4 Replies Latest reply on Jan 22, 2010 8:56 AM by EspinosaCZ
    Can't install 1.5 on opensuse 11.0
    JDArnold123
      I can't seem to install the new, official AIR 1.5 on my 32bit openSUSE 11.0 system. When I run the installer as root, I get:
      Error loading the runtime (libadobecertstore.so: cannot open shared object file: No such file or directory)
      Any ideas on why libadobecertstore.so is missing?
        • 1. Re: Can't install 1.5 on opensuse 11.0
          Cesare Rocchi Level 2
          I have no idea.
          In any case Linux versions supported are: Fedora Core 8, Ubuntu 7.10, openSUSE 10.3
          (as reported here http://www.adobe.com/products/air/systemreqs/)
          Hope this helps.
          • 2. Re: Can't install 1.5 on opensuse 11.0
            funktion_lkjd
            Does /usr/lib/libadobecertstore.so exist?
            • 3. Re: Can't install 1.5 on opensuse 11.0
              Try running ldconfig as root. It found the library after I did that.
              • 4. Re: Can't install 1.5 on opensuse 11.0
                EspinosaCZ
                I have to report the same issue in Mandriva 2009.1
                $ ./AdobeAIRInstaller.bin
                There is no such library as libadobecertstore.so in my system. Not in /usr/lib, not anywhere.
                The libadobecertstore.so it sounds like something to be installed with the installer, something from Adobe, something not ot expected in the target system.
                $ strace ./AdobeAIRInstaller.bin
                rmdir("/tmp/air.honJJG/build/opt/Adobe AIR/Versions/1.0/Resources") = 0
                stat64("/tmp/air.honJJG/build/opt/Adobe AIR/Versions/1.0/libCore.so", {st_mode=S_IFREG|0775, st_size=10724968, ...}) = 0
                unlink("/tmp/air.honJJG/build/opt/Adobe AIR/Versions/1.0/libCore.so") = 0
                getdents(7, /* 0 entries */, 4096)      = 0
                rmdir("/tmp/air.honJJG/build/opt/Adobe AIR/Versions/1.0") = 0
                getdents(6, /* 0 entries */, 4096)      = 0
                rmdir("/tmp/air.honJJG/build/opt/Adobe AIR/Versions") = 0
                getdents(5, /* 0 entries */, 4096)      = 0
                rmdir("/tmp/air.honJJG/build/opt/Adobe AIR") = 0
                getdents(4, /* 0 entries */, 4096)      = 0
                rmdir("/tmp/air.honJJG/build/opt")      = 0
                getdents(3, /* 0 entries */, 4096)      = 0
                rmdir("/tmp/air.honJJG/build")          = 0
                stat64("/tmp/air.honJJG/Certs/usr/bin", 0xbfc9c44c) = -1 ENOENT (No such file or directory)
                stat64("/tmp/air.honJJG/Certs/etc", 0xbfc9c44c) = -1 ENOENT (No such file or directory)
                open("/tmp/air.honJJG", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 9
                fstat64(9, {st_mode=S_IFDIR|0700, st_size=4096, ...}) = 0
                getdents(9, /* 2 entries */, 4096)      = 32
                getdents(9, /* 0 entries */, 4096)      = 0
                rmdir("/tmp/air.honJJG")                = 0
                exit_group(1)                           = ?
