3 Replies Latest reply on Jun 6, 2006 5:28 PM by vonblonderbelt
    Loading bar
      Hello! I' m new in Flsh and I want someone to tell me how can I make a loading bar??
        • 1. Re: Loading bar
          NNDth Level 1
          • 2. Re: Loading bar
            I assume you mean a pre-loader that shows a progress bar and then launches the movie?
            I found some tutorials on the Net how to make one and got one to actually work.
            But maybe the easiest thing would be to send you a flash file with the preloader in it. It uses the first two frames of a movie. You could use that as your base and build your movie after that, or insert it into a pre-existing movie. My preloader gives a progress bar and also indicates the percent of the movie as it loads. You can change the text styles and color of the bar and so on. I got it from a tutorial, so I think it is okay to share it. I just can't remember which tutorial (I've read so many!) I found it in.
            If you are interested, send me an e-mail or Private Message.
            • 3. Re: Loading bar
              for an excellent preloader tutorial, go check out www.gotoandlearn.com
