12 Replies Latest reply on Mar 22, 2016 3:17 PM by Obi-wan Kenobi
    Path of a sub-folder in the script panel…
    Obi-wan Kenobi Level 5
      I've a script called "XXX.jsx" placed into a sub-folder called "YYY" itself placed in the ID "Scripts Panel" folder.
      In the "YYY" sub-folder, I have a .txt file called "XXX_List1.txt" beside the "XXX.jsx" file.
      I would like to make reference to the "XXX_List1.txt" file in the "XXX.jsx" file!
      Thanks in advance!
        • 1. Re: Path of a sub-folder in the script panel…
          I've tried this … and alas! it doesn't work:
          textFile = File (script_dir() + '/List1.txt');
          • 2. Re: Path of a sub-folder in the script panel…
            pixxxel schubser MVP & Adobe Community Professional
            Hi Obi,
            only make a reference? Or something else?
            Save this snippet in your folder "YYY" and run the script from ESTK or ID
            var txt = "XXX_List1.txt";
            myFile = File(File($.fileName).parent.fullName + "/" + txt);
            if(myFile.open() == true) { //this only should show some possibilities - better use: if myFile.exists
                myFile.execute();
            } else {
                alert (decodeURI(myFile) + " not found");
            Have fun
            • 3. Re: Path of a sub-folder in the script panel…
              Loic.Aigon Adobe Community Professional
              Hi Obi,
              You may be interested in activeScript property of the application:
              activeScriptFilereadonlyThe current script running from the Scripts panel.
              var txtFile  = File ( Folder ( app.activeScript.parent )+"/YYY/XXX_List1.txt" );
              alert ( txtFile.exists );
              HTH,
              Loïc
              Ozalto | Productivity Oriented - Loïc Aigon
              • 4. Re: Path of a sub-folder in the script panel…
                Thanks all 2!
                I continue on the script but it doesn't work:
                myTextFile = File(File($.fileName).parent.fullName + "/List1.txt");
                if(myTextFile.open() == true) {
                    myTextFile.execute();
                } else {
                    alert (decodeURI(myTextFile) + " not found");
                myWord = myTextFile.read();
                myTextFile.close();
                myWord = myWord.split("\n");
                app.findGrepPreferences = app.changeGrepPreferences = null;
                app.changeGrepPreferences.appliedCharacterStyle = app.activeDocument.characterStyles.item("Cap_Blue");
                while (myWord.length > 0)
                app.findGrepPreferences.findWhat = myWord.pop();
                app.activeDocument.changeGrep();
                Apparently, the List1.txt is open but not close after!
                The script doesn't catch data!    [Grrrrrr!!]
                • 5. Re: Path of a sub-folder in the script panel…
                  Make slowly and step by step.
                  No master is falling from the sky.
                  var myTextFile = File(File($.fileName).parent.fullName + "/List1.txt");
                  if(myTextFile.exists) {
                      myTextFile.open();
                      var myWord = myTextFile.read();
                      alert(myWord)
                      myTextFile.close();
                      while (myWord.length > 0) {
                  } else {
                  • 6. Re: Path of a sub-folder in the script panel…
                    Aha!  Thank you to join me in the sandbox!
                    Now, with your answer, I get the list with commas!
                    … So, normally, this could work!
                        myTextFile.open();
                        myTextFile.close();
                    } else {
                    But I have an error on this line:
                    Tired!
                    • 7. Re: Path of a sub-folder in the script panel…
                      Today it's not a sandbox - it's a classroom.
                      pop() will reduce your array myWord by one and
                          alert(myWord.pop());
                      What is the content of your text file?
                      Do you have an example IDML and an example List1.txt for us?
                      findWhat needs the parts of the Array
                      I prefer:
                          myTextFile.open();
                          alert(myWord)
                          myTextFile.close();
                          for (i=0; i<myWord.length; i++) {
                              alert(i + " " + myWord[i]);
                      } else {
                      • 8. Re: Path of a sub-folder in the script panel…
                        Pixxxel,
                        Gotcha!
                            myTextFile.open();
                            myTextFile.close();
                            app.changeGrepPreferences.appliedCharacterStyle = app.activeDocument.characterStyles.item("xx");
                                app.findGrepPreferences.findWhat = "\\b"+myWord.pop()+"\\b";
                        } else {
                        A last question: How do you do to have your code view as in your last post?
                        • 9. Re: Path of a sub-folder in the script panel…
                          click in the answer window in the right corner on --> extended editor (hope this is the correct name in english) and than:
                          And yes findWhat always need a grep syntax.
                          • 10. Re: Path of a sub-folder in the script panel…
                            Cool! Thanks a lot Pixxxel [for all]!
                                myTextFile.open();
                                myTextFile.close();
                            } else {
