5 Replies Latest reply on Jun 18, 2016 6:20 AM by 3zzz Branched to a new discussion.
    Deployment of flashplayer msi failed with timeout
    3zzz
      I try to deploy Flashplayer 21.0.0.182 using MSI for ActiveX and Plugin on Windows 7 german 64bit. If I install the msi the installation hangs. Using the installer from Adobe Flash Player Install for all versions is working.
      These are the steps for current deployment:
      Flashplayer IE
      check if Plugin is installed
      run uninstaller if not
      run install_flash_player_21_active_x.msi without any properties (ok REBOOT is used) or modifications
      modify mms.cfg
      Flashplayer Plugin
      check if activex is installed
      run install_flash_player_21_plugin.msi without any Properties or modifications
      modify mms.cfg
      This is the logfile for msi installer
      === Verbose logging started: 22.03.2016  11:25:48  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\SysWOW64\msiexec.exe ===
      MSI (c) (B0:38) [11:25:48:455]: Resetting cached policy values
      MSI (c) (B0:38) [11:25:48:455]: Machine policy value 'Debug' is 0
      MSI (c) (B0:38) [11:25:48:455]: ******* RunEngine:
                 ******* Product: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\install_flash_player_21_active_x .msi
                 ******* Action:
                 ******* CommandLine: **********
      MSI (c) (B0:38) [11:25:48:456]: Client-side and UI is none or basic: Running entire install on the server.
      MSI (c) (B0:38) [11:25:48:456]: Grabbed execution mutex.
      MSI (c) (B0:38) [11:25:48:475]: Cloaking enabled.
      MSI (c) (B0:38) [11:25:48:475]: Attempting to enable all disabled privileges before calling Install on Server
      MSI (c) (B0:38) [11:25:48:479]: Incrementing counter to disable shutdown. Counter after increment: 0
      MSI (s) (2C:54) [11:25:48:490]: Running installation inside multi-package transaction C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\install_flash_player_21_active_x .msi
      MSI (s) (2C:54) [11:25:48:490]: Grabbed execution mutex.
      MSI (s) (2C:54) [11:25:48:494]: Resetting cached policy values
      MSI (s) (2C:54) [11:25:48:494]: Machine policy value 'Debug' is 0
      MSI (s) (2C:54) [11:25:48:494]: ******* RunEngine:
                 ******* Action:
      MSI (s) (2C:54) [11:25:48:503]: Machine policy value 'DisableUserInstalls' is 0
      MSI (s) (2C:54) [11:25:48:504]: Setting cached product context: User non-assigned for product: 5845E07DA26AFA043B2F7F3D14B23E14
      MSI (s) (2C:54) [11:25:48:504]: Using cached product context: User non-assigned for product: 5845E07DA26AFA043B2F7F3D14B23E14
      MSI (s) (2C:54) [11:25:48:504]: Setting cached product context: User non-assigned for product: 7621A3DD89A12334EBA1D114C5C21C8D
      MSI (s) (2C:54) [11:25:48:504]: Using cached product context: User non-assigned for product: 7621A3DD89A12334EBA1D114C5C21C8D
      MSI (s) (2C:54) [11:25:48:504]: Setting cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:504]: Using cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:504]: Setting cached product context: machine assigned for product: 00004109110000000000000000F01FEC
      MSI (s) (2C:54) [11:25:48:504]: Using cached product context: machine assigned for product: 00004109110000000000000000F01FEC
      MSI (s) (2C:54) [11:25:48:504]: Setting cached product context: machine assigned for product: 000041091A0070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Using cached product context: machine assigned for product: 000041091A0070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Setting cached product context: machine assigned for product: 000041091A0090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Using cached product context: machine assigned for product: 000041091A0090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Setting cached product context: machine assigned for product: 00004109440070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Using cached product context: machine assigned for product: 00004109440070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Setting cached product context: machine assigned for product: 00004109440090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Using cached product context: machine assigned for product: 00004109440090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Setting cached product context: machine assigned for product: 00004109510070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Using cached product context: machine assigned for product: 00004109510070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Setting cached product context: machine assigned for product: 00004109510090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:505]: Using cached product context: machine assigned for product: 00004109510090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Setting cached product context: machine assigned for product: 00004109511090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Using cached product context: machine assigned for product: 00004109511090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Setting cached product context: machine assigned for product: 00004109610070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Using cached product context: machine assigned for product: 00004109610070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Setting cached product context: machine assigned for product: 00004109610090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Using cached product context: machine assigned for product: 00004109610090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Setting cached product context: machine assigned for product: 00004109611090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Using cached product context: machine assigned for product: 00004109611090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Setting cached product context: machine assigned for product: 00004109711090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:506]: Using cached product context: machine assigned for product: 00004109711090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Setting cached product context: machine assigned for product: 00004109810070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Using cached product context: machine assigned for product: 00004109810070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Setting cached product context: machine assigned for product: 00004109810090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Using cached product context: machine assigned for product: 00004109810090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Setting cached product context: machine assigned for product: 00004109910070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Using cached product context: machine assigned for product: 00004109910070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Setting cached product context: machine assigned for product: 00004109910090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Using cached product context: machine assigned for product: 00004109910090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Setting cached product context: machine assigned for product: 00004109A10070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Using cached product context: machine assigned for product: 00004109A10070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Setting cached product context: machine assigned for product: 00004109A10090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Using cached product context: machine assigned for product: 00004109A10090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:507]: Setting cached product context: machine assigned for product: 00004109A20000000100000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Using cached product context: machine assigned for product: 00004109A20000000100000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Setting cached product context: machine assigned for product: 00004109A20070400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Using cached product context: machine assigned for product: 00004109A20070400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Setting cached product context: machine assigned for product: 00004109A20090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Using cached product context: machine assigned for product: 00004109A20090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Setting cached product context: machine assigned for product: 00004109AB0070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Using cached product context: machine assigned for product: 00004109AB0070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Setting cached product context: machine assigned for product: 00004109AB0090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Using cached product context: machine assigned for product: 00004109AB0090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Setting cached product context: machine assigned for product: 00004109B10070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Using cached product context: machine assigned for product: 00004109B10070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Setting cached product context: machine assigned for product: 00004109B10090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:508]: Using cached product context: machine assigned for product: 00004109B10090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Setting cached product context: machine assigned for product: 00004109C20070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Using cached product context: machine assigned for product: 00004109C20070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Setting cached product context: machine assigned for product: 00004109C20090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Using cached product context: machine assigned for product: 00004109C20090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Setting cached product context: machine assigned for product: 00004109E60070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Using cached product context: machine assigned for product: 00004109E60070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Setting cached product context: machine assigned for product: 00004109E60090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Using cached product context: machine assigned for product: 00004109E60090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Setting cached product context: machine assigned for product: 00004109F10001400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Using cached product context: machine assigned for product: 00004109F10001400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Setting cached product context: machine assigned for product: 00004109F10070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:509]: Using cached product context: machine assigned for product: 00004109F10070400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Setting cached product context: machine assigned for product: 00004109F10090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Using cached product context: machine assigned for product: 00004109F10090400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Setting cached product context: machine assigned for product: 00004109F100A0C00000000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Using cached product context: machine assigned for product: 00004109F100A0C00000000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Setting cached product context: machine assigned for product: 00004109F100C0400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Using cached product context: machine assigned for product: 00004109F100C0400000000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Setting cached product context: machine assigned for product: 00005159250090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Using cached product context: machine assigned for product: 00005159250090400100000000F01FEC
      MSI (s) (2C:54) [11:25:48:510]: Setting cached product context: machine assigned for product: 05E9AE0BCF1C7F948B117ED359E12FA4
      MSI (s) (2C:54) [11:25:48:510]: Using cached product context: machine assigned for product: 05E9AE0BCF1C7F948B117ED359E12FA4
      MSI (s) (2C:54) [11:25:48:510]: Setting cached product context: machine assigned for product: 070C583262CE9BA478816E509C770CDE
      MSI (s) (2C:54) [11:25:48:510]: Using cached product context: machine assigned for product: 070C583262CE9BA478816E509C770CDE
      MSI (s) (2C:54) [11:25:48:511]: Setting cached product context: machine assigned for product: 08E0C60B7F499924D95B1E19AB0576C2
      MSI (s) (2C:54) [11:25:48:511]: Using cached product context: machine assigned for product: 08E0C60B7F499924D95B1E19AB0576C2
      MSI (s) (2C:54) [11:25:48:511]: Setting cached product context: machine assigned for product: 09AB59D18F4FCE748A2844C1993DC0E1
      MSI (s) (2C:54) [11:25:48:511]: Using cached product context: machine assigned for product: 09AB59D18F4FCE748A2844C1993DC0E1
      MSI (s) (2C:54) [11:25:48:511]: Setting cached product context: machine assigned for product: 0CC20BF55214FEC47AE53B0A9BF5A73A
      MSI (s) (2C:54) [11:25:48:511]: Using cached product context: machine assigned for product: 0CC20BF55214FEC47AE53B0A9BF5A73A
      MSI (s) (2C:54) [11:25:48:511]: Setting cached product context: machine assigned for product: 1007C6B46D7C017319E3B52CF3EC196E
      MSI (s) (2C:54) [11:25:48:511]: Using cached product context: machine assigned for product: 1007C6B46D7C017319E3B52CF3EC196E
