7 Replies Latest reply on Mar 25, 2016 11:49 AM by MW Design
    xml import runs hours - never get finished
    enzephalon
      Hello
      I try to import XML file with XSLT-transformation. It works for a XML-file with around 200 nodes.
      But if I try to import XML-file with around 3000 nodes, the application runs endlessly (more then 8 hours till I killed InDesign) at "Bearbeitung nach Import" (in english I think it's "processing after import"). I've made a screenshot indesign_lags_import_xml.jpg
      I use MacBookPro with 16GB of RAM and 2,5GHz i7 - that has to be enough for this!
      This is one node (and the beginning) from my XML-file:
      <?xml version="1.0" encoding="iso-8859-1" standalone="yes"?>
      <kategorie>
      <artikel><ARTIKELNR>214565</ARTIKELNR><BEZEICHNUNG><![CDATA[(DOLCH) - I & II DigiCD]]></BEZEICHNUNG><TEXT><![CDATA[mysteriöser & avantgardistischer blackmetal für fans von URFAUST ]]></TEXT><VK1BRUTTO>12,99 €</VK1BRUTTO></artikel>
      And this is my XSLT-file:
      <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:aid="http://ns.adobe.com/AdobeInDesign/4.0/" xmlns:aid5="http://ns.adobe.com/AdobeInDesign/5.0/">
      <xsl:output method="xml" version="1.0" encoding="ISO-8859-1" indent="yes"/>
      <xsl:template match="/kategorie">
          <Produkte>
           <Tabelle aid:table="table" aid:tcols="3" aid:trows="{count(artikel) + count(artikel/TEXT[text()])}" xmlns:aid="http://ns.adobe.com/AdobeInDesign/4.0/" xmlns:aid5="http://ns.adobe.com/AdobeInDesign/5.0/">
               <xsl:for-each select="artikel">
                   <cell aid:table="cell" aid:ccolwidth="25.30" aid:pstyle="abs_Produkt_Artikelnummer" aid:cstyle="zei_Produkt_Artikelnummer" aid5:cellstyle="zel_Produkt_Artikelnummer" >
                       <xsl:value-of select="normalize-space(ARTIKELNR)"/>
                   </cell>
                   <cell aid:table="cell" aid:ccolwidth="136.76" aid:pstyle="abs_Produkt_Bezeichnung" aid:cstyle="zei_Produkt_Bezeichnung" aid5:cellstyle="zel_Produkt_Bezeichnung">
                       <xsl:value-of select="BEZEICHNUNG"/>
                   </cell>
                   <cell aid:table="cell" aid:ccolwidth="21.55" aid:pstyle="abs_Produkt_VKBrutto" aid:cstyle="zei_Produkt_VKBrutto" aid5:cellstyle="zel_Produkt_VKBrutto">
                       <xsl:value-of select="substring(VK1BRUTTO, 0, string-length(VK1BRUTTO)-1)"/>
                   </cell>
                   <xsl:if test="TEXT/text()">
                       <cell aid:table="cell" aid:ccolwidth="25.30" aid:cstyle="zei_Produkt" aid5:cellstyle="zel_Produkt"></cell>
                       <cell aid:table="cell" aid:ccolwidth="158.31" aid:ccols="2" aid:pstyle="abs_Produkt_Beschreibung" aid:cstyle="zei_Produkt_Beschreibung" aid5:cellstyle="zel_Produkt_Beschreibung">
                           <xsl:value-of select="TEXT"/>
                            <xsl:if test="FREIFELD2/text()">
                            Lieferbare Größen: <xsl:value-of select="FREIFELD2"/>
                            </xsl:if>
                       </cell>
                   </xsl:if>
               </xsl:for-each>
           </Tabelle>
        </Produkte>
      </xsl:template>
      </xsl:stylesheet>
      Now I'm in trouble, cause the import must be done today! Can anybody help me with this issue, please?
      best regards
      Johannes
        • 1. Re: xml import runs hours - never get finished
          Prithivi_Prepress Level 1
          Check that is there any text gone to overset when you import the XML file, add few additional pages. And check for longest word in content.
