• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Preliminary experience
New Here ,
Mar 22, 2016 Mar 22, 2016
Do I need to have any programming experience before working with Cold Fusion? If yes, what programming languages do I have to know? Thank you!)
Views
333
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate , Mar 22, 2016 Mar 22, 2016
Learn CF in a Week‌ is a good place to start for Coldfusion.
There are plenty of resources available for HTML. Try having a look on Google for HTML , CSS and Javascript resources as you will probably need a grasp of all of these.
Votes
Translate
Translate
Advocate ,
Experience in CFML would be handy. You don't technically need any previous experience in any language although general experience in programming helps you with the concept. Do you at least know / understand the concept of HTML?
Votes
Translate
Translate
Report
Report
New Here ,
Thank you!!) Unfortunately no, I am a beginner, but I want to make first step in learning how to create web-apps. Just need to understand from where to begin.
Votes
Translate
Translate
Report
Report
Advocate ,
Votes
Translate
Translate
Report
Report
LEGEND ,
The difference between most programming/developing languages is syntax.  Most languages are based upon C; but this should not be considered a reason to learn C.
If you learn one language, then you also learn the logic.  The logic is 99% the same across all languages.  This makes it easier to learn the syntax of other languages.
Also, CF is commonly coded using CF tags, but you can also write code in CFSCRIPT that looks a lot like JavaScript or Perl (semi-colons are important!)
So, to answer your question, there is no specific language that will help you with CF other than CFML.  But, as haxtbh‌ pointed out, a solid grasp of HTML is very beneficial.
HTH,
^_^
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thank you very much!!
Votes
Translate
Translate
Report
Report
Resources
Documentation