      MSI (s) (2C:54) [11:25:48:511]: Setting cached product context: machine assigned for product: 1019A74A5BE64134DB1A928708BF9B80
      MSI (s) (2C:54) [11:25:48:511]: Using cached product context: machine assigned for product: 1019A74A5BE64134DB1A928708BF9B80
      MSI (s) (2C:54) [11:25:48:511]: Setting cached product context: machine assigned for product: 121E2D80A6F7BE3479DF26B944094330
      MSI (s) (2C:54) [11:25:48:511]: Using cached product context: machine assigned for product: 121E2D80A6F7BE3479DF26B944094330
      MSI (s) (2C:54) [11:25:48:512]: Setting cached product context: machine assigned for product: 12DEF5833D58E104B8A883413033AF8C
      MSI (s) (2C:54) [11:25:48:512]: Using cached product context: machine assigned for product: 12DEF5833D58E104B8A883413033AF8C
      MSI (s) (2C:54) [11:25:48:512]: Setting cached product context: machine assigned for product: 137FCEEC80F301240837E7785FC8103D
      MSI (s) (2C:54) [11:25:48:512]: Using cached product context: machine assigned for product: 137FCEEC80F301240837E7785FC8103D
      MSI (s) (2C:54) [11:25:48:512]: Setting cached product context: machine assigned for product: 153AA053AF120723B8A73845437E66DA
      MSI (s) (2C:54) [11:25:48:512]: Using cached product context: machine assigned for product: 153AA053AF120723B8A73845437E66DA
      MSI (s) (2C:54) [11:25:48:512]: Setting cached product context: machine assigned for product: 1796855C9A3EA234397B1D0DFE707646
      MSI (s) (2C:54) [11:25:48:512]: Using cached product context: machine assigned for product: 1796855C9A3EA234397B1D0DFE707646
      MSI (s) (2C:54) [11:25:48:512]: Setting cached product context: machine assigned for product: 1926E8D15D0BCE53481466615F760A7F
      MSI (s) (2C:54) [11:25:48:512]: Using cached product context: machine assigned for product: 1926E8D15D0BCE53481466615F760A7F
      MSI (s) (2C:54) [11:25:48:512]: Setting cached product context: machine assigned for product: 19DA96544F74E9D4F89C17E73CD2A71E
      MSI (s) (2C:54) [11:25:48:512]: Using cached product context: machine assigned for product: 19DA96544F74E9D4F89C17E73CD2A71E
      MSI (s) (2C:54) [11:25:48:513]: Setting cached product context: machine assigned for product: 1af2a8da7e60d0b429d7e6453b3d0182
      MSI (s) (2C:54) [11:25:48:513]: Using cached product context: machine assigned for product: 1af2a8da7e60d0b429d7e6453b3d0182
      MSI (s) (2C:54) [11:25:48:513]: Setting cached product context: machine assigned for product: 1D5E3C0FEDA1E123187686FED06E995A
      MSI (s) (2C:54) [11:25:48:513]: Using cached product context: machine assigned for product: 1D5E3C0FEDA1E123187686FED06E995A
      MSI (s) (2C:54) [11:25:48:513]: Setting cached product context: machine assigned for product: 1D763DBFF246FC747BB9B94EF83B0470
      MSI (s) (2C:54) [11:25:48:513]: Using cached product context: machine assigned for product: 1D763DBFF246FC747BB9B94EF83B0470
      MSI (s) (2C:54) [11:25:48:513]: Setting cached product context: machine assigned for product: 1F764691F11C67F458B88521DA8CB349
      MSI (s) (2C:54) [11:25:48:513]: Using cached product context: machine assigned for product: 1F764691F11C67F458B88521DA8CB349
      MSI (s) (2C:54) [11:25:48:513]: Setting cached product context: machine assigned for product: 20B91A1DE71869244AB57058F37DD475
      MSI (s) (2C:54) [11:25:48:513]: Using cached product context: machine assigned for product: 20B91A1DE71869244AB57058F37DD475
      MSI (s) (2C:54) [11:25:48:513]: Setting cached product context: machine assigned for product: 25BBB29DFF28DE24A8C3E460F249A47B
      MSI (s) (2C:54) [11:25:48:513]: Using cached product context: machine assigned for product: 25BBB29DFF28DE24A8C3E460F249A47B
      MSI (s) (2C:54) [11:25:48:513]: Setting cached product context: machine assigned for product: 26D3E1158E3177C46B1AC381951FD8FF
      MSI (s) (2C:54) [11:25:48:514]: Using cached product context: machine assigned for product: 26D3E1158E3177C46B1AC381951FD8FF
      MSI (s) (2C:54) [11:25:48:514]: Setting cached product context: machine assigned for product: 300C9B2DDC3A0A44D95E25EF89C6305E
      MSI (s) (2C:54) [11:25:48:514]: Using cached product context: machine assigned for product: 300C9B2DDC3A0A44D95E25EF89C6305E
      MSI (s) (2C:54) [11:25:48:514]: Setting cached product context: machine assigned for product: 3732E82594EA20844B8A23B6FBAD6D0A
      MSI (s) (2C:54) [11:25:48:514]: Using cached product context: machine assigned for product: 3732E82594EA20844B8A23B6FBAD6D0A
      MSI (s) (2C:54) [11:25:48:514]: Setting cached product context: machine assigned for product: 39680A21322919245B222D74FB5703FF
      MSI (s) (2C:54) [11:25:48:514]: Using cached product context: machine assigned for product: 39680A21322919245B222D74FB5703FF
      MSI (s) (2C:54) [11:25:48:514]: Setting cached product context: machine assigned for product: 4042899D12397B94CA19FD4B91B9A913
      MSI (s) (2C:54) [11:25:48:514]: Using cached product context: machine assigned for product: 4042899D12397B94CA19FD4B91B9A913
      MSI (s) (2C:54) [11:25:48:514]: Setting cached product context: machine assigned for product: 40E581B27BE37D11798C0005ADB176F5
      MSI (s) (2C:54) [11:25:48:514]: Using cached product context: machine assigned for product: 40E581B27BE37D11798C0005ADB176F5
      MSI (s) (2C:54) [11:25:48:514]: Setting cached product context: machine assigned for product: 4223F3FF207BBC840B143247A34EF015
      MSI (s) (2C:54) [11:25:48:514]: Using cached product context: machine assigned for product: 4223F3FF207BBC840B143247A34EF015
      MSI (s) (2C:54) [11:25:48:515]: Setting cached product context: machine assigned for product: 42D27DD0684067845A2A235AE10692B4
      MSI (s) (2C:54) [11:25:48:515]: Using cached product context: machine assigned for product: 42D27DD0684067845A2A235AE10692B4
      MSI (s) (2C:54) [11:25:48:515]: Setting cached product context: machine assigned for product: 45852D8D0F7D5C5478206D055A2AE312
      MSI (s) (2C:54) [11:25:48:515]: Using cached product context: machine assigned for product: 45852D8D0F7D5C5478206D055A2AE312
      MSI (s) (2C:54) [11:25:48:515]: Setting cached product context: machine assigned for product: 4940BFC469E21364384635E8A29A3142
      MSI (s) (2C:54) [11:25:48:515]: Using cached product context: machine assigned for product: 4940BFC469E21364384635E8A29A3142
      MSI (s) (2C:54) [11:25:48:515]: Setting cached product context: machine assigned for product: 4E9B274AFFA0B7F42BD56FF4E829A8BA
      MSI (s) (2C:54) [11:25:48:515]: Using cached product context: machine assigned for product: 4E9B274AFFA0B7F42BD56FF4E829A8BA
      MSI (s) (2C:54) [11:25:48:515]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120755FF
      MSI (s) (2C:54) [11:25:48:515]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120755FF
      MSI (s) (2C:54) [11:25:48:515]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140755FF
      MSI (s) (2C:54) [11:25:48:515]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140755FF
      MSI (s) (2C:54) [11:25:48:516]: Setting cached product context: machine assigned for product: 4FE93B4DC0B9F3340845ABE63E0067C4
      MSI (s) (2C:54) [11:25:48:516]: Using cached product context: machine assigned for product: 4FE93B4DC0B9F3340845ABE63E0067C4
      MSI (s) (2C:54) [11:25:48:516]: Setting cached product context: machine assigned for product: 51BB133E91DB2E8419E6E79453F709F5
      MSI (s) (2C:54) [11:25:48:516]: Using cached product context: machine assigned for product: 51BB133E91DB2E8419E6E79453F709F5
      MSI (s) (2C:54) [11:25:48:516]: Setting cached product context: machine assigned for product: 520A249C048A2FB4987848C9D04D5447
      MSI (s) (2C:54) [11:25:48:516]: Using cached product context: machine assigned for product: 520A249C048A2FB4987848C9D04D5447
      MSI (s) (2C:54) [11:25:48:516]: Setting cached product context: machine assigned for product: 59570F336A6FAAF4D8CB8580C82C4D58
      MSI (s) (2C:54) [11:25:48:516]: Using cached product context: machine assigned for product: 59570F336A6FAAF4D8CB8580C82C4D58
      MSI (s) (2C:54) [11:25:48:516]: Setting cached product context: machine assigned for product: 5D67DCF0C51F80248845AD6193DD7C91
      MSI (s) (2C:54) [11:25:48:516]: Using cached product context: machine assigned for product: 5D67DCF0C51F80248845AD6193DD7C91
      MSI (s) (2C:54) [11:25:48:516]: Setting cached product context: machine assigned for product: 5DAB1C8C6E456414DA70A3A83D56963C
      MSI (s) (2C:54) [11:25:48:516]: Using cached product context: machine assigned for product: 5DAB1C8C6E456414DA70A3A83D56963C
      MSI (s) (2C:54) [11:25:48:517]: Setting cached product context: machine assigned for product: 5FBA89DEFB6BDE7429BAC1CDBA694474
      MSI (s) (2C:54) [11:25:48:517]: Using cached product context: machine assigned for product: 5FBA89DEFB6BDE7429BAC1CDBA694474
      MSI (s) (2C:54) [11:25:48:517]: Setting cached product context: machine assigned for product: 6414876250E69FF3395387C6C7F05BEB
      MSI (s) (2C:54) [11:25:48:517]: Using cached product context: machine assigned for product: 6414876250E69FF3395387C6C7F05BEB
      MSI (s) (2C:54) [11:25:48:517]: Setting cached product context: machine assigned for product: 64625BFC68DD57549923DF18862F45FF
      MSI (s) (2C:54) [11:25:48:517]: Using cached product context: machine assigned for product: 64625BFC68DD57549923DF18862F45FF
      MSI (s) (2C:54) [11:25:48:517]: Setting cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
      MSI (s) (2C:54) [11:25:48:517]: Using cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
      MSI (s) (2C:54) [11:25:48:517]: Setting cached product context: machine assigned for product: 687A7CEC8C9A7FE4BB9556813E3B8C87
      MSI (s) (2C:54) [11:25:48:517]: Using cached product context: machine assigned for product: 687A7CEC8C9A7FE4BB9556813E3B8C87
      MSI (s) (2C:54) [11:25:48:517]: Setting cached product context: machine assigned for product: 68AB67CA7DA7035200000A0000000040
      MSI (s) (2C:54) [11:25:48:517]: Using cached product context: machine assigned for product: 68AB67CA7DA7035200000A0000000040
      MSI (s) (2C:54) [11:25:48:518]: Setting cached product context: machine assigned for product: 68AB67CA7DA7464543820A0000000050
      MSI (s) (2C:54) [11:25:48:518]: Using cached product context: machine assigned for product: 68AB67CA7DA7464543820A0000000050
      MSI (s) (2C:54) [11:25:48:518]: Setting cached product context: machine assigned for product: 68AB67CA7DA7FFFFB744BA0000000010
      MSI (s) (2C:54) [11:25:48:518]: Using cached product context: machine assigned for product: 68AB67CA7DA7FFFFB744BA0000000010
      MSI (s) (2C:54) [11:25:48:518]: Setting cached product context: machine assigned for product: 6B1D51EC6B91D4D4F834FCD5C23365FF
      MSI (s) (2C:54) [11:25:48:518]: Using cached product context: machine assigned for product: 6B1D51EC6B91D4D4F834FCD5C23365FF
      MSI (s) (2C:54) [11:25:48:518]: Setting cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
      MSI (s) (2C:54) [11:25:48:518]: Using cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
      MSI (s) (2C:54) [11:25:48:518]: Setting cached product context: machine assigned for product: 6F9E66FF7E38E3A3FA41D89E8A906A4A
      MSI (s) (2C:54) [11:25:48:518]: Using cached product context: machine assigned for product: 6F9E66FF7E38E3A3FA41D89E8A906A4A
      MSI (s) (2C:54) [11:25:48:518]: Setting cached product context: machine assigned for product: 71B0EB18B3654D541B8975126E6C56DC
      MSI (s) (2C:54) [11:25:48:518]: Using cached product context: machine assigned for product: 71B0EB18B3654D541B8975126E6C56DC
      MSI (s) (2C:54) [11:25:48:518]: Setting cached product context: machine assigned for product: 727E254E8B683324C83C14DF18A7AFFF
      MSI (s) (2C:54) [11:25:48:519]: Using cached product context: machine assigned for product: 727E254E8B683324C83C14DF18A7AFFF
      MSI (s) (2C:54) [11:25:48:519]: Setting cached product context: machine assigned for product: 811CF9E1D156439479EB5EC3EAC5D754
      MSI (s) (2C:54) [11:25:48:519]: Using cached product context: machine assigned for product: 811CF9E1D156439479EB5EC3EAC5D754
      MSI (s) (2C:54) [11:25:48:519]: Setting cached product context: machine assigned for product: 830FB9FB30EFD924B962F20ADF570625
      MSI (s) (2C:54) [11:25:48:519]: Using cached product context: machine assigned for product: 830FB9FB30EFD924B962F20ADF570625
      MSI (s) (2C:54) [11:25:48:519]: Setting cached product context: machine assigned for product: 8489373E92353E84D882B5DBE6B83E48
      MSI (s) (2C:54) [11:25:48:519]: Using cached product context: machine assigned for product: 8489373E92353E84D882B5DBE6B83E48
      MSI (s) (2C:54) [11:25:48:519]: Setting cached product context: machine assigned for product: 84b9c17023c712640acaf308593282f8
      MSI (s) (2C:54) [11:25:48:519]: Using cached product context: machine assigned for product: 84b9c17023c712640acaf308593282f8
      MSI (s) (2C:54) [11:25:48:519]: Setting cached product context: machine assigned for product: 88B87010189257F4690BB8222E2DED30
      MSI (s) (2C:54) [11:25:48:519]: Using cached product context: machine assigned for product: 88B87010189257F4690BB8222E2DED30
      MSI (s) (2C:54) [11:25:48:519]: Setting cached product context: machine assigned for product: 8B4937AF56ECE9F4CA993F27DA634542
      MSI (s) (2C:54) [11:25:48:520]: Using cached product context: machine assigned for product: 8B4937AF56ECE9F4CA993F27DA634542
      MSI (s) (2C:54) [11:25:48:520]: Setting cached product context: machine assigned for product: 8E58E8E6B4EC5FF4197F4099C9F9EAA6
      MSI (s) (2C:54) [11:25:48:520]: Using cached product context: machine assigned for product: 8E58E8E6B4EC5FF4197F4099C9F9EAA6
