2 Replies Latest reply on May 23, 2016 4:10 PM by kristens93382128
    Activation Error
    MagisterAlbus
      I have downloaded an e-book from Harper-Collins but, when I try to read it, I get this message: Error! Check Activation.
      What does that mean?@
        • 1. Re: Activation Error
          cselhost Level 2
          Hi Magister,
          You need to manually delete the activation file and then resign in. Please follow these steps:
          You must have administration authority.
          On Windows it can be found here:
          Open Windows Registry by using the command prompt and typing 'regedit' or by opening the start menu and searching for 'regedit'.
          Search for the following folder:
          HKEY_CURRENT_USER\Software\Adobe\Adept\Activation
          The 'Activation' folder can be entirely deleted.
          On Mac it can be found here:
          In Finder, find the 'Go' option on the menu bar and click 'Go to folder' and type the following in:
          ~/Library/Application Support/Adobe/Digital Editions/
          Delete the activation.dat file within the 'Digital Editions' folder.
          Restart ADE and it should be deactivated at this point. You should be good to sign back in.
          • 2. Re: Activation Error
            kristens93382128
            Thank you!!  I had the exact same problem and this solved it!!  I had to re-authorize my computer, but now it works! THANKS AGAIN!
