6 Replies Latest reply on Mar 29, 2016 7:02 AM by Loic.Aigon
    Export xml attribute values
    karthiks94217840 Level 2
      Dear java expert,
      I was try to script export attribute value in the .txt format. I have attached screenshot for your reference.  Please suggestion me friends.
      I am using system: Mac, indesign Cs6.
      Advance Thanks to all
        • 1. Re: Export xml attribute values
          Dear friends,
          Please tell any one suggestion in my above question?
          • 2. Re: Export xml attribute values
            Dear java kings,
            Advance Thanks to all,
            • 3. Re: Export xml attribute values
              Dear friends,
              I have share my java coding in below, based on the above question.
              var myDocument = app.activeDocument;
              var log=new File(app.activeDocument.filePath+"/log.html");
              log.encoding = "UTF-8";
              log.open("w");
              log.writeln("<html><body><table border=1>");
              log.writeln("<tr><td>Text(In template)</td><td>Found(Href Tag)</td></tr>");
              FindEmail(myDocument);
              log.writeln("</table></body></html>");
              log.close();
              alert("process Completed");
              function FindEmail(elm)
                  for (var i = 0; i < elm.xmlElements.length; i++)
                      XMLelementName=elm.xmlElements[i].markupTag.name.toString();
                     if(XMLelementName=="img")
                           for(j=0; j<elm.xmlElements[i].xmlAttributes.length; j++)
                              var cc =  elm.xmlElements[i].contents
                               //alert(cc);
                               var aa = elm.xmlElements[i].xmlAttributes[j].name
                                if(aa=="src")
                                       //alert (aa);
                                        var bb =  elm.xmlElements[i].xmlAttributes[j].value;
                                       log.writeln("<tr><td>"+ cc +"</td><td>"+  elm.xmlElements[i].xmlAttributes[j].value +"</td></tr>");
                                        //alert (cc  + "~~" + aa+ " ~~ "  + bb);
                      FindEmail(elm.xmlElements[i]);
              • 4. Re: Export xml attribute values
                Loic.Aigon Adobe Community Professional
                Hi there is more interesting and performing imho:
                var main = function(){
                  var doc = app.properties.activeDocument,
                  xmlFile = File ( Folder.temp+"/attr.xml" ),
                  xmlObject,
                  xmlAttrs, attrs = [], n = 0, i = 0,
                  sep = "\t";
                  if (!doc) return;
                  doc.exportFile ( ExportFormat.XML, xmlFile );
                  if ( !xmlFile.exists ) {
                  alert("Unable to read xml data");
                  return;
                  xmlFile.open('r');
                  xmlObject = XML ( xmlFile.read() );
                  xmlFile.close();
                  xmlFile.remove();
                  xmlAttrs = xmlObject.xpath("//*//@*");
                  n = xmlAttrs.length();
                  while ( i<n ) {
                  attrs [ attrs.length ] = xmlAttrs[i].name()+sep+xmlAttrs[i];
                  i++;
                  if ( !attrs.length ) {
                  alert("Could'nt find any attributes.");
                  return;
                  writeFile ( "Attribute Name"+sep+"Attribute Value"+"\r"+attrs.join("\r") );
                var writeFile = function( data ) {
                  var file = File ( Folder.desktop+"/attributes.csv" );
                  file.open("w");
                  file.write ( data );
                  file.close();
                  file.execute();
                main();
                FWIW,
                Loic
                Ozalto | Productivity Oriented - Loïc Aigon
                • 5. Re: Export xml attribute values
                  HI Loic.Aigon,
                  Thank you so match for your advance script. Very help full for me.
                  Just one question: Where is you are mention(add) the image tags for <img> in the script?
                  Example for my coding: if(XMLelementName=="img")
                  Please explain me friend.
                  • 6. Re: Export xml attribute values
                    just edit the xpath:
                    //img/@*
                    Loic
