1 Reply Latest reply on Mar 25, 2016 10:37 AM by cselhost
    Try to add .acsm to library, get error "Error.  Check Activation"
    danc53520975
      Try to add .acsm to library, get error "Error.  Check Activation"  Have removed authorization / reauthorized / downloaded new ADE still get error msg.
        • 1. Re: Try to add .acsm to library, get error "Error.  Check Activation"
          cselhost Level 2
          Hi Dan,
          You need to manually delete the activation file and then resign in. Please follow these steps:
          You must have administration authority.
          On Windows it can be found here:
          Open Windows Registry by using the command prompt and typing 'regedit' or by opening the start menu and searching for 'regedit'.
          Search for the following folder:
          HKEY_CURRENT_USER\Software\Adobe\Adept\Activation
          The 'Activation' folder can be entirely deleted.
          On Mac it can be found here:
          In Finder, find the 'Go' option on the menu bar and click 'Go to folder' and type the following in:
          ~/Library/Application Support/Adobe/Digital Editions/
          Delete the activation.dat file within the 'Digital Editions' folder.
          Restart ADE and it should be deactivated at this point. You should be good to sign back in.
