1 Reply Latest reply on Mar 24, 2016 9:13 AM by Gaius Coffey
    Flash builder compile bug; what do I do here?
    Gaius Coffey Level 2
      I have recently done a clean install of Windows and, consequently, Flash Builder.
      Now, whenever I try to compile _FOR_RELEASE_ against a known-good project, I get the error shown below.
      No errors are shown when debugging.
      The project is good and from a long established codebase that I have been working with for several years.
      HOW DO I GET IT TO COMPILE?
      G
      Description Resource Path Location Type
      com.google.common.collect.ComputationException: java.lang.NullPointerException
      at com.google.common.collect.ComputingConcurrentHashMap$ComputingSegment.compute(ComputingCo ncurrentHashMap.java:167)
      at com.google.common.collect.ComputingConcurrentHashMap$ComputingSegment.compute(ComputingCo ncurrentHashMap.java:116)
      at com.google.common.collect.ComputingConcurrentHashMap.apply(ComputingConcurrentHashMap.jav a:67)
      at com.google.common.collect.MapMaker$ComputingMapAdapter.get(MapMaker.java:623)
      at com.adobe.flash.compiler.internal.projects.CompilerProject.getCacheForScope(CompilerProje ct.java:701)
      at com.adobe.flash.compiler.internal.definitions.InterfaceDefinition.resolveExtendedInterfac es(InterfaceDefinition.java:123)
      at com.adobe.flash.compiler.internal.definitions.InterfaceDefinition$InterfaceIterator.analy ze(InterfaceDefinition.java:343)
      at com.adobe.flash.compiler.internal.definitions.InterfaceDefinition$InterfaceIterator.initF romInterface(InterfaceDefinition.java:325)
      at com.adobe.flash.compiler.internal.definitions.InterfaceDefinition$InterfaceIterator.<init >(InterfaceDefinition.java:293)
      at com.adobe.flash.compiler.internal.definitions.ClassDefinitionBase.interfaceIterator(Class DefinitionBase.java:399)
      at com.adobe.flash.compiler.internal.definitions.ClassDefinitionBase.isInstanceOf(ClassDefin itionBase.java:429)
      at com.adobe.flash.compiler.internal.semantics.SemanticUtils.isInstanceOf(SemanticUtils.java :565)
      at com.adobe.flash.compiler.internal.semantics.SemanticUtils.isValidTypeConversion(SemanticU tils.java:220)
      at com.adobe.flash.compiler.internal.semantics.SemanticUtils.isValidTypeConversion(SemanticU tils.java:342)
      at com.adobe.flash.compiler.internal.semantics.MethodBodySemanticChecker.checkImplicitConver sion(MethodBodySemanticChecker.java:560)
      at com.adobe.flash.compiler.internal.semantics.MethodBodySemanticChecker.checkImplicitConver sion(MethodBodySemanticChecker.java:372)
      at com.adobe.flash.compiler.internal.semantics.MethodBodySemanticChecker.checkAssignment(Met hodBodySemanticChecker.java:244)
      at com.adobe.flash.compiler.internal.as.codegen.ABCGeneratingReducer.reduce_assignToNameExpr _to_void_expression(ABCGeneratingReducer.java:3026)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.action_238(CmcEmitter.java:4509)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.dispatchAction(CmcEmitter.java:81 61)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.reduceAntecedent(CmcEmitter.java: 39704)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.dispatchAction(CmcEmitter.java:95 07)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.reduce(CmcEmitter.java:39681)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.reduceSubgoals(CmcEmitter.java:39 732)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.reduceAntecedent(CmcEmitter.java: 39703)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.reduceSubgoals(CmcEmitter.java:39 723)
      at com.adobe.flash.compiler.internal.as.codegen.CmcEmitter.burm(CmcEmitter.java:39983)
      at com.adobe.flash.compiler.internal.as.codegen.ABCGenerator.generateInstructions(ABCGenerat or.java:232)
      at com.adobe.flash.compiler.internal.as.codegen.ABCGenerator.generateMethodBodyForFunction(A BCGenerator.java:397)
      at com.adobe.flash.compiler.internal.as.codegen.ABCGenerator.generateMethodBodyForFunction(A BCGenerator.java:351)
      at com.adobe.flash.compiler.internal.as.codegen.ABCGenerator.generateFunction(ABCGenerator.j ava:266)
      at com.adobe.flash.compiler.internal.as.codegen.ClassDirectiveProcessor.finishClassDefinitio n(ClassDirectiveProcessor.java:468)
      at com.adobe.flash.compiler.internal.as.codegen.GlobalDirectiveProcessor.declareClass(Global DirectiveProcessor.java:424)
      at com.adobe.flash.compiler.internal.as.codegen.DirectiveProcessor.processNode(DirectiveProc essor.java:207)
      at com.adobe.flash.compiler.internal.as.codegen.DirectiveProcessor.traverse(DirectiveProcess or.java:189)
      at com.adobe.flash.compiler.internal.as.codegen.GlobalDirectiveProcessor.declarePackage(Glob alDirectiveProcessor.java:449)
      at com.adobe.flash.compiler.internal.as.codegen.DirectiveProcessor.processNode(DirectiveProc essor.java:224)
      at com.adobe.flash.compiler.internal.as.codegen.ABCGenerator.generate(ABCGenerator.java:126)
      at com.adobe.flash.compiler.internal.units.ASCompilationUnit.handleABCBytesRequest(ASCompila tionUnit.java:374)
      at com.adobe.flash.compiler.internal.units.CompilationUnitBase.processABCBytesRequest(Compil ationUnitBase.java:870)
      at com.adobe.flash.compiler.internal.units.CompilationUnitBase.access$300(CompilationUnitBas e.java:107)
      at com.adobe.flash.compiler.internal.units.CompilationUnitBase$4$1.call(CompilationUnitBase. java:309)
      at com.adobe.flash.compiler.internal.units.CompilationUnitBase$4$1.call(CompilationUnitBase. java:305)
      at com.adobe.flash.compiler.internal.units.requests.RequestMaker$1.call(RequestMaker.java:22 8)
      at com.adobe.flash.compiler.internal.units.requests.RequestMaker$1.call(RequestMaker.java:22 2)
      at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
      at java.util.concurrent.FutureTask.run(Unknown Source)
      at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
      at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
      at java.lang.Thread.run(Unknown Source)
      Caused by: java.lang.NullPointerException
      at com.google.common.base.Preconditions.checkNotNull(Preconditions.java:187)
      at com.google.common.collect.CustomConcurrentHashMap.hash(CustomConcurrentHashMap.java:1432)
      at com.google.common.collect.ComputingConcurrentHashMap.apply(ComputingConcurrentHashMap.jav a:66)
      at com.adobe.flash.compiler.internal.scopes.ASProjectScope.addScopeToCompilationUnitScopeLis t(ASProjectScope.java:1306)
      at com.adobe.flash.compiler.internal.projects.CompilerProject$ScopeMakerFunction.apply(Compi lerProject.java:106)
      at com.adobe.flash.compiler.internal.projects.CompilerProject$ScopeMakerFunction.apply(Compi lerProject.java:95)
      at com.google.common.collect.ComputingConcurrentHashMap$ComputingSegment.compute(ComputingCo ncurrentHashMap.java:155)
      ... 54 more PlayerSprite.as /RTE_OSMF_Player/src line 37 Flex Problem
