3 Replies Latest reply on Apr 29, 2016 2:10 AM by Piyush Nayak
    ACF 2016 WAR Deployment Tomcat server did not start
    MadAqua Level 1
      Hi, i need some help.
      First the environment:
      OS: Centos 6.7 latest
      ACF: 2016 64bit Linux war deployment
      Tomcat : 8.0.32
      Java Version :
      openjdk version "1.8.0_71"
      OpenJDK Runtime Environment (build 1.8.0_71-b15)
      OpenJDK 64-Bit Server VM (build 25.71-b15, mixed mode)
      After i deploy the war file the server did not start.
      Here are some more information (catalinalog):
      23-Mar-2016 18:32:20.035 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version:    Apache Tomcat/8.0.32
      23-Mar-2016 18:32:20.036 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:      Feb 2 2016 19:34:53 UTC
      23-Mar-2016 18:32:20.036 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number:     8.0.32.0
      23-Mar-2016 18:32:20.036 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name:           Linux
      23-Mar-2016 18:32:20.036 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version:        2.6.32-573.18.1.el6.x86_64
      23-Mar-2016 18:32:20.036 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture:      amd64
      23-Mar-2016 18:32:20.036 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home:         /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.71-1.b15.el6_7.x86_64/jre
      23-Mar-2016 18:32:20.036 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:       1.8.0_71-b15
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:        Oracle Corporation
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:     /opt/tomcat8
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:     /opt/tomcat8
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/opt/tomcat8/conf/logging.properties
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dnet.sf.ehcache.skipUpdateCheck=true
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseConcMarkSweepGC
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+CMSClassUnloadingEnabled
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseParNewGC
      23-Mar-2016 18:32:20.037 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms512m
      23-Mar-2016 18:32:20.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
      23-Mar-2016 18:32:20.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=/opt/tomcat8/endorsed
      23-Mar-2016 18:32:20.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/opt/tomcat8
      23-Mar-2016 18:32:20.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/opt/tomcat8
      23-Mar-2016 18:32:20.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/opt/tomcat8/temp
      23-Mar-2016 18:32:20.038 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
      23-Mar-2016 18:32:20.095 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8180"]
      23-Mar-2016 18:32:20.106 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
      23-Mar-2016 18:32:20.108 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
      23-Mar-2016 18:32:20.109 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
      23-Mar-2016 18:32:20.110 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 354 ms
      23-Mar-2016 18:32:20.128 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
      23-Mar-2016 18:32:20.128 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.32
      23-Mar-2016 18:32:20.148 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive /opt/tomcat8/webapps/cfusion.war
      23-Mar-2016 18:32:20.672 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
      23-Mar-2016 18:33:23.690 INFO [localhost-startStop-1] org.apache.catalina.util.SessionIdGeneratorBase.createSecureRandom Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [63,009] milliseconds.
      When i remove the war file the server starts normal.