      MSI (s) (2C:54) [11:25:48:520]: Setting cached product context: machine assigned for product: 91785D291CBB3CC40AB8659C8E48CCC2
      MSI (s) (2C:54) [11:25:48:520]: Using cached product context: machine assigned for product: 91785D291CBB3CC40AB8659C8E48CCC2
      MSI (s) (2C:54) [11:25:48:520]: Setting cached product context: machine assigned for product: 9637E36972C64464BA15249C0D3BC447
      MSI (s) (2C:54) [11:25:48:520]: Using cached product context: machine assigned for product: 9637E36972C64464BA15249C0D3BC447
      MSI (s) (2C:54) [11:25:48:520]: Setting cached product context: machine assigned for product: 9AE9E7FF6E52C324DBF53073E83438C7
      MSI (s) (2C:54) [11:25:48:520]: Using cached product context: machine assigned for product: 9AE9E7FF6E52C324DBF53073E83438C7
      MSI (s) (2C:54) [11:25:48:520]: Setting cached product context: machine assigned for product: 9eab5ec6ac3d99b498a1d16c1c815acf
      MSI (s) (2C:54) [11:25:48:520]: Using cached product context: machine assigned for product: 9eab5ec6ac3d99b498a1d16c1c815acf
      MSI (s) (2C:54) [11:25:48:520]: Setting cached product context: machine assigned for product: 9EF6BAB69A7278A479FEED43FBB6AAD2
      MSI (s) (2C:54) [11:25:48:520]: Using cached product context: machine assigned for product: 9EF6BAB69A7278A479FEED43FBB6AAD2
      MSI (s) (2C:54) [11:25:48:521]: Setting cached product context: machine assigned for product: 9FA444B1EBD14884F85369B9FEFC968A
      MSI (s) (2C:54) [11:25:48:521]: Using cached product context: machine assigned for product: 9FA444B1EBD14884F85369B9FEFC968A
      MSI (s) (2C:54) [11:25:48:521]: Setting cached product context: machine assigned for product: A05E7C36DCBF0C0479F480552C68BAB2
      MSI (s) (2C:54) [11:25:48:521]: Using cached product context: machine assigned for product: A05E7C36DCBF0C0479F480552C68BAB2
      MSI (s) (2C:54) [11:25:48:521]: Setting cached product context: machine assigned for product: A7A8F98311688E241896022DAB0F5C59
      MSI (s) (2C:54) [11:25:48:521]: Using cached product context: machine assigned for product: A7A8F98311688E241896022DAB0F5C59
      MSI (s) (2C:54) [11:25:48:521]: Setting cached product context: machine assigned for product: A7C07E9B58F993A44A3AFB3A3CFB6731
      MSI (s) (2C:54) [11:25:48:521]: Using cached product context: machine assigned for product: A7C07E9B58F993A44A3AFB3A3CFB6731
      MSI (s) (2C:54) [11:25:48:521]: Setting cached product context: machine assigned for product: AF078AE2F585781409D3BCF9DF122E0E
      MSI (s) (2C:54) [11:25:48:521]: Using cached product context: machine assigned for product: AF078AE2F585781409D3BCF9DF122E0E
      MSI (s) (2C:54) [11:25:48:521]: Setting cached product context: machine assigned for product: AFD293B0BC81E3A40B6BC32853B9688C
      MSI (s) (2C:54) [11:25:48:521]: Using cached product context: machine assigned for product: AFD293B0BC81E3A40B6BC32853B9688C
      MSI (s) (2C:54) [11:25:48:522]: Setting cached product context: machine assigned for product: B047CBE03634B984C87289EC7004AB91
      MSI (s) (2C:54) [11:25:48:522]: Using cached product context: machine assigned for product: B047CBE03634B984C87289EC7004AB91
      MSI (s) (2C:54) [11:25:48:522]: Setting cached product context: machine assigned for product: B0F4613917B97CE4C8A7E329504736E0
      MSI (s) (2C:54) [11:25:48:522]: Using cached product context: machine assigned for product: B0F4613917B97CE4C8A7E329504736E0
      MSI (s) (2C:54) [11:25:48:522]: Setting cached product context: machine assigned for product: B5DEF536D6C2EB94786EA7F6DC22CBA5
      MSI (s) (2C:54) [11:25:48:522]: Using cached product context: machine assigned for product: B5DEF536D6C2EB94786EA7F6DC22CBA5
      MSI (s) (2C:54) [11:25:48:522]: Setting cached product context: machine assigned for product: B850D529A465A3444B2BE7096C34E255
      MSI (s) (2C:54) [11:25:48:522]: Using cached product context: machine assigned for product: B850D529A465A3444B2BE7096C34E255
      MSI (s) (2C:54) [11:25:48:522]: Setting cached product context: machine assigned for product: B88EE04BA00466241AB73EED469E4413
      MSI (s) (2C:54) [11:25:48:522]: Using cached product context: machine assigned for product: B88EE04BA00466241AB73EED469E4413
      MSI (s) (2C:54) [11:25:48:522]: Setting cached product context: machine assigned for product: B8CF35CA81EEC9F3B9950639D7B081C2
      MSI (s) (2C:54) [11:25:48:522]: Using cached product context: machine assigned for product: B8CF35CA81EEC9F3B9950639D7B081C2
      MSI (s) (2C:54) [11:25:48:523]: Setting cached product context: machine assigned for product: B939370D97B297146863DC6D9573E483
      MSI (s) (2C:54) [11:25:48:523]: Using cached product context: machine assigned for product: B939370D97B297146863DC6D9573E483
      MSI (s) (2C:54) [11:25:48:523]: Setting cached product context: machine assigned for product: BCA1BC2A2A49AB231AE5D70813F95798
      MSI (s) (2C:54) [11:25:48:523]: Using cached product context: machine assigned for product: BCA1BC2A2A49AB231AE5D70813F95798
      MSI (s) (2C:54) [11:25:48:523]: Setting cached product context: machine assigned for product: c1c4f01781cc94c4c8fb1542c0981a2a
      MSI (s) (2C:54) [11:25:48:523]: Using cached product context: machine assigned for product: c1c4f01781cc94c4c8fb1542c0981a2a
      MSI (s) (2C:54) [11:25:48:523]: Setting cached product context: machine assigned for product: C2DAA1748709CAD4DB34AF01BFC7F3EC
      MSI (s) (2C:54) [11:25:48:523]: Using cached product context: machine assigned for product: C2DAA1748709CAD4DB34AF01BFC7F3EC
      MSI (s) (2C:54) [11:25:48:523]: Setting cached product context: machine assigned for product: C313169CB933B504A9B878815848CEDA
      MSI (s) (2C:54) [11:25:48:523]: Using cached product context: machine assigned for product: C313169CB933B504A9B878815848CEDA
      MSI (s) (2C:54) [11:25:48:523]: Setting cached product context: machine assigned for product: C3839DFF5D1079849A4534FA95A9DE03
      MSI (s) (2C:54) [11:25:48:523]: Using cached product context: machine assigned for product: C3839DFF5D1079849A4534FA95A9DE03
      MSI (s) (2C:54) [11:25:48:524]: Setting cached product context: machine assigned for product: C50CACE03E86B2744A60AA9D7BFA9C8D
      MSI (s) (2C:54) [11:25:48:524]: Using cached product context: machine assigned for product: C50CACE03E86B2744A60AA9D7BFA9C8D
      MSI (s) (2C:54) [11:25:48:524]: Setting cached product context: machine assigned for product: C7937558D24AF684793B2ABC2C735239
      MSI (s) (2C:54) [11:25:48:524]: Using cached product context: machine assigned for product: C7937558D24AF684793B2ABC2C735239
      MSI (s) (2C:54) [11:25:48:524]: Setting cached product context: machine assigned for product: C9335768C821DD4438FBA0D5A6DB2879
      MSI (s) (2C:54) [11:25:48:524]: Using cached product context: machine assigned for product: C9335768C821DD4438FBA0D5A6DB2879
      MSI (s) (2C:54) [11:25:48:524]: Setting cached product context: machine assigned for product: C9A2212A996A5634DA8F86EFCA21D516
      MSI (s) (2C:54) [11:25:48:524]: Using cached product context: machine assigned for product: C9A2212A996A5634DA8F86EFCA21D516
      MSI (s) (2C:54) [11:25:48:524]: Setting cached product context: machine assigned for product: CF60544C648B2874CAB2C80332C60E57
      MSI (s) (2C:54) [11:25:48:524]: Using cached product context: machine assigned for product: CF60544C648B2874CAB2C80332C60E57
      MSI (s) (2C:54) [11:25:48:524]: Setting cached product context: machine assigned for product: CFD2C1F142D260E3CB8B271543DA9F98
      MSI (s) (2C:54) [11:25:48:524]: Using cached product context: machine assigned for product: CFD2C1F142D260E3CB8B271543DA9F98
      MSI (s) (2C:54) [11:25:48:525]: Setting cached product context: machine assigned for product: D0AC3A29DC55D5C4AB59C562002CF062
      MSI (s) (2C:54) [11:25:48:525]: Using cached product context: machine assigned for product: D0AC3A29DC55D5C4AB59C562002CF062
      MSI (s) (2C:54) [11:25:48:525]: Setting cached product context: machine assigned for product: D0B6F432EA017BB42B3F4ED8841659D2
      MSI (s) (2C:54) [11:25:48:525]: Using cached product context: machine assigned for product: D0B6F432EA017BB42B3F4ED8841659D2
      MSI (s) (2C:54) [11:25:48:525]: Setting cached product context: machine assigned for product: D20352A90C039D93DBF6126ECE614057
      MSI (s) (2C:54) [11:25:48:525]: Using cached product context: machine assigned for product: D20352A90C039D93DBF6126ECE614057
      MSI (s) (2C:54) [11:25:48:525]: Setting cached product context: machine assigned for product: D6BB7BA5D4D8E4647A0E2FA5E51540E9
      MSI (s) (2C:54) [11:25:48:525]: Using cached product context: machine assigned for product: D6BB7BA5D4D8E4647A0E2FA5E51540E9
      MSI (s) (2C:54) [11:25:48:525]: Setting cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100
      MSI (s) (2C:54) [11:25:48:525]: Using cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100
      MSI (s) (2C:54) [11:25:48:525]: Setting cached product context: machine assigned for product: D831F9A72B69D1040B3BBFF128416838
      MSI (s) (2C:54) [11:25:48:525]: Using cached product context: machine assigned for product: D831F9A72B69D1040B3BBFF128416838
      MSI (s) (2C:54) [11:25:48:526]: Setting cached product context: machine assigned for product: DB6A8167E887D9F44B35DA1C789B6441
      MSI (s) (2C:54) [11:25:48:526]: Using cached product context: machine assigned for product: DB6A8167E887D9F44B35DA1C789B6441
      MSI (s) (2C:54) [11:25:48:526]: Setting cached product context: machine assigned for product: E85AF24F704727849B735161CD413381
      MSI (s) (2C:54) [11:25:48:526]: Using cached product context: machine assigned for product: E85AF24F704727849B735161CD413381
      MSI (s) (2C:54) [11:25:48:526]: Setting cached product context: machine assigned for product: E873E3303DA65DA4DBBEBC6DB91340C6
      MSI (s) (2C:54) [11:25:48:526]: Using cached product context: machine assigned for product: E873E3303DA65DA4DBBEBC6DB91340C6
      MSI (s) (2C:54) [11:25:48:526]: Setting cached product context: machine assigned for product: ECF428BD067B3314A93B9B54D45C9393
      MSI (s) (2C:54) [11:25:48:526]: Using cached product context: machine assigned for product: ECF428BD067B3314A93B9B54D45C9393
      MSI (s) (2C:54) [11:25:48:526]: Setting cached product context: machine assigned for product: ED61347A4C9C1444FBCBF259A2F87836
      MSI (s) (2C:54) [11:25:48:526]: Using cached product context: machine assigned for product: ED61347A4C9C1444FBCBF259A2F87836
      MSI (s) (2C:54) [11:25:48:526]: Setting cached product context: machine assigned for product: EDB32C8D84749D449ADDA86BE41BB83E
      MSI (s) (2C:54) [11:25:48:526]: Using cached product context: machine assigned for product: EDB32C8D84749D449ADDA86BE41BB83E
      MSI (s) (2C:54) [11:25:48:527]: Setting cached product context: machine assigned for product: EE6A5A0BAB8F1B84BB23AB1CE7692C4B
      MSI (s) (2C:54) [11:25:48:527]: Using cached product context: machine assigned for product: EE6A5A0BAB8F1B84BB23AB1CE7692C4B
      MSI (s) (2C:54) [11:25:48:527]: Setting cached product context: machine assigned for product: EE97D8821D2AFA2459790BDACC328ADE
      MSI (s) (2C:54) [11:25:48:527]: Using cached product context: machine assigned for product: EE97D8821D2AFA2459790BDACC328ADE
      MSI (s) (2C:54) [11:25:48:527]: Setting cached product context: machine assigned for product: EED07F63FBE17074FA2A0E53EEEAAB1A
      MSI (s) (2C:54) [11:25:48:527]: Using cached product context: machine assigned for product: EED07F63FBE17074FA2A0E53EEEAAB1A
      MSI (s) (2C:54) [11:25:48:527]: Setting cached product context: machine assigned for product: EFEE0228DC83E77358593193D847A0EC
      MSI (s) (2C:54) [11:25:48:527]: Using cached product context: machine assigned for product: EFEE0228DC83E77358593193D847A0EC
      MSI (s) (2C:54) [11:25:48:527]: Setting cached product context: machine assigned for product: F31855E83AF28E74A99F13CDB0A43EDE
      MSI (s) (2C:54) [11:25:48:527]: Using cached product context: machine assigned for product: F31855E83AF28E74A99F13CDB0A43EDE
      MSI (s) (2C:54) [11:25:48:527]: Setting cached product context: machine assigned for product: F57535DFC0F7E894189ED2B317429486
      MSI (s) (2C:54) [11:25:48:527]: Using cached product context: machine assigned for product: F57535DFC0F7E894189ED2B317429486
      MSI (s) (2C:54) [11:25:48:528]: Setting cached product context: machine assigned for product: F6D70D51CC4E9D14883A4911E5E5A501
      MSI (s) (2C:54) [11:25:48:528]: Using cached product context: machine assigned for product: F6D70D51CC4E9D14883A4911E5E5A501
      MSI (s) (2C:54) [11:25:48:528]: Setting cached product context: machine assigned for product: F887AADD6E25AE44DA8B2938B711FB62
      MSI (s) (2C:54) [11:25:48:528]: Using cached product context: machine assigned for product: F887AADD6E25AE44DA8B2938B711FB62
      MSI (s) (2C:54) [11:25:48:528]: Setting cached product context: machine assigned for product: F91942D1564452E40BB4D0E94C17FFA7
      MSI (s) (2C:54) [11:25:48:528]: Using cached product context: machine assigned for product: F91942D1564452E40BB4D0E94C17FFA7
      MSI (s) (2C:54) [11:25:48:528]: Setting cached product context: machine assigned for product: F945AC88167972343B043E777EDAA4D2
      MSI (s) (2C:54) [11:25:48:528]: Using cached product context: machine assigned for product: F945AC88167972343B043E777EDAA4D2
      MSI (s) (2C:54) [11:25:48:528]: Setting cached product context: machine assigned for product: FC38113FF01E1ED4BB95C6F03FE884E1
      MSI (s) (2C:54) [11:25:48:528]: Using cached product context: machine assigned for product: FC38113FF01E1ED4BB95C6F03FE884E1
      MSI (s) (2C:54) [11:25:48:531]: SRSetRestorePoint skipped for this transaction.
