8 Replies Latest reply on Dec 17, 2017 11:25 PM by ramonhsea1975
    Can you add LUTS to Premiere Elements? If so, how?
    alister24 Level 1
      I know you can do it in Premiere Pro, but is it available to do in Elements?
        • 1. Re: Can you add LUTS to Premiere Elements? If so, how?
          whsprague Adobe Community Professional
          You have not recieved an answer yet.  I've not used LUTS anywhere.  In my use of Premier Elements for a few years, I've not seen where it can be done.  However, there are color correction tools where you can adjust one clip and paste the adjustment to the rest of the clips on the timeline.
          Only recently have consumer cameras like the Sony RX100iv and Sony RX10ii had provisions for log profile shooting.  It will be interesting how that works into consumer NLE software.
          • 2. Re: Can you add LUTS to Premiere Elements? If so, how?
            jefrs Level 1
            I am also looking for a solution to this. Pro cameras like the Panasonic GH4 have V-Log which require LUT correction but Premiere Pro costs an arm and a leg. I am looking for a less expensive solution. I cannot see any way to utilise a LUT plugin in Premiere Elements. However to normalise audio, Adobe do point us at Premiere Pro, yet Premiere Elements can do it easily, cunning.
            • 3. Re: Can you add LUTS to Premiere Elements? If so, how?
              wineandine Level 1
              Hi, I am using Magic Bullet and it has LUT Buddy that can be used to install some luts. Don't know if your lut will install, but give it a try. It's FREE. I used a lut for my drone footage.
              2 people found this helpful
              • 4. Re: Can you add LUTS to Premiere Elements? If so, how?
                anelson316 Level 1
                Yea but again this what you mentioned.. is for the pro version's! I went to the site and LUT buddy is only compatible with after effects cc and premier pro cc, The question was if any LUTS can be added into the consumer version, such as premier elements, I'm having a similar issue but not the the video editor, but the Photoshop elements . I want colour preset's in that one, but no where to be found!!  Except if you buy this elements+ software, but I don't have tons more money to throw around!! Want a quick free fix!
                • 5. Re: Can you add LUTS to Premiere Elements? If so, how?
                  I have never seen or heard of LUTS being used in either Premiere Elements or Photoshop Elements.  "elements+" is not Adobe software and has mixed reviews.
                  • 6. Re: Can you add LUTS to Premiere Elements? If so, how?
                    rickf779 Level 1
                    Yes, you can use LUTs in Premiere Elements.  Go to www.logarist.com and follow the instructions.
                    Of course, without a waveform monitor and vectorscope in P-Elements, it can be a challenge to get the levels correct.
                    • 7. Re: Can you add LUTS to Premiere Elements? If so, how?
                      Robert J. Johnston Level 3
                      I installed the The Magic Bullet LUT Buddy from Red Giant today for use with Premiere Elements, using the After Effects option.  When Premiere Elements starts up, it scans the directory in which LUT Buddy is installed, such as C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore. There's a log file that shows this. Lut Buddy shows up in my Premiere Elements 11, 15, and 2018. With the new versions of Premiere Elements, you can use an adjustment layer for the LUT Buddy plug-in and set the opacity of the Adjustment Layer to modify the strength.
                      I found that .3DL lut files from Adobe Photoshop work okay, but .cube files don't. If you have Adobe Photoshop, you can convert from .cube to .3DL.
                      The plug-in is not completely compatible with Premiere Elements, such as if you Render a Preview, then changing the lut file in the Buddy settings does not delete the rendered preview -- there is still a green line. Also, you won't necessarily see the results of applying the plug-in until you scrub or render a preview.
                      You can try creating a LUT file with the LUT Buddy, but after reading the instructions -- which are for After Effects -- I wasn't sure how to do the same in Premiere Elements. I just stuck with the basic loading of an existing lut file in the Buddy settings  (cog wheel icon).
                      • 8. Re: Can you add LUTS to Premiere Elements? If so, how?
                        ramonhsea1975 Level 1
                        This does work and its a really good solution
