n|\n|\r)/gm,"").replace("\uFEFF", ""));