      MSI (s) (2C:54) [11:25:48:535]: File will have security applied from OpCode.
      MSI (s) (2C:54) [11:25:48:562]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\install_flash_player_21_active_x .msi' against software restriction policy
      MSI (s) (2C:54) [11:25:48:562]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\install_flash_player_21_active_x .msi has a digital signature
      MSI (s) (2C:54) [11:25:48:563]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\install_flash_player_21_active_x .msi is permitted to run because the user token authorizes execution (system or service token).
      MSI (s) (2C:54) [11:25:48:563]: End dialog not enabled
      MSI (s) (2C:54) [11:25:48:563]: Original package ==> C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\install_flash_player_21_active_x .msi
      MSI (s) (2C:54) [11:25:48:563]: Package we're running from ==> C:\Windows\Installer\b6bf4c.msi
      MSI (s) (2C:54) [11:25:48:567]: APPCOMPAT: Compatibility mode property overrides found.
      MSI (s) (2C:54) [11:25:48:567]: APPCOMPAT: looking for appcompat database entry with ProductCode '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
      MSI (s) (2C:54) [11:25:48:567]: APPCOMPAT: no matching ProductCode found in database.
      MSI (s) (2C:54) [11:25:48:573]: MSCOREE not loaded loading copy from system32
      MSI (s) (2C:54) [11:25:48:578]: Machine policy value 'TransformsSecure' is 1
      MSI (s) (2C:54) [11:25:48:578]: Note: 1: 2205 2:  3: MsiFileHash
      MSI (s) (2C:54) [11:25:48:578]: Machine policy value 'DisablePatch' is 0
      MSI (s) (2C:54) [11:25:48:578]: Machine policy value 'AllowLockdownPatch' is 0
      MSI (s) (2C:54) [11:25:48:578]: Machine policy value 'DisableLUAPatching' is 0
      MSI (s) (2C:54) [11:25:48:578]: Machine policy value 'DisableFlyWeightPatching' is 0
      MSI (s) (2C:54) [11:25:48:578]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
      MSI (s) (2C:54) [11:25:48:579]: APPCOMPAT: looking for appcompat database entry with ProductCode '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
      MSI (s) (2C:54) [11:25:48:579]: APPCOMPAT: no matching ProductCode found in database.
      MSI (s) (2C:54) [11:25:48:579]: Transforms are not secure.
      MSI (s) (2C:54) [11:25:48:580]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Program Files (x86)\Common Files\enteo\NiLogs\Adobe Flash Player ActiveX 21.0.0.182_EN_inst.log'.
      MSI (s) (2C:54) [11:25:48:580]: Command Line: REBOOT=ReallySuppress CURRENTDIRECTORY=C:\Windows\system32 CLIENTUILEVEL=3 CLIENTPROCESSID=4784
      MSI (s) (2C:54) [11:25:48:580]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{68B30DE0-0B6D-4EB9-BFC0-D3DC88FF7A37}'.
      MSI (s) (2C:54) [11:25:48:580]: Product Code passed to Engine.Initialize:           ''
      MSI (s) (2C:54) [11:25:48:580]: Product Code from property table before transforms: '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
      MSI (s) (2C:54) [11:25:48:580]: Product Code from property table after transforms:  '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
      MSI (s) (2C:54) [11:25:48:580]: Product not registered: beginning first-time install
      MSI (s) (2C:54) [11:25:48:580]: Product {92C34178-B679-4C83-AC33-7EFCE6D36E01} is not managed.
      MSI (s) (2C:54) [11:25:48:580]: MSI_LUA: Credential prompt not required, user is an admin
      MSI (s) (2C:54) [11:25:48:580]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
      MSI (s) (2C:54) [11:25:48:580]: Entering CMsiConfigurationManager::SetLastUsedSource.
      MSI (s) (2C:54) [11:25:48:580]: User policy value 'SearchOrder' is 'nmu'
      MSI (s) (2C:54) [11:25:48:580]: Adding new sources is allowed.
      MSI (s) (2C:54) [11:25:48:581]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
      MSI (s) (2C:54) [11:25:48:581]: Package name extracted from package path: 'install_flash_player_21_active_x.msi'
      MSI (s) (2C:54) [11:25:48:582]: Package to be registered: 'install_flash_player_21_active_x.msi'
      MSI (s) (2C:54) [11:25:48:583]: Note: 1: 2262 2: AdminProperties 3: -2147287038
      MSI (s) (2C:54) [11:25:48:583]: Machine policy value 'DisableMsi' is 0
      MSI (s) (2C:54) [11:25:48:583]: Machine policy value 'AlwaysInstallElevated' is 1
      MSI (s) (2C:54) [11:25:48:583]: User policy value 'AlwaysInstallElevated' is 0
      MSI (s) (2C:54) [11:25:48:583]: Product installation will be elevated because user is admin and product is being installed per-machine.
      MSI (s) (2C:54) [11:25:48:583]: Running product '{92C34178-B679-4C83-AC33-7EFCE6D36E01}' with elevated privileges: Product is assigned.
      MSI (s) (2C:54) [11:25:48:583]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
      MSI (s) (2C:54) [11:25:48:583]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Windows\system32'.
      MSI (s) (2C:54) [11:25:48:583]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.
      MSI (s) (2C:54) [11:25:48:583]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4784'.
      MSI (s) (2C:54) [11:25:48:583]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
      MSI (s) (2C:54) [11:25:48:587]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'f33982b3b1dfef48aec09432df35bd07'.
      MSI (s) (2C:54) [11:25:48:587]: RESTART MANAGER: Session opened.
      MSI (s) (2C:54) [11:25:48:588]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
      MSI (s) (2C:54) [11:25:48:588]: TRANSFORMS property is now:
      MSI (s) (2C:54) [11:25:48:588]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '110'.
      MSI (s) (2C:54) [11:25:48:590]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming
      MSI (s) (2C:54) [11:25:48:592]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\Favorites
      MSI (s) (2C:54) [11:25:48:594]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Network Shortcuts
      MSI (s) (2C:54) [11:25:48:595]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\Documents
      MSI (s) (2C:54) [11:25:48:597]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
      MSI (s) (2C:54) [11:25:48:598]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Recent
      MSI (s) (2C:54) [11:25:48:600]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\SendTo
      MSI (s) (2C:54) [11:25:48:602]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Templates
      MSI (s) (2C:54) [11:25:48:602]: SHELL32::SHGetFolderPath returned: C:\ProgramData
      MSI (s) (2C:54) [11:25:48:603]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Local
      MSI (s) (2C:54) [11:25:48:605]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\Pictures
      MSI (s) (2C:54) [11:25:48:608]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
      MSI (s) (2C:54) [11:25:48:610]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
      MSI (s) (2C:54) [11:25:48:611]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
      MSI (s) (2C:54) [11:25:48:613]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
      MSI (s) (2C:54) [11:25:48:615]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
      MSI (s) (2C:54) [11:25:48:618]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
      MSI (s) (2C:54) [11:25:48:619]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
      MSI (s) (2C:54) [11:25:48:621]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
      MSI (s) (2C:54) [11:25:48:622]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\AppData\Roaming\Microsoft\Windows\Start Menu
      MSI (s) (2C:54) [11:25:48:624]: SHELL32::SHGetFolderPath returned: C:\Users\svc.corp.DSMRun\Desktop
      MSI (s) (2C:54) [11:25:48:626]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
      MSI (s) (2C:54) [11:25:48:627]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
      MSI (s) (2C:54) [11:25:48:627]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
      MSI (s) (2C:54) [11:25:48:634]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
      MSI (s) (2C:54) [11:25:48:634]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
      MSI (s) (2C:54) [11:25:48:634]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
      MSI (s) (2C:54) [11:25:48:634]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
      MSI (s) (2C:54) [11:25:48:634]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Knorr-Bremse'.
      MSI (s) (2C:54) [11:25:48:635]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Knorr-Bremse'.
      MSI (s) (2C:54) [11:25:48:635]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\b6bf4c.msi'.
      MSI (s) (2C:54) [11:25:48:635]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\install_flash_player_21_active_x .msi'.
      MSI (s) (2C:54) [11:25:48:635]: Machine policy value 'MsiDisableEmbeddedUI' is 0
      MSI (s) (2C:54) [11:25:48:635]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
      MSI (s) (2C:54) [11:25:48:635]: Note: 1: 2205 2:  3: PatchPackage
      MSI (s) (2C:54) [11:25:48:635]: Machine policy value 'DisableRollback' is 0
      MSI (s) (2C:54) [11:25:48:635]: User policy value 'DisableRollback' is 0
      MSI (s) (2C:54) [11:25:48:635]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
      === Logging started: 22.03.2016  11:25:48 ===
      MSI (s) (2C:54) [11:25:48:636]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
      MSI (s) (2C:54) [11:25:48:636]: Doing action: INSTALL
      Action start 11:25:48: INSTALL.
      MSI (s) (2C:54) [11:25:48:637]: Running ExecuteSequence
      MSI (s) (2C:54) [11:25:48:637]: Doing action: ISSetupFilesExtract
      MSI (s) (2C:54) [11:25:48:640]: Creating MSIHANDLE (1) of type 790542 for thread 6228
      MSI (s) (2C:2C) [11:25:48:659]: Invoking remote custom action. DLL: C:\Windows\Installer\MSIBFB9.tmp, Entrypoint: SFStartupEx
      MSI (s) (2C:B4) [11:25:48:661]: Generating random cookie.
