1 Reply Latest reply on Mar 21, 2016 10:14 AM by George_Johnson
    Using Acrobat Action Wizard to auto-tab to next field
    GTR Elise
      I’m trying to speed up the process of creating an interactive pdf form in Adobe Acrobat through Action Wizard using Javascript, as I use and change the forms many times a day. I’m struggling to make the auto tab work through Action Wizard – I have some fields that require only one number and I like it to automatically go to the next field once that number is entered. Example of some of the code I currently use in Action Wizard:
      for (var i = 0; i < numFields; i++) {
        var fName = getNthFieldName(i);
        var f = getField(fName);
        var fTool = getNthFieldName(i).userName;
        if (fName == "C1”) {
        f.charLimit = 1;
        f.alignment = "center";
          f.setAction("Keystroke", "AFNumber_Keystroke\(0, 0, 0, 0, \"\", false\);");
        if (fName =="C2”) {
        f.charLimit = 1;
      So I would like C1 to have some code that automatically goes to C2. Is there any way this is possible with just Action Wizard? Currently I’ve been doing it manual using:
      function tab_next(next_field_name) {
          if (event.willCommit || AFMergeChange(event).length === event.target.charLimit) {
              getField(next_field_name).setFocus();
      And the Keystroke script:
      tab_next(“C2”);
      If anyone knows a way to do this, that would be much appreciated. Thanks!
        • 1. Re: Using Acrobat Action Wizard to auto-tab to next field
          George_Johnson MVP & Adobe Community Professional
          You'd have to create a new document-level function that combines what the AFNumber_Keystroke routine accomplished as well as the tab_next routine, something like:
          // Document-level function
          function digOnlyKS_TabNext(next_field_name) {
              // Get all that is currently in the field
              var val = AFMergeChange(event);
              // Reject entry if anything but digits
              event.rc = AFExactMatch(/\d*/, val);
              if (event.rc && next_field_name) {
          You'd then like this in the keystroke event:
          // Auto tab to C2
          digOnlyKS_TabNext("C2");
          and for the C2 field:
          digOnlyKS_TabNext();