          • 2. Re: xml import runs hours - never get finished
            enzephalon Level 1
            A little update.
            My Import works for max 250-300 nodes. If I try to import 800 or 3000 nodes, the import will freeze at "processing after import" and thats it :-( .
            But I do not like to cut my XML into pieces - not to 12 files - if I have 3000 nodes (12 * 250 = 3000). This can't be the solution.
            Hey Adobe, what should I do?
            best regards
            Johannes
            • 3. Re: xml import runs hours - never get finished
              MW Design Level 5
              I didn't try a super large file, but I did replicate your little sample to 1350 nodes and it imported in about 8 minutes or so.
              But there are some issues with your sample and xslt. One, the Euro is not supported using the ISO encoding you are using. Use UTF-16. So I altered the xslt for that. Also, the price element will simply drop off the Euro anyway with the substring. So I also removed that and used the proper means of using it.
              Oh, I also widen the number and the price cells a bit. It imported fine.
              If you still need help, give a shout in the thread. I just got out of the hospital and so if I don't get back to the thread, send me a PM--I have notifications for threads shut off, but the PM will hit my email.
              Mike
              • 4. Re: xml import runs hours - never get finished
                enzephalon Level 1
                Hey Mike
                Thanks for your reply.
                After some adjustments, I was able to import a XML-file with 806 nodes. Took 15 minutes or so.
                Happy about that, I now try to import the 3000-nodes file. This import stands still like described above.
                My new XLST is
                <xsl:output method="xml" version="1.0" encoding="utf-8" indent="yes"/>
                    <CDs>
                            <cell aid:table="cell" aid:ccolwidth="25.30" aid:pstyle="abs_Produkt_Artikelnummer" aid5:cellstyle="zel_Produkt_Artikelnummer" >
                            </cell>
                            <cell aid:table="cell" aid:ccolwidth="136.76" aid:pstyle="abs_Produkt_Bezeichnung" aid5:cellstyle="zel_Produkt_Bezeichnung">
                            </cell>
                            <cell aid:table="cell" aid:ccolwidth="21.55" aid:pstyle="abs_Produkt_VKBrutto" aid5:cellstyle="zel_Produkt_VKBrutto">
                                <xsl:value-of select="VK1BRUTTO"/>
                            </cell>
                                <cell aid:table="cell" aid:ccolwidth="25.30" aid5:cellstyle="zel_Produkt"></cell>
                                <cell aid:table="cell" aid:ccolwidth="158.31" aid:ccols="2" aid:pstyle="abs_Produkt_Beschreibung" aid5:cellstyle="zel_Produkt_Beschreibung">
                                      </xsl:if>
                                </cell>
                            </xsl:if>
                        </xsl:for-each>
                    </Tabelle>
                  </CDs>
                </xsl:template>
                </xsl:stylesheet>
                Whyever UTF-16 doesn't work for me, UTF-8 works fine.
                But why the import stucks - I don't know...
                best regards
                Johannes
                • 5. Re: xml import runs hours - never get finished
                  MW Design Level 5
                  Hi Johannes,
                  Hopefully it works. Let us know.
                  • 6. Re: xml import runs hours - never get finished
                    enzephalon Level 1
                    Hello
                    I had to cut my XML file into 3 pieces with 1000 nodes each. These I was able to import.
                    In case of larger files (1500 nodes) the import freezes.
                    Importing, reloading - these are unbelievable slow, taking 30 or more minutes - on a performance machine! Whats wrong with InDesign? Such easy xml-transformation can be done by php in seconds!
                    I did a "benchmark" with other computer: Core2Dueo 3GHz Windows7 64bit InDesign CS5. Imported the whole 3000 nodes xml file - the import was running 3 hours!
                    best regards
                    Johannes
                    • 7. Re: xml import runs hours - never get finished
                      MW Design Level 5
                      So do the transformation in PHP. I use a dedicated XML editor to do such things. With the transformed xml being loaded it takes ID 10 minutes or a little less. It should be faster, but it isn't. Xml hasn't been updated for a long, long time that I know of.