      MSI (s) (2C:B4) [11:25:48:666]: Created Custom Action Server with PID 392 (0x188).
      MSI (s) (2C:44) [11:25:48:729]: Running as a service.
      MSI (s) (2C:44) [11:25:48:732]: Hello, I'm your 32bit Impersonated custom action server.
      MSI (s) (2C!A0) [11:25:48:737]: Creating MSIHANDLE (2) of type 790531 for thread 160
      Action start 11:25:48: ISSetupFilesExtract.
      MSI (s) (2C!A0) [11:25:48:737]: Closing MSIHANDLE (2) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:738]: Creating MSIHANDLE (3) of type 790531 for thread 160
      1: Starting to extract setup files
      MSI (s) (2C!A0) [11:25:48:738]: Closing MSIHANDLE (3) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:742]: Creating MSIHANDLE (4) of type 790531 for thread 160
      1: Getting SUPPORTDIR property :
      MSI (s) (2C!A0) [11:25:48:743]: Closing MSIHANDLE (4) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:743]: Creating MSIHANDLE (5) of type 790541 for thread 160
      MSI (s) (2C!A0) [11:25:48:743]: Creating MSIHANDLE (6) of type 790531 for thread 160
      1: Extracting SetupFiles to:  C:\Users\SVCCOR~1.DSM\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
      MSI (s) (2C!A0) [11:25:48:744]: Closing MSIHANDLE (6) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:745]: Creating MSIHANDLE (7) of type 790540 for thread 160
      MSI (s) (2C!A0) [11:25:48:745]: Creating MSIHANDLE (8) of type 790531 for thread 160
      1: Getting ISSetupFile table view
      MSI (s) (2C!A0) [11:25:48:746]: Closing MSIHANDLE (8) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:746]: Creating MSIHANDLE (9) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:746]: Creating MSIHANDLE (10) of type 790531 for thread 160
      1: Executing ISSetupFile table view
      MSI (s) (2C!A0) [11:25:48:747]: Closing MSIHANDLE (10) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:747]: Creating MSIHANDLE (11) of type 790531 for thread 160
      1: Extracting Setup File:
      MSI (s) (2C!A0) [11:25:48:747]: Closing MSIHANDLE (11) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:749]: Closing MSIHANDLE (9) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:749]: Creating MSIHANDLE (12) of type 790531 for thread 160
      1: C:\Users\SVCCOR~1.DSM\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\IsIllegal Upgrade.vbs
      MSI (s) (2C!A0) [11:25:48:750]: Closing MSIHANDLE (12) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:750]: PROPERTY CHANGE: Adding SUPPORTDIR property. Its value is 'C:\Users\SVCCOR~1.DSM\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
      MSI (s) (2C!A0) [11:25:48:750]: PROPERTY CHANGE: Adding ISSETUPFILESCOMPLETED property. Its value is 'Completed'.
      MSI (s) (2C!A0) [11:25:48:750]: Creating MSIHANDLE (13) of type 790531 for thread 160
      1: Setting SUPPORTDIR property to:  C:\Users\SVCCOR~1.DSM\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
      MSI (s) (2C!A0) [11:25:48:750]: Closing MSIHANDLE (13) of type 790531 for thread 160
      MSI (s) (2C!A0) [11:25:48:751]: Closing MSIHANDLE (7) of type 790540 for thread 160
      MSI (s) (2C!A0) [11:25:48:751]: Closing MSIHANDLE (5) of type 790541 for thread 160
      MSI (s) (2C:2C) [11:25:48:751]: Closing MSIHANDLE (1) of type 790542 for thread 6228
      1: Setting ISSETUPFILESCOMPLETED property
      MSI (s) (2C:54) [11:25:48:753]: Doing action: ISSetAllUsers
      Action ended 11:25:48: ISSetupFilesExtract. Return value 1.
      MSI (s) (2C:54) [11:25:48:756]: Creating MSIHANDLE (14) of type 790542 for thread 6228
      MSI (s) (2C:00) [11:25:48:781]: Invoking remote custom action. DLL: C:\Windows\Installer\MSIC027.tmp, Entrypoint: SetAllUsers
      MSI (s) (2C!04) [11:25:48:786]: Creating MSIHANDLE (15) of type 790531 for thread 7940
      Action start 11:25:48: ISSetAllUsers.
      MSI (s) (2C!04) [11:25:48:787]: Closing MSIHANDLE (15) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:787]: Creating MSIHANDLE (16) of type 790541 for thread 7940
      MSI (s) (2C!04) [11:25:48:787]: Creating MSIHANDLE (17) of type 790531 for thread 7940
      InstallShield 11:25:48: Begin SetAllUsers()
      MSI (s) (2C!04) [11:25:48:788]: Closing MSIHANDLE (17) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:789]: Creating MSIHANDLE (18) of type 790540 for thread 7940
      MSI (s) (2C!04) [11:25:48:789]: Creating MSIHANDLE (19) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:790]: Creating MSIHANDLE (20) of type 790531 for thread 7940
      InstallShield 11:25:48: Getting records from Upgrade table
      MSI (s) (2C!04) [11:25:48:792]: Closing MSIHANDLE (20) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:792]: Creating MSIHANDLE (21) of type 790531 for thread 7940
      InstallShield 11:25:48: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C}    MinVersion: 6.0.0.0    MaxVersion: 21.0.0.182    Language:     Attributes: 769
      MSI (s) (2C!04) [11:25:48:794]: Closing MSIHANDLE (21) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:794]: Closing MSIHANDLE (19) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:795]: Creating MSIHANDLE (22) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:796]: Creating MSIHANDLE (23) of type 790531 for thread 7940
      InstallShield 11:25:48: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
      MSI (s) (2C!04) [11:25:48:798]: Closing MSIHANDLE (23) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:798]: Creating MSIHANDLE (24) of type 790531 for thread 7940
      InstallShield 11:25:48: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1}    MinVersion:     MaxVersion: 21.0.0.182    Language:     Attributes: 257
      MSI (s) (2C!04) [11:25:48:799]: Closing MSIHANDLE (24) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:800]: Closing MSIHANDLE (22) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:800]: Creating MSIHANDLE (25) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:801]: Creating MSIHANDLE (26) of type 790531 for thread 7940
      InstallShield 11:25:48: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
      MSI (s) (2C!04) [11:25:48:802]: Closing MSIHANDLE (26) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:802]: Creating MSIHANDLE (27) of type 790531 for thread 7940
      InstallShield 11:25:48: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8}    MinVersion:     MaxVersion: 21.0.0.182    Language:     Attributes: 257
      MSI (s) (2C!04) [11:25:48:802]: Closing MSIHANDLE (27) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:803]: Closing MSIHANDLE (25) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:803]: Creating MSIHANDLE (28) of type 790531 for thread 7940
      InstallShield 11:25:48: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
      MSI (s) (2C!04) [11:25:48:803]: Closing MSIHANDLE (28) of type 790531 for thread 7940
      MSI (s) (2C!04) [11:25:48:803]: Closing MSIHANDLE (18) of type 790540 for thread 7940
      MSI (s) (2C!04) [11:25:48:804]: Closing MSIHANDLE (16) of type 790541 for thread 7940
      MSI (s) (2C:00) [11:25:48:804]: Closing MSIHANDLE (14) of type 790542 for thread 6228
      InstallShield 11:25:48: End SetAllUsers()
      MSI (s) (2C:54) [11:25:48:806]: Doing action: AppSearch
      Action ended 11:25:48: ISSetAllUsers. Return value 1.
      Action start 11:25:48: AppSearch.
      MSI (s) (2C:54) [11:25:48:807]: Note: 1: 2262 2: Signature 3: -2147287038
      MSI (s) (2C:54) [11:25:48:807]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Macromedia\FlashPlayerActiveX 3: 2
      MSI (s) (2C:54) [11:25:48:808]: Doing action: LaunchConditions
      Action ended 11:25:48: AppSearch. Return value 1.
      Action start 11:25:48: LaunchConditions.
      MSI (s) (2C:54) [11:25:48:809]: Doing action: FindRelatedProducts
      Action ended 11:25:48: LaunchConditions. Return value 1.
      Action start 11:25:48: FindRelatedProducts.
      MSI (s) (2C:54) [11:25:48:811]: Skipping action: CCPSearch (condition is false)
      MSI (s) (2C:54) [11:25:48:811]: Skipping action: RMCCPSearch (condition is false)
      MSI (s) (2C:54) [11:25:48:811]: Doing action: ValidateProductID
      Action ended 11:25:48: FindRelatedProducts. Return value 1.
      Action start 11:25:48: ValidateProductID.
      MSI (s) (2C:54) [11:25:48:813]: Doing action: MakePropsAvailable
      Action ended 11:25:48: ValidateProductID. Return value 1.
      Action start 11:25:48: MakePropsAvailable.
      MSI (s) (2C:54) [11:25:48:813]: Doing action: IsIllegalUpgrade
      Action ended 11:25:48: MakePropsAvailable. Return value 1.
      MSI (s) (2C:54) [11:25:48:814]: Creating MSIHANDLE (29) of type 790542 for thread 6228
      MSI (s) (2C:00) [11:25:48:814]: Creating MSIHANDLE (30) of type 0 for thread 1792
      MSI (s) (2C:00) [11:25:48:826]: Closing MSIHANDLE (30) of type 0 for thread 1792
      MSI (s) (2C:00) [11:25:48:826]: Closing MSIHANDLE (29) of type 790542 for thread 6228
      Action start 11:25:48: IsIllegalUpgrade.
      MSI (s) (2C:54) [11:25:48:826]: Doing action: CostInitialize
      Action ended 11:25:48: IsIllegalUpgrade. Return value 0.
      MSI (s) (2C:54) [11:25:48:827]: Machine policy value 'MaxPatchCacheSize' is 10
      MSI (s) (2C:54) [11:25:48:827]: Baseline: Sorting baselines for {92C34178-B679-4C83-AC33-7EFCE6D36E01}.
      MSI (s) (2C:54) [11:25:48:827]: Baseline: New baseline 21.0.0 from transaction.
      MSI (s) (2C:54) [11:25:48:827]: Baseline: Sorted order Native: Order 0.
      MSI (s) (2C:54) [11:25:48:827]: Baseline Data Table:
      MSI (s) (2C:54) [11:25:48:827]: ProductCode: {92C34178-B679-4C83-AC33-7EFCE6D36E01} Version: 21.0.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
      MSI (s) (2C:54) [11:25:48:827]: Baseline File Table:
      Action start 11:25:48: CostInitialize.
      MSI (s) (2C:54) [11:25:48:829]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
      MSI (s) (2C:54) [11:25:48:829]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
      MSI (s) (2C:54) [11:25:48:829]: Note: 1: 2262 2: Patch 3: -2147287038
      MSI (s) (2C:54) [11:25:48:829]: Note: 1: 2205 2:  3: PatchPackage
      MSI (s) (2C:54) [11:25:48:829]: Note: 1: 2205 2:  3: MsiPatchHeaders
      MSI (s) (2C:54) [11:25:48:829]: Note: 1: 2205 2:  3: __MsiPatchFileList
      MSI (s) (2C:54) [11:25:48:829]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
      MSI (s) (2C:54) [11:25:48:829]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
      MSI (s) (2C:54) [11:25:48:829]: Doing action: FileCost
      Action ended 11:25:48: CostInitialize. Return value 1.
      MSI (s) (2C:54) [11:25:48:830]: Note: 1: 2205 2:  3: MsiAssembly
      MSI (s) (2C:54) [11:25:48:830]: Note: 1: 2205 2:  3: Registry
      MSI (s) (2C:54) [11:25:48:830]: Note: 1: 2205 2:  3: Class
      MSI (s) (2C:54) [11:25:48:830]: Note: 1: 2205 2:  3: Extension
      MSI (s) (2C:54) [11:25:48:830]: Note: 1: 2205 2:  3: TypeLib
      Action start 11:25:48: FileCost.
      MSI (s) (2C:54) [11:25:48:830]: Doing action: IsolateComponents
      Action ended 11:25:48: FileCost. Return value 1.
      Action start 11:25:48: IsolateComponents.
      MSI (s) (2C:54) [11:25:48:830]: Doing action: CostFinalize
      Action ended 11:25:48: IsolateComponents. Return value 0.
