7 Replies Latest reply on Mar 24, 2016 6:45 AM by smithcgl9043167
    Add mask on all selected layers.
    smithcgl9043167 Level 2
      Hello guys! I'm here looking for a script that adds mask on all selected layers.
        • 2. Re: Add mask on all selected layers.
          From what I understand, the post you showed me is to másscars creates layered levels, it is not what I'm looking for. Thanks for the attention!
          • 3. Re: Add mask on all selected layers.
            SuperMerlin Level 5
            Please try this.
            #target photoshop;
            app.bringToFront();
            if(documents.length) main();
            function main(){
            var selectedlayers = getSelectedLayersIdx();
            selectedlayers.reverse();
            for(var z in selectedlayers){
                selectLayerByIndex(selectedlayers[z]);
                selectLayerData();
            app.activeDocument.selection.deselect();
            for(var a in selectedlayers) {selectLayerByIndex(selectedlayers[a],true);}
            function getSelectedLayersIdx(){
                  var selectedLayers = new Array;
                  var ref = new ActionReference();
                  ref.putProperty(charIDToTypeID('Prpr'), stringIDToTypeID('targetLayers'));
                  ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                  var desc = executeActionGet(ref);
                  if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                     desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                      var c = desc.count;
                      var selectedLayers = new Array();
                      for(var i=0;i<c;i++){
                        try{
                           activeDocument.backgroundLayer;
                           selectedLayers.push(  desc.getReference( i ).getIndex() );
                        }catch(e){
                           selectedLayers.push(  desc.getReference( i ).getIndex()+1 );
                   }else{
                     ref.putProperty( charIDToTypeID('Prpr') , charIDToTypeID( 'ItmI' ));
                     ref.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                     try{
                        selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( 'ItmI' ))-1);
                     }catch(e){
                        selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( 'ItmI' )));
                 var vis = app.activeDocument.activeLayer.visible;
                    if(vis == true) app.activeDocument.activeLayer.visible = false;
                    var desc9 = new ActionDescriptor();
                var list9 = new ActionList();
                var ref9 = new ActionReference();
                ref9.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                list9.putReference( ref9 );
                desc9.putList( charIDToTypeID('null'), list9 );
                executeAction( charIDToTypeID('Shw '), desc9, DialogModes.NO );
                if(app.activeDocument.activeLayer.visible == false) selectedLayers.shift();
                    app.activeDocument.activeLayer.visible = vis;
                  return selectedLayers;
            function selectLayerByIndex(index,add){
            ref.putIndex(charIDToTypeID('Lyr '), index);
            var desc = new ActionDescriptor();
            desc.putReference(charIDToTypeID('null'), ref );
            if(add) desc.putEnumerated( stringIDToTypeID( 'selectionModifier' ), stringIDToTypeID( 'selectionModifierType' ), stringIDToTypeID( 'addToSelection' ) );
            desc.putBoolean( charIDToTypeID( 'MkVs' ), false );
            try{
            executeAction(charIDToTypeID('slct'), desc, DialogModes.NO );
            }catch(e){}
            function createMask() {
            var desc13 = new ActionDescriptor();
            desc13.putClass( charIDToTypeID('Nw  '), charIDToTypeID('Chnl') );
            var ref12 = new ActionReference();
            ref12.putEnumerated( charIDToTypeID('Chnl'), charIDToTypeID('Chnl'), charIDToTypeID('Msk ') );
            desc13.putReference( charIDToTypeID('At  '), ref12 );
            desc13.putEnumerated( charIDToTypeID('Usng'), charIDToTypeID('UsrM'), charIDToTypeID('RvlS') );
            executeAction( charIDToTypeID('Mk  '), desc13, DialogModes.NO );
            function selectLayerData() {
            var desc8 = new ActionDescriptor();
            var ref6 = new ActionReference();
            ref6.putProperty( charIDToTypeID('Chnl'), charIDToTypeID('fsel') );
            desc8.putReference( charIDToTypeID('null'), ref6 );
            var ref7 = new ActionReference();
            ref7.putEnumerated( charIDToTypeID('Chnl'), charIDToTypeID('Chnl'), charIDToTypeID('Trsp') );
            desc8.putReference( charIDToTypeID('T   '), ref7 );
            executeAction( charIDToTypeID('setd'), desc8, DialogModes.NO );
            • 4. Re: Add mask on all selected layers.
              SuperMerlin, I tested the code here and nothing changed ... The layers remain the same. Thank skin helps!
              • 5. Re: Add mask on all selected layers.
                SuperMerlin Level 5
                It was writtem and tested with CS6, and the layers need to be selected.
                • 6. Re: Add mask on all selected layers.
                  SuperMerlin Level 5
                  sorry I found i had made an alteration, this should work now.
                  #target photoshop;
                  app.bringToFront();
                  function main(){
                      selectLayerData();
                       createMask();
                            var c = desc.count;
                              try{
                              }catch(e){
                         }else{
                           try{
                           }catch(e){
                  try{
                  }catch(e){}
                  • 7. Re: Add mask on all selected layers.
                    Now yes it is working perfectly !!!. Months looking for this on the internet and here in the forum in less than 24 hours I found the correct answer.
                    Very sheltered SuperMerlin.
