5 Replies Latest reply on Mar 26, 2016 12:53 PM by Obi-wan Kenobi
    Find frames and resize them! …
    Obi-wan Kenobi Level 5
      This simple script works fine:
      var myTF = app.activeDocument.textFrames.everyItem().getElements()
      for(i=0; i<myTF .length; i++)
          myStoreBounds = myTF[i].geometricBounds
          myTF[i].geometricBounds = [myStoreBounds[0], myStoreBounds[1], myStoreBounds[0] +50, myStoreBounds[1] +50]
      But not this one:
      var myWidth = "50 mm"
      var myHeight = "50 mm"
      app.activeDocument.textFrames.everyItem().resize(
            CoordinateSpaces.INNER_COORDINATES,
            AnchorPoint.CENTER_ANCHOR,
            ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH,
            [ myWidth, myHeight ]
      I'm curious to know why!
      What I truly want to do is: select several graphic frames (not a find/replace and not text frames) and resize them using this: AnchorPoint.CENTER_ANCHOR
      Another way would be to find graphic frames by their color [e.g. "Red"].
      Thanks for your help and your lenience!
        • 1. Re: Find frames and resize them! …
          Peter Kahrel Adobe Community Professional & MVP
          .resize() takes as input only numbers and they are always interpreted as points. To use millimeters, convert them to points:
          var myWidth = UnitValue('50mm').as('pt');
          var myHeight = UnitValue('50mm').as('pt');
          To select several frames and resize them, you could do something like this:
          for (i = 0; i < app.selection; i++) {
            app.selection[i].resize(. . .);
          Peter
          • 2. Re: Find frames and resize them! …
            Hi Peter,
            Thanks for your help!
            About the first point, this works fine!    So the 2 versions are OK.
            2 last questions about their writing:
            • If I only want to treat graphic or undefined frames, I only found this but I don't really understand if good and how to insert them in the code:
            ObjectTypes.ALL_FRAMES_TYPE    All frame types.
            ObjectTypes.GRAPHIC_FRAMES_TYPE    Graphics frame.
            ObjectTypes.TEXT_FRAMES_TYPE    Text frame.
            ObjectTypes.UNASSIGNED_FRAMES_TYPE    Unassigned frame.
            • In this version, where can I add "AnchorPoint.CENTER_ANCHOR" to resize correctly the blocks?
            About the second point, It doesn't work! Surely something I've not understood!
            I've selected some blocks and tried this:
            var myWidth = UnitValue('10mm').as('pt');
            var myHeight = UnitValue('10mm').as('pt');
                  [ myWidth, myHeight ]);
            Thanks!
            • 3. Re: Find frames and resize them! …
              Sorry, in that code, the for loop is wrong, it should be like this:
              for (i = 0; i < app.selection.length; i++) {
              • 4. Re: Find frames and resize them! …
                If you're after graphic frames, you can do several things.
                1. Graphics are always in a rectangle, never in a text frame, so you could do app.documents[0].rectangles instead of app.documents[0].textFrames.
                2. Get all frames (e.g. select all items on a page), then after line 4 add an if clause: if (app.selection[i] instanceof Rectangle) {
                3. But if you're after all graphics in a document, then it's easiest to go after the document's links: app.documents[0].links. If you have a link object, its parent is the graphic, and its parent in turn is a rectangle. So you'd get something like this:
                var myLinks = app.activeDocument.links.everyItem().getElements();
                for (var i = 0; i < myLinks.length; i++) {
                  myLinks[i].parent.parent.resize(
                    [ myWidth, myHeight]
                P.
                • 5. Re: Find frames and resize them! …
                  Thanks a lot, Peter!