      MSI (s) (2C:54) [11:25:48:830]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
      MSI (s) (2C:54) [11:25:48:830]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
      MSI (s) (2C:54) [11:25:48:830]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
      MSI (s) (2C:54) [11:25:48:830]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
      MSI (s) (2C:54) [11:25:48:830]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
      MSI (s) (2C:54) [11:25:48:831]: Note: 1: 2205 2:  3: Condition
      MSI (s) (2C:54) [11:25:48:831]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
      MSI (s) (2C:54) [11:25:48:831]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\'.
      MSI (s) (2C:54) [11:25:48:832]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\SysWOW64\Macromed\'.
      MSI (s) (2C:54) [11:25:48:832]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\SysWOW64\Macromed\Flash\'.
      MSI (s) (2C:54) [11:25:48:832]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\SysWOW64\Macromed\Flash\'.
      MSI (s) (2C:54) [11:25:48:832]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
      MSI (s) (2C:54) [11:25:48:832]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
      MSI (s) (2C:54) [11:25:48:832]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\'.
      MSI (s) (2C:54) [11:25:48:832]: Target path resolution complete. Dumping Directory table...
      MSI (s) (2C:54) [11:25:48:832]: Note: target paths subject to change (via custom actions or browsing)
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: TARGETDIR    , Object: C:\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: USERPROFILE    , Object: C:\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: TempFolder    , Object: C:\Users\SVCCOR~1.DSM\AppData\Local\Temp\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: SystemFolder    , Object: C:\Windows\SysWOW64\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: MACROMED    , Object: C:\Windows\SysWOW64\Macromed\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: FLASH    , Object: C:\Windows\SysWOW64\Macromed\Flash\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: INSTALLDIR    , Object: C:\Windows\SysWOW64\Macromed\Flash\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: ISCommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\InstallShield\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: ISUpdateServiceFolder    , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
      MSI (s) (2C:54) [11:25:48:832]: Dir (target): Key: ALLUSERSPROFILE    , Object: C:\
      MSI (s) (2C:54) [11:25:48:832]: Note: 1: 2205 2:  3: MsiAssembly
      MSI (s) (2C:54) [11:25:48:832]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
      Action start 11:25:48: CostFinalize.
      MSI (s) (2C:54) [11:25:48:833]: Doing action: SetARPINSTALLLOCATION
      Action ended 11:25:48: CostFinalize. Return value 1.
      MSI (s) (2C:54) [11:25:48:833]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\SysWOW64\Macromed\Flash\'.
      Action start 11:25:48: SetARPINSTALLLOCATION.
      MSI (s) (2C:54) [11:25:48:833]: Doing action: SetODBCFolders
      Action ended 11:25:48: SetARPINSTALLLOCATION. Return value 1.
      MSI (s) (2C:54) [11:25:48:833]: Note: 1: 2205 2:  3: ODBCDriver
      MSI (s) (2C:54) [11:25:48:833]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
      MSI (s) (2C:54) [11:25:48:834]: Note: 1: 2205 2:  3: ODBCTranslator
      MSI (s) (2C:54) [11:25:48:834]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
      Action start 11:25:48: SetODBCFolders.
      MSI (s) (2C:54) [11:25:48:834]: Doing action: MigrateFeatureStates
      Action ended 11:25:48: SetODBCFolders. Return value 0.
      Action start 11:25:48: MigrateFeatureStates.
      MSI (s) (2C:54) [11:25:48:834]: Doing action: InstallValidate
      Action ended 11:25:48: MigrateFeatureStates. Return value 0.
      MSI (s) (2C:54) [11:25:48:835]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'f33982b3b1dfef48aec09432df35bd07'.
      MSI (s) (2C:54) [11:25:48:835]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
      MSI (s) (2C:54) [11:25:48:835]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
      MSI (s) (2C:54) [11:25:48:835]: Component: InstallAX_21_0_0_182.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: Registry
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: BindImage
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: ProgId
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: PublishComponent
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: SelfReg
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: Extension
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: Font
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: Shortcut
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: Class
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: TypeLib
      Action start 11:25:48: InstallValidate.
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: _RemoveFilePath
      MSI (s) (2C:54) [11:25:48:835]: Note: 1: 2205 2:  3: MsiFileHash
      MSI (s) (2C:54) [11:25:48:835]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: Registry
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: BindImage
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: ProgId
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: PublishComponent
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: SelfReg
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: Extension
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: Font
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: Shortcut
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: Class
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: TypeLib
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2727 2:
      MSI (s) (2C:54) [11:25:48:836]: Note: 1: 2205 2:  3: FilesInUse
      MSI (s) (2C:54) [11:25:48:858]: Note: 1: 2727 2:
      MSI (s) (2C:54) [11:25:48:858]: Doing action: RemoveExistingProducts
      Action ended 11:25:48: InstallValidate. Return value 1.
      Action start 11:25:48: RemoveExistingProducts.
      MSI (s) (2C:54) [11:25:48:861]: Doing action: InstallInitialize
      Action ended 11:25:48: RemoveExistingProducts. Return value 1.
      MSI (s) (2C:54) [11:25:48:861]: Machine policy value 'AlwaysInstallElevated' is 1
      MSI (s) (2C:54) [11:25:48:861]: User policy value 'AlwaysInstallElevated' is 0
      MSI (s) (2C:54) [11:25:48:861]: BeginTransaction: Locking Server
      MSI (s) (2C:54) [11:25:48:862]: SRSetRestorePoint skipped for this transaction.
      MSI (s) (2C:54) [11:25:48:862]: Server not locked: locking for product {92C34178-B679-4C83-AC33-7EFCE6D36E01}
      Action start 11:25:48: InstallInitialize.
      MSI (s) (2C:54) [11:25:49:008]: Skipping action: CallExeUninstaller (condition is false)
      MSI (s) (2C:54) [11:25:49:008]: Doing action: AllocateRegistrySpace
      Action ended 11:25:49: InstallInitialize. Return value 1.
      Action start 11:25:49: AllocateRegistrySpace.
      MSI (s) (2C:54) [11:25:49:010]: Doing action: ProcessComponents
      Action ended 11:25:49: AllocateRegistrySpace. Return value 1.
      MSI (s) (2C:54) [11:25:49:010]: Note: 1: 2205 2:  3: MsiPatchCertificate
      MSI (s) (2C:54) [11:25:49:010]: LUA patching is disabled: missing MsiPatchCertificate table
      MSI (s) (2C:54) [11:25:49:010]: Resolving source.
      MSI (s) (2C:54) [11:25:49:010]: Resolving source to launched-from source.
      MSI (s) (2C:54) [11:25:49:010]: Setting launched-from source as last-used.
      MSI (s) (2C:54) [11:25:49:010]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\'.
      MSI (s) (2C:54) [11:25:49:010]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\'.
      MSI (s) (2C:54) [11:25:49:010]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
      MSI (s) (2C:54) [11:25:49:010]: SOURCEDIR ==> C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\
      MSI (s) (2C:54) [11:25:49:010]: SOURCEDIR product ==> {92C34178-B679-4C83-AC33-7EFCE6D36E01}
      MSI (s) (2C:54) [11:25:49:012]: SECREPAIR: CryptAcquireContext succeeded
      MSI (s) (2C:54) [11:25:49:013]: Determining source type
      MSI (s) (2C:54) [11:25:49:022]: Source type from package 'install_flash_player_21_active_x.msi': 0
      MSI (s) (2C:54) [11:25:49:023]: SECREPAIR: Hash Database: C:\Windows\Installer\SourceHash{92C34178-B679-4C83-AC33-7EFCE6D36E01}
      MSI (s) (2C:54) [11:25:49:025]: Note: 1: 2262 2: SourceHash 3: -2147287038
      MSI (s) (2C:54) [11:25:49:029]: SECREPAIR: New Hash Database creation complete.
      MSI (s) (2C:54) [11:25:49:178]: SECREPAIR: Hash Value for the file:install_flash_player_21_active_x.msi is: 0/ufFSGsruc7SCIpoxxGYOM9faaJlYXZx4wGC4B6H5A=
      Action start 11:25:49: ProcessComponents.
      MSI (s) (2C:54) [11:25:49:183]: Source path resolution complete. Dumping Directory table...
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: TARGETDIR    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\    , LongSubPath:     , ShortSubPath:
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: USERPROFILE    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\UserProfile\    , LongSubPath: UserProfile\    , ShortSubPath: USERPR~1\
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: TempFolder    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\Temp\    , LongSubPath: Temp\    , ShortSubPath:
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: SystemFolder    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\System32\    , LongSubPath: System32\    , ShortSubPath:
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: MACROMED    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\System32\Macromed\    , LongSubPath: System32\Macromed\    , ShortSubPath:
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: FLASH    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\System32\Macromed\Flash\    , LongSubPath: System32\Macromed\Flash\    , ShortSubPath:
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: INSTALLDIR    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\System32\Macromed\Flash\    , LongSubPath: System32\Macromed\Flash\    , ShortSubPath:
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\Common\    , LongSubPath: Common\    , ShortSubPath:
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: ISCommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\Common\InstallShield\    , LongSubPath: Common\InstallShield\    , ShortSubPath: Common\Instal~1\
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: ISUpdateServiceFolder    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\Common\InstallShield\UpdateServi ce\    , LongSubPath: Common\InstallShield\UpdateService\    , ShortSubPath: Common\Instal~1\UPDATE~1\
      MSI (s) (2C:54) [11:25:49:183]: Dir (source): Key: ALLUSERSPROFILE    , Object: C:\Program Files (x86)\Common Files\enteo\RepositoryCache\237665\rev\1\Extern$\msidata\All Users\    , LongSubPath: All Users\    , ShortSubPath: ALLUSE~1\
      MSI (s) (2C:54) [11:25:49:188]: Doing action: UnpublishComponents
      Action ended 11:25:49: ProcessComponents. Return value 1.
      MSI (s) (2C:54) [11:25:49:189]: Note: 1: 2205 2:  3: PublishComponent
      MSI (s) (2C:54) [11:25:49:189]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
      Action start 11:25:49: UnpublishComponents.
      MSI (s) (2C:54) [11:25:49:189]: Doing action: MsiUnpublishAssemblies
      Action ended 11:25:49: UnpublishComponents. Return value 0.
      MSI (s) (2C:54) [11:25:49:190]: Note: 1: 2205 2:  3: MsiAssembly
      MSI (s) (2C:54) [11:25:49:190]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
      Action start 11:25:49: MsiUnpublishAssemblies.
      MSI (s) (2C:54) [11:25:49:190]: Doing action: UnpublishFeatures
      Action ended 11:25:49: MsiUnpublishAssemblies. Return value 0.
      Action start 11:25:49: UnpublishFeatures.
      MSI (s) (2C:54) [11:25:49:191]: Doing action: StopServices
      Action ended 11:25:49: UnpublishFeatures. Return value 1.
      MSI (s) (2C:54) [11:25:49:192]: Note: 1: 2205 2:  3: ServiceControl
      MSI (s) (2C:54) [11:25:49:192]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
      Action start 11:25:49: StopServices.
      MSI (s) (2C:54) [11:25:49:192]: Doing action: DeleteServices
      Action ended 11:25:49: StopServices. Return value 1.
      Action start 11:25:49: DeleteServices.
      MSI (s) (2C:54) [11:25:49:192]: Doing action: UnregisterComPlus
      Action ended 11:25:49: DeleteServices. Return value 1.
      MSI (s) (2C:54) [11:25:49:192]: Note: 1: 2205 2:  3: Complus
      MSI (s) (2C:54) [11:25:49:192]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
      Action start 11:25:49: UnregisterComPlus.
      MSI (s) (2C:54) [11:25:49:193]: Doing action: SelfUnregModules
      Action ended 11:25:49: UnregisterComPlus. Return value 0.
      MSI (s) (2C:54) [11:25:49:193]: Note: 1: 2205 2:  3: SelfReg
      MSI (s) (2C:54) [11:25:49:193]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
      Action start 11:25:49: SelfUnregModules.
      MSI (s) (2C:54) [11:25:49:193]: Doing action: UnregisterTypeLibraries
      Action ended 11:25:49: SelfUnregModules. Return value 1.
      MSI (s) (2C:54) [11:25:49:194]: Note: 1: 2205 2:  3: TypeLib
      MSI (s) (2C:54) [11:25:49:194]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
      Action start 11:25:49: UnregisterTypeLibraries.
