3 Replies Latest reply on Apr 21, 2006 6:06 AM by Newsgroup_User
    Flash External interface iterprets empty string "" as string "null"
    slawu
      Hi
      I'm using ScreenTime mProjector and Flash8 to write some MSWindows application. A have a little plugin writen in C++. When I used Flash7 everything was all right but when I switched to Flash8 string "null" showed up everywhere. I asked ScreenTime support - they wrote:
      "When we pass or return a null string through the Flash External interface the Flash 8 player changes it to be a string equal to "null"."
      Can you help?
        • 1. Re: Flash External interface iterprets empty string "" as string "null"
          Level 7
          slawu,
          Okay.
          All right.
          > Can you help?
          What's your question? What do you need? Based on ScreenTime's
          response, I would alter my ActionScript to check for both empty strings and
          the string "null" in all locations where I previously only checked for empty
          strings.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Flash External interface iterprets empty string "" as string "null"
            slawu Level 1
            I'm sorry. I really didn't wrote what is my problem. So my problem is...
            I would like to pass empty strings between my plugin and my ActionScript and I would like to distinguish the strings "" and "null". Now I never know if the user entered the string "null" or he entered "".
            My question is: how can I pass the string "" from my plugin to AS and vice versa?
            • 3. Re: Flash External interface iterprets empty string "" as string "null"
              Level 7
              slawu,
              Aha. Well, this seems to only be happening because of your 3rd party
              wrapper. If that's how ScreenTime interacts with the ExternalInterface
              class, you may just have to handle the ""/"null" discrepancy from inside the
              SWF. If the user submits an empty string, you could check for that before
              using ExternalInterface and pass something else, instead.
              David
