5 Replies Latest reply on Apr 6, 2016 9:12 AM by runew73276507
    Textoverset and missing links and fonts
    runew73276507
      OBS: this is for InDesign CS3 use
      I have this script which checks for overset text:
      if (app.documents.length != 0){
         var myFrames = app.activeDocument.textFrames;
         var thePageNames = new Array();
         for (var j = 0 ; j <= (myFrames.length - 1); j++) {
           if(myFrames[j].overflows == true){
             try {
               thePageName = myFrames[j].parent.documentOffset;
             } catch (e) {
               continue; // must be on Pasteboard so ignore
             thePageNames[thePageName] = 1
         if (thePageNames.length == 0) {
           alert("No oversets found on pages.");
         } else{
           var s = "";
           for (i in thePageNames) {
             s = s + app.documents[0].pages[Number(i) - 1].name + ", ";
           s = s.substring(0,s.length - 2);
           alert("Check for oversets on page(s): " + "\n" + s);
       } else {
         alert("No documents are open.");
      I need it to fit into this script:
      var doc = app.activeDocument;
      var _PDFExportPreset = app.pdfExportPresets.item('MyPDFSetting');
      if (_PDFExportPreset == null){
         alert('Preset is missing');
         exit();
      var _DocName = doc.name.replace(/\.indd/, "");
      var _EndNumber = parseInt(_DocName.match(/\d{3}$/),10); /* extract end number */
      /* test if is a number */
      if (isNaN(_EndNumber)){
          alert('End document name is not a number');
          exit();
      for(i = 0; i < doc.pages.length; i++){
          _PageName = doc.pages.item(i).name;
          app.pdfExportPreferences.pageRange = _PageName;
          _NewNumber = _EndNumber + i; /* incresase number */
          _NewNumber = ("00"+_NewNumber).slice(-3); /* padding */
          _DocName = _DocName.replace(/\d{3}$/,_NewNumber); /* replace number in doc name */
          _PDFfile = new File('\\\\Testserver\\Test\\'.concat(_DocName,'.pdf'));
          doc.exportFile(ExportFormat.pdfType, _PDFfile, false, _PDFExportPreset);
      //If the active document has been changed since it was last saved, save it.
      if(app.activeDocument.modified == true){
       app.activeDocument.save();
      //Closes the active document.
      app.activeDocument.close()
      So if there is NO text overset I need the script to continue run and of there IS overset text inside the document frame and on the active layer I need it to alert and stop. If it is possilble I would also like that it is possible for the user to ignore the overset text and then make the script continue run.
      AND I would also like that it checks for Missing and/or out of date links AND missing fonts in the same princip as the overset text.
        • 1. Re: Textoverset and missing links and fonts
          runew73276507 Level 1
          I still need help if anyone has a solution
          • 2. Re: Textoverset and missing links and fonts
            tpk1982 Level 4
            Please use function and confirm available in JavaScript. So you can call the pdf script from the end of first function
            JavaScript Functions
            http://www.w3schools.com/jsref/met_win_confirm.asp
            • 3. Re: Textoverset and missing links and fonts
              b91823603 Level 3
              Hi runew73276507,
              Modify the code as shown below,
                     try {
                     } catch (e) {
                 } else{
                   var s = "";
                   if(!confirm("Check for oversets on page(s): " + "\n" + s+"\nDo you want to continue..."))
                   exit();
              } else {
                 exit();
              //then write your code here....
              • 4. Re: Textoverset and missing links and fonts
                Hi Dilibabu,
                Thank you very much for your help - I got it to work for my needs with some small corrections:
                       try {
                       } catch (e) {
                   } else{
                       var s = "";
                     exit();
                Now I am trying to modify same script so it with same princip can check for missing or out of date links AND missing fonts - can you help me out here also?