      MSI (s) (2C:54) [11:25:49:195]: Doing action: RemoveODBC
      Action ended 11:25:49: UnregisterTypeLibraries. Return value 0.
      MSI (s) (2C:54) [11:25:49:195]: Note: 1: 2205 2:  3: ODBCDataSource
      MSI (s) (2C:54) [11:25:49:195]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
      MSI (s) (2C:54) [11:25:49:195]: Note: 1: 2205 2:  3: ODBCTranslator
      MSI (s) (2C:54) [11:25:49:195]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
      MSI (s) (2C:54) [11:25:49:195]: Note: 1: 2205 2:  3: ODBCDriver
      MSI (s) (2C:54) [11:25:49:195]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
      MSI (s) (2C:54) [11:25:49:195]: Note: 1: 2711 2: ODBCDriverManager
      Action start 11:25:49: RemoveODBC.
      MSI (s) (2C:54) [11:25:49:196]: Note: 1: 2711 2: ODBCDriverManager64
      MSI (s) (2C:54) [11:25:49:196]: Doing action: UnregisterFonts
      Action ended 11:25:49: RemoveODBC. Return value 1.
      MSI (s) (2C:54) [11:25:49:196]: Note: 1: 2205 2:  3: Font
      MSI (s) (2C:54) [11:25:49:196]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
      Action start 11:25:49: UnregisterFonts.
      MSI (s) (2C:54) [11:25:49:197]: Doing action: RemoveRegistryValues
      Action ended 11:25:49: UnregisterFonts. Return value 1.
      MSI (s) (2C:54) [11:25:49:197]: Note: 1: 2205 2:  3: Registry
      MSI (s) (2C:54) [11:25:49:197]: Note: 1: 2205 2:  3: RegAction
      MSI (s) (2C:54) [11:25:49:197]: Note: 1: 2228 2:  3: RegAction 4: SELECT `RegAction`.`BinaryType`,`Root`,`Key`,`Name`,`Value`, `Component_`, null, null, null, `Component`.`Attributes` FROM `RegAction`,`Component` WHERE `Component`=`Component_` AND (`RegAction`.`Action`=0 OR (`Root` = 0 AND (`RegAction`.`Action` = 11 OR `RegAction`.`Action` = 12))) ORDER BY `RegAction`.`BinaryType`, `Root`, `Key`
      Action start 11:25:49: RemoveRegistryValues.
      MSI (s) (2C:54) [11:25:49:197]: Doing action: UnregisterClassInfo
      Action ended 11:25:49: RemoveRegistryValues. Return value 1.
      MSI (s) (2C:54) [11:25:49:197]: Note: 1: 2205 2:  3: Class
      MSI (s) (2C:54) [11:25:49:197]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
      Action start 11:25:49: UnregisterClassInfo.
      MSI (s) (2C:54) [11:25:49:198]: Doing action: UnregisterExtensionInfo
      Action ended 11:25:49: UnregisterClassInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:198]: Note: 1: 2205 2:  3: Extension
      MSI (s) (2C:54) [11:25:49:198]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
      Action start 11:25:49: UnregisterExtensionInfo.
      MSI (s) (2C:54) [11:25:49:198]: Doing action: UnregisterProgIdInfo
      Action ended 11:25:49: UnregisterExtensionInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:198]: Note: 1: 2205 2:  3: ProgId
      MSI (s) (2C:54) [11:25:49:198]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
      Action start 11:25:49: UnregisterProgIdInfo.
      MSI (s) (2C:54) [11:25:49:199]: Doing action: UnregisterMIMEInfo
      Action ended 11:25:49: UnregisterProgIdInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:199]: Note: 1: 2205 2:  3: MIME
      MSI (s) (2C:54) [11:25:49:199]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
      Action start 11:25:49: UnregisterMIMEInfo.
      MSI (s) (2C:54) [11:25:49:199]: Doing action: RemoveIniValues
      Action ended 11:25:49: UnregisterMIMEInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:200]: Note: 1: 2205 2:  3: IniFile
      MSI (s) (2C:54) [11:25:49:200]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
      Action start 11:25:49: RemoveIniValues.
      MSI (s) (2C:54) [11:25:49:200]: Doing action: RemoveShortcuts
      Action ended 11:25:49: RemoveIniValues. Return value 1.
      MSI (s) (2C:54) [11:25:49:200]: Note: 1: 2205 2:  3: Shortcut
      MSI (s) (2C:54) [11:25:49:200]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
      Action start 11:25:49: RemoveShortcuts.
      MSI (s) (2C:54) [11:25:49:200]: Doing action: RemoveEnvironmentStrings
      Action ended 11:25:49: RemoveShortcuts. Return value 0.
      MSI (s) (2C:54) [11:25:49:201]: Note: 1: 2205 2:  3: Environment
      MSI (s) (2C:54) [11:25:49:201]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
      Action start 11:25:49: RemoveEnvironmentStrings.
      MSI (s) (2C:54) [11:25:49:201]: Doing action: RemoveDuplicateFiles
      Action ended 11:25:49: RemoveEnvironmentStrings. Return value 1.
      Action start 11:25:49: RemoveDuplicateFiles.
      MSI (s) (2C:54) [11:25:49:201]: Doing action: RemoveFolders
      Action ended 11:25:49: RemoveDuplicateFiles. Return value 1.
      Action start 11:25:49: RemoveFolders.
      MSI (s) (2C:54) [11:25:49:202]: Doing action: CreateFolders
      Action ended 11:25:49: RemoveFolders. Return value 1.
      Action start 11:25:49: CreateFolders.
      MSI (s) (2C:54) [11:25:49:202]: Doing action: MoveFiles
      Action ended 11:25:49: CreateFolders. Return value 1.
      Action start 11:25:49: MoveFiles.
      MSI (s) (2C:54) [11:25:49:203]: Doing action: InstallFiles
      Action ended 11:25:49: MoveFiles. Return value 1.
      MSI (s) (2C:54) [11:25:49:203]: Dumping binary patch manager data...
      MSI (s) (2C:54) [11:25:49:204]: The file represented by File table key 'InstallAX_21_0_0_182.exe' has no eligible binary patches
      MSI (s) (2C:54) [11:25:49:204]: Dumping binary patch manager data...
      Action start 11:25:49: InstallFiles.
      MSI (s) (2C:54) [11:25:49:204]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
      MSI (s) (2C:54) [11:25:49:204]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
      MSI (s) (2C:54) [11:25:49:205]: Note: 1: 2205 2:  3: MsiSFCBypass
      MSI (s) (2C:54) [11:25:49:205]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
      MSI (s) (2C:54) [11:25:49:205]: Note: 1: 2205 2:  3: MsiPatchHeaders
      MSI (s) (2C:54) [11:25:49:205]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
      MSI (s) (2C:54) [11:25:49:205]: Note: 1: 2205 2:  3: PatchPackage
      MSI (s) (2C:54) [11:25:49:207]: Doing action: NewCustomAction1
      Action ended 11:25:49: InstallFiles. Return value 1.
      Action start 11:25:49: NewCustomAction1.
      MSI (s) (2C:54) [11:25:49:209]: Doing action: PatchFiles
      Action ended 11:25:49: NewCustomAction1. Return value 1.
      Action start 11:25:49: PatchFiles.
      MSI (s) (2C:54) [11:25:49:210]: Doing action: DuplicateFiles
      Action ended 11:25:49: PatchFiles. Return value 1.
      Action start 11:25:49: DuplicateFiles.
      MSI (s) (2C:54) [11:25:49:211]: Doing action: BindImage
      Action ended 11:25:49: DuplicateFiles. Return value 1.
      Action start 11:25:49: BindImage.
      MSI (s) (2C:54) [11:25:49:211]: Doing action: CreateShortcuts
      Action ended 11:25:49: BindImage. Return value 1.
      Action start 11:25:49: CreateShortcuts.
      MSI (s) (2C:54) [11:25:49:215]: Note: 1: 2205 2:  3: Shortcut
      MSI (s) (2C:54) [11:25:49:215]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
      MSI (s) (2C:54) [11:25:49:215]: Doing action: RegisterClassInfo
      Action ended 11:25:49: CreateShortcuts. Return value 0.
      MSI (s) (2C:54) [11:25:49:215]: Note: 1: 2205 2:  3: Class
      MSI (s) (2C:54) [11:25:49:215]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
      Action start 11:25:49: RegisterClassInfo.
      MSI (s) (2C:54) [11:25:49:216]: Doing action: RegisterExtensionInfo
      Action ended 11:25:49: RegisterClassInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:217]: Note: 1: 2205 2:  3: Extension
      MSI (s) (2C:54) [11:25:49:217]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
      Action start 11:25:49: RegisterExtensionInfo.
      MSI (s) (2C:54) [11:25:49:217]: Doing action: RegisterProgIdInfo
      Action ended 11:25:49: RegisterExtensionInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:218]: Note: 1: 2205 2:  3: ProgId
      MSI (s) (2C:54) [11:25:49:218]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
      Action start 11:25:49: RegisterProgIdInfo.
      MSI (s) (2C:54) [11:25:49:218]: Doing action: RegisterMIMEInfo
      Action ended 11:25:49: RegisterProgIdInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:219]: Note: 1: 2205 2:  3: MIME
      MSI (s) (2C:54) [11:25:49:219]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
      Action start 11:25:49: RegisterMIMEInfo.
      MSI (s) (2C:54) [11:25:49:219]: Doing action: WriteRegistryValues
      Action ended 11:25:49: RegisterMIMEInfo. Return value 0.
      MSI (s) (2C:54) [11:25:49:220]: Note: 1: 2205 2:  3: Registry
      MSI (s) (2C:54) [11:25:49:220]: Note: 1: 2205 2:  3: RegAction
      MSI (s) (2C:54) [11:25:49:220]: Note: 1: 2228 2:  3: RegAction 4: SELECT `RegAction`.`BinaryType`,`Root`,`Key`,`Name`,`Value`, `Component_`, `Registry`, `RegAction`.`Action`, `RegAction`.`Attributes`, `Component`.`Attributes` FROM `RegAction`, `Component` WHERE `RegAction`.`Component_` = `Component` AND ((`RegAction`.`Action`=1 OR `RegAction`.`Action`=2) OR (`Root` = 0 AND `RegAction`.`Action` = null AND `RegAction`.`ActionRequest` = 1)) ORDER BY `RegAction`.`BinaryType`, `Root`, `Key`
      Action start 11:25:49: WriteRegistryValues.
      MSI (s) (2C:54) [11:25:49:220]: Doing action: WriteIniValues
      Action ended 11:25:49: WriteRegistryValues. Return value 1.
      MSI (s) (2C:54) [11:25:49:220]: Note: 1: 2205 2:  3: IniFile
      MSI (s) (2C:54) [11:25:49:220]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
      Action start 11:25:49: WriteIniValues.
      MSI (s) (2C:54) [11:25:49:220]: Doing action: WriteEnvironmentStrings
      Action ended 11:25:49: WriteIniValues. Return value 1.
      MSI (s) (2C:54) [11:25:49:221]: Note: 1: 2205 2:  3: Environment
      MSI (s) (2C:54) [11:25:49:221]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
      Action start 11:25:49: WriteEnvironmentStrings.
      MSI (s) (2C:54) [11:25:49:221]: Doing action: RegisterFonts
      Action ended 11:25:49: WriteEnvironmentStrings. Return value 1.
      MSI (s) (2C:54) [11:25:49:221]: Note: 1: 2205 2:  3: Font
      MSI (s) (2C:54) [11:25:49:221]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
      Action start 11:25:49: RegisterFonts.
      MSI (s) (2C:54) [11:25:49:221]: Doing action: InstallODBC
      Action ended 11:25:49: RegisterFonts. Return value 1.
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2711 2: ODBCDriverManager
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2711 2: ODBCDriverManager64
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2205 2:  3: ODBCDriver
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`, `Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2205 2:  3: ODBCTranslator
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileNam e`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2205 2:  3: ODBCDataSource
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
      Action start 11:25:49: InstallODBC.
      MSI (s) (2C:54) [11:25:49:222]: Doing action: RegisterTypeLibraries
      Action ended 11:25:49: InstallODBC. Return value 0.
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2205 2:  3: TypeLib
      MSI (s) (2C:54) [11:25:49:222]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
      Action start 11:25:49: RegisterTypeLibraries.
      MSI (s) (2C:54) [11:25:49:223]: Doing action: SelfRegModules
      Action ended 11:25:49: RegisterTypeLibraries. Return value 0.
