0 Replies Latest reply on Mar 24, 2016 10:20 AM by Dizz Hicks
    Apply/amend script to work on multiple objects?
    Dizz Hicks Level 1
      I need to convert hundreds of objects into perfect circles of a more-or-less equal area to each original object.
      I found the below script but it only works with a single object.
      Can it be amended to apply to all objects selected, or is there a way to apply a script to each selected object individually?
      Thank you!
      #target illustrator
      function main() {
           if (app.documents.length == 0) {
                alert('Open a document before running this script');
                     return;
           } else {
                var docRef = app.activeDocument;
                with (docRef) {
                     if (pathItems.length == 0) {
                          alert('No Path Items');
                          return;
                     } else {
                          var pVB = pathItems[0].visibleBounds;
                          var pVC = (pVB[2]+pVB[0])/2;
                          var pHC = (pVB[1]+pVB[3])/2;
                          var rad = Math.sqrt(pathItems[0].area/Math.PI);
                          pathItems.ellipse(pHC+rad,pVC-rad,rad*2,rad*2,false,true);
                          redraw();
      main();
