4 Replies Latest reply on Apr 11, 2016 8:25 AM by greg_sutton
    What is the "default" TOC font?
    greg_sutton
      What is the "default" TOC font (i.e., the font chosen when you click the Default Font button on the TOC Styles tab under Advanced Settings)?
      Regards,
      Greg
        • 1. Re: What is the "default" TOC font?
          Willam van Weelden Adobe Community Professional & MVP
          Which RH version and which Layout? For RH2015, the default font is the font set in the global settings.
          • 2. Re: What is the "default" TOC font?
            greg_sutton Level 1
            So sorry. I am using RH2015. Do you mean the Windows system font setting?
            • 3. Re: What is the "default" TOC font?
              What you are asking about would seem to imply you are creating CHM output?
              CHM output is presented using the Microsoft HTML Help viewer. That viewer uses elements of Microsoft Internet Explorer for its display engine. Perhaps Willam knows more about it, but my own guess would be that the Default font is whatever Microsoft Internet Explorer would be using.
              Why are you concerned with the TOC font?
              Cheers... Rick
              • 4. Re: What is the "default" TOC font?
                greg_sutton Level 1
                Yes, I am creating a CHM output using RH2015. Here is my concern. Years ago, we [my company] did not specify a font for the TOC, which resulted in undesirable font substitutions. For example, on one customer's computer, the TOC font ended up being an unreadable script font. This was probably back in Windows 97 days.
                Since then, we always specified Verdana 8pt as the TOC font (but for some reason chose Arial as the body text font). I want to use Segoe UI Regular as my body text font and as my TOC font. RH2015 only allows Light as the font style selection when Segoe UI is selected as the font.
                I want to avoid the issue we had years ago. I can specify another font for the TOC but now I am curious as to what is the source of the "default" TOC font.  Changing the font in Internet Explorer is not changing my TOC font.