      MSI (s) (2C:54) [11:25:49:223]: Note: 1: 2205 2:  3: SelfReg
      MSI (s) (2C:54) [11:25:49:223]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
      Action start 11:25:49: SelfRegModules.
      MSI (s) (2C:54) [11:25:49:223]: Doing action: RegisterComPlus
      Action ended 11:25:49: SelfRegModules. Return value 1.
      MSI (s) (2C:54) [11:25:49:224]: Note: 1: 2205 2:  3: Complus
      MSI (s) (2C:54) [11:25:49:224]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
      Action start 11:25:49: RegisterComPlus.
      MSI (s) (2C:54) [11:25:49:224]: Doing action: InstallServices
      Action ended 11:25:49: RegisterComPlus. Return value 0.
      MSI (s) (2C:54) [11:25:49:224]: Detected older ServiceInstall table schema
      MSI (s) (2C:54) [11:25:49:224]: Note: 1: 2205 2:  3: ServiceInstall
      MSI (s) (2C:54) [11:25:49:224]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrder Group`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Argume nts` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
      Action start 11:25:49: InstallServices.
      MSI (s) (2C:54) [11:25:49:224]: Doing action: MsiConfigureServices
      Action ended 11:25:49: InstallServices. Return value 1.
      MSI (s) (2C:54) [11:25:49:225]: Note: 1: 2205 2:  3: MsiServiceConfig
      MSI (s) (2C:54) [11:25:49:225]: Note: 1: 2228 2:  3: MsiServiceConfig 4: SELECT `Name`, `Event`, `ConfigType`, `Argument`, `Action` FROM `MsiServiceConfig`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 3)
      MSI (s) (2C:54) [11:25:49:225]: Note: 1: 2205 2:  3: MsiServiceConfigFailureActions
      MSI (s) (2C:54) [11:25:49:225]: Note: 1: 2228 2:  3: MsiServiceConfigFailureActions 4: SELECT `Name`, `Event`, `ResetPeriod`, `RebootMessage`,`Command`,  `Actions`, `DelayActions`, `Action` FROM `MsiServiceConfigFailureActions`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 3)
      Action start 11:25:49: MsiConfigureServices.
      MSI (s) (2C:54) [11:25:49:225]: Doing action: StartServices
      Action ended 11:25:49: MsiConfigureServices. Return value 1.
      MSI (s) (2C:54) [11:25:49:225]: Note: 1: 2205 2:  3: ServiceControl
      MSI (s) (2C:54) [11:25:49:225]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
      Action start 11:25:49: StartServices.
      MSI (s) (2C:54) [11:25:49:225]: Doing action: RegisterUser
      Action ended 11:25:49: StartServices. Return value 1.
      Action start 11:25:49: RegisterUser.
      MSI (s) (2C:54) [11:25:49:226]: Doing action: RegisterProduct
      Action ended 11:25:49: RegisterUser. Return value 1.
      Action start 11:25:49: RegisterProduct.
      MSI (s) (2C:54) [11:25:49:228]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
      MSI (s) (2C:54) [11:25:49:228]: Doing action: PublishComponents
      Action ended 11:25:49: RegisterProduct. Return value 1.
      MSI (s) (2C:54) [11:25:49:228]: Note: 1: 2205 2:  3: PublishComponent
      MSI (s) (2C:54) [11:25:49:228]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
      Action start 11:25:49: PublishComponents.
      MSI (s) (2C:54) [11:25:49:228]: Doing action: MsiPublishAssemblies
      Action ended 11:25:49: PublishComponents. Return value 0.
      MSI (s) (2C:54) [11:25:49:229]: Note: 1: 2205 2:  3: MsiAssembly
      MSI (s) (2C:54) [11:25:49:230]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
      Action start 11:25:49: MsiPublishAssemblies.
      MSI (s) (2C:54) [11:25:49:230]: Doing action: PublishFeatures
      Action ended 11:25:49: MsiPublishAssemblies. Return value 0.
      Action start 11:25:49: PublishFeatures.
      MSI (s) (2C:54) [11:25:49:232]: Doing action: PublishProduct
      Action ended 11:25:49: PublishFeatures. Return value 1.
      Action start 11:25:49: PublishProduct.
      MSI (s) (2C:54) [11:25:49:234]: Skipping action: ScheduleReboot (condition is false)
      MSI (s) (2C:54) [11:25:49:234]: Doing action: InstallFinalize
      Action ended 11:25:49: PublishProduct. Return value 1.
      MSI (s) (2C:54) [11:25:49:234]: Running Script: C:\Windows\Installer\MSIC1DD.tmp
      MSI (s) (2C:54) [11:25:49:234]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
      MSI (s) (2C:54) [11:25:49:238]: Machine policy value 'DisableRollback' is 0
      MSI (s) (2C:54) [11:25:49:244]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
      MSI (s) (2C:54) [11:25:49:246]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1215716153,LangId=1033,Platform=0,Scrip tType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
      Action start 11:25:49: InstallFinalize.
      MSI (s) (2C:54) [11:25:49:246]: Executing op: ProductInfo(ProductKey={92C34178-B679-4C83-AC33-7EFCE6D36E01},ProductName=Adobe Flash Player 21 ActiveX,PackageName=install_flash_player_21_active_x.msi,Language=1033,Version=352321536, Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={68B30DE0-0B6D-4EB9 -BFC0-D3DC88FF7A37},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFla gs=3)
      MSI (s) (2C:54) [11:25:49:247]: Executing op: DialogInfo(Type=0,Argument=1033)
      MSI (s) (2C:54) [11:25:49:247]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 21 ActiveX)
      MSI (s) (2C:54) [11:25:49:247]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
      MSI (s) (2C:54) [11:25:49:247]: Executing op: SetBaseline(Baseline=0,)
      MSI (s) (2C:54) [11:25:49:247]: Executing op: SetBaseline(Baseline=1,)
      MSI (s) (2C:54) [11:25:49:247]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
      MSI (s) (2C:54) [11:25:49:248]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
      MSI (s) (2C:54) [11:25:49:248]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},KeyPath=C:\Windows\S ysWOW64\Macromed\Flash\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
      MSI (s) (2C:54) [11:25:49:250]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},KeyPath=C:\Users\SVC COR~1.DSM\AppData\Local\Temp\InstallAX_21_0_0_182.exe,State=3,,Disk=1,SharedDllRefCount=1, BinaryType=0)
      MSI (s) (2C:54) [11:25:49:252]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
      MSI (s) (2C:54) [11:25:49:252]: Executing op: ODBCDriverManager(,BinaryType=0)
      MSI (s) (2C:54) [11:25:49:252]: Executing op: ODBCDriverManager(,BinaryType=1)
      MSI (s) (2C:54) [11:25:49:252]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
      MSI (s) (2C:54) [11:25:49:252]: Executing op: FolderCreate(Folder=C:\Windows\SysWOW64\Macromed\Flash\,Foreign=0,,)
      MSI (s) (2C:54) [11:25:49:253]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
      MSI (s) (2C:54) [11:25:49:253]: Executing op: ProgressTotal(Total=19377344,Type=0,ByteEquivalent=1)
      MSI (s) (2C:54) [11:25:49:253]: Executing op: SetTargetFolder(Folder=C:\Users\SVCCOR~1.DSM\AppData\Local\Temp\)
      MSI (s) (2C:54) [11:25:49:253]: Executing op: SetSourceFolder(Folder=1\Temp\)
      MSI (s) (2C:54) [11:25:49:253]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\Windows\Instal ler\b6bf4c.msi,,,,,IsFirstPhysicalMedia=1)
      MSI (s) (2C:54) [11:25:49:253]: Executing op: FileCopy(SourceName=FP_AX_~1.EXE|InstallAX_21_0_0_182.exe,SourceCabKey=InstallAX_21_0_0_1 82.exe,DestName=InstallAX_21_0_0_182.exe,Attributes=16384,FileSize=19377344,PerTick=65536, ,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.0.0.0,Language=1033,InstallMode=58982400,,,,,, ,)
      MSI (s) (2C:54) [11:25:49:255]: File: C:\Users\SVCCOR~1.DSM\AppData\Local\Temp\InstallAX_21_0_0_182.exe;    To be installed;    Won't patch;    No existing file
      MSI (s) (2C:54) [11:25:49:255]: Source for file 'InstallAX_21_0_0_182.exe' is compressed
      MSI (s) (2C:54) [11:25:49:498]: Executing op: CacheSizeFlush(,)
      MSI (s) (2C:54) [11:25:49:498]: Executing op: ActionStart(Name=NewCustomAction1,,)
      MSI (s) (2C:54) [11:25:49:501]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C:\Users\SVCCOR~1.DSM \AppData\Local\Temp\InstallAX_21_0_0_182.exe,Target=-install -msi -prev 0,)
      Installation is done with elevated rights.
      Is there a chance to fix the msi or the uninstaller to allow a working installation?
      The number of problematic machines is currently increasing.
        • 1. Re: Deployment of flashplayer msi failed with timeout
          maria__ Adobe Employee
          What is the exact command-line argument you are using to deploy the MSI?
          Please provide the FlashInstall.log file from an impacted system.  On a 64-bit OS there are two files saved at C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash.  Both files are required.  They most likely well be very large to post here, as such you can upload them to cloud.acrobat.com using the instructions at The specified item was not found. and post the link to the uploaded files in your reply.
          Thank you.
          Maria
          • 2. Re: Deployment of flashplayer msi failed with timeout
            3zzz Level 1
            Hello,
            sorry for my delayed answer. As already mentioned the deployment system is DSM 2015.1 by Frontrange.
            My used command line is:
            %WINSYSDIR%\msiexec.exe /i ".\Extern$\msidata\install_flash_player_21_active_x.msi" REBOOT=ReallySuppress /qn /l*vx "%LogFileSettings.LogFilePath%\%Project.Name%_inst.log"
            This will be transformed to:
            C:\Windows\system32\msiexec.exe /i "C:\Program Files (x86)\Common Files\enteo\RepositoryCache\240688\rev\1\Extern$\msidata\install_flash_player_21_plugin.m si" REBOOT=ReallySuppress /qn /l*vx "C:\Program Files (x86)\Common Files\enteo\NiLogs\Adobe Flash Player Plugin 21.0.0.213_EN_inst.log"
            The logfile show this command line (this modification is done because of process tracking, built in in DSM):
            C:\Windows\system32\msiexec.exe /i "C:\Program Files (x86)\Common Files\enteo\RepositoryCache\240688\rev\1\Extern$\msidata\install_flash_player_21_plugin.m si" REBOOT=ReallySuppress /qn /l*vx "C:\Program Files (x86)\Common Files\enteo\NiLogs\Adobe Flash Player Plugin 21.0.0.213_EN_inst.log" CURRENTDIRECTORY=C:\Windows\system32 CLIENTUILEVEL=3 CLIENTPROCESSID=6648
            These are the requested flashinstall.log logfiles from one corrupt machine:
            System32: https://files.acrobat.com/a/preview/643072cc-f69c-47d6-9c39-0a6103c3446f
            Syswow64: https://files.acrobat.com/a/preview/f968a90f-9fec-4fda-9b73-e1873738a2cf
            The timeout problem is best described so:
            The above mentioned command will be executed and the deployment system wait about (in this case) 30 minutes to finish the installation and a process end. If the installation takes longer than 30 minutes, a timeout is triggered. Currently there is no process termination, so the processes are running until next reboot. If the installation will rerun later again without reboot, the install processes are still running.
            I try to update the first post with the logfile and try to move it to acrobat cloud, too.
            Best regards,
            3zzz
            • 3. Re: Deployment of flashplayer msi failed with timeout
              Sorry for the late reply.
              You provided a MSI verbose log file for an ActiveX installation attempt, however the FlashInstall.log file appears to be fro a NPAPI plugin installation attempt.  Since they don't appear to be from the same installation attempt, it's difficult to troubleshoot.
              Please provide the 3 log files for the same installation attempt.
              Thank you.
              Maria
              • 4. Re: Deployment of flashplayer msi failed with timeout
                3zzz Level 1
                Once again a very long time between the posts. Sorry for that.
                Now I hope all required files are collected.
                https://files.acrobat.com/a/preview/e16849af-ca23-4456-af1d-b588ad218177
                • 5. Re: Deployment of flashplayer msi failed with timeout
                  3zzz Level 1
                  Any news about the topic?@
