2 Replies Latest reply on Mar 23, 2016 9:06 AM by jbowden
    Remove target
    graphix_101
      Is there a way to remove a target once i defined it in the app? At the Moment i have to delete the item :/
        • 1. Re: Remove target
          elainecc Adobe Employee
          Yes! You can drag either the wire's start or end point. The only exception is if there are two start points for one end point; in that case, you'll only be able to drag the start point.
          • 2. Re: Remove target
            jbowden Adobe Employee
            Hi Christian,
            We're working on making this workflow more intuitive, but for now to remove a target, simply drag and drop the connector from the targeted artboard to the pasteboard (gray background outside of artboards) to totally disconnect the link.
            To link to another artboard instead, just directly drag and drop the connector to the artboard you want to link.
            hth,
            Joe
