7 Replies Latest reply on Apr 16, 2006 7:54 PM by icemansiva
    Sprite Movement
    M4rkeh Level 1
      Hi i was wondering if its possible to get a sprite to move accross the stage, then when clicked on it changes to a different sprite, plays a sound and resets to its original position to start over again?
      currently i have the sprite moving across the screen once, and the sprite i want to replace the original with appears in the center of the stage when i click, not where the first sprite was.
      on mouseup me
      sprite(2).member="picture2"
      Hopefully someone understands what i'm trying to do. Any help would be great
      thanks
      Mark
        • 1. Re: Sprite Movement
          James Newton, ACP Level 3
          property pSprite
          property pStartLoc
          property pTargetLoc
          property pStep
          property pFrames
          on beginSprite(me)
          pSprite = sprite(me.spriteNum)
          pStartLoc = pSprite.loc
          pTargetLoc = point(0, 0) -- or wherever
          pFrames = 30 -- number of frames to reach target
          pStep = (pStartLoc - pTargetLoc) / float(pFrames)
          end
          on enterFrame(me)
          if not pFrames then
          exit
          end if
          pFrames = pFrames - 1
          vLoc = pTargetLoc + pFrames * pStep
          pSprite.loc = vLoc
          end enterFrame
          on mouseUp(me)
          pSprite.member = me.mGetMember()
          pSprite.loc = pStartLoc
          puppetSound(1, "MouseUp Sound")
          pFrames = 30
          end
          on mGetMember(me)
          return pSprite.member -- or something more imaginative
          end
          • 2. Re: Sprite Movement
            M4rkeh Level 1
            Thanks v much for the help openspark, i'll try this tonight, can i just ask what the difference is between -
            and
            pSprite = sprite the spritenum of me
            Is there two versions or a shorter version of lingo i'm missing out on. Sorry if this is a stupid question i'm new to director, just wondering why people on these forums usually type lingo in a way different to what i'm taught in class.
            • 3. Re: Sprite Movement
              'pSprite = sprite(me.spriteNum)' will not work in Director 6.5 and earlier, whereas 'pSprite = sprite the spritenum of me' will.
              In both cases, you can also use
              property spriteNum -- explicit declaration of the implicit spriteNum property
              on beginSprite
              pSprite = sprite(spriteNum)
              -- etc
              end
              • 4. Re: Sprite Movement
                M4rkeh Level 1
                That script sort of does what i need it to do, i'm not sure if I fully understand what its doing though.
                Is there a way to get the sprite to return to the original location once it gets to the target location and has not been clicked on?
                Also can i get the sprite image to change to another image when its clicked on before it resets to the original location?
                Mark
                • 5. Re: Sprite Movement
                  In the enterFrame() handler, when pFrames reaches 0, it appears at the target point. Subsequently, the enterFrame() handler is shortcircuited. You could add code to allow pFrames to reach -1, and when it does so, return it to its pStartLoc.
                  You could move the line...
                  ... to a mouseDown() handler, so that the member changes on mouseDown, but the sprite moves back to pStartLoc on mouseUp.
                  You need to change the mGetMember() handler so that it returns a different member. I do not know what different member(s) you might want to use, so I have left this as 'an exercise for the reader'.
                  • 6. Re: Sprite Movement
                    M4rkeh Level 1
                    thanks for all the help openspark, i'm slowly getting things working
                    I still can't get the sprite to change though -
                    what do i do with mGetMember() ? put the sprite number between the brackets or sprite name?
                    Sorry one more question is there any way to set a random time before the sprite appears? such a wait or hold command set to a random interval before the sprite is shown on the stage?
                    apologies for all the questions i don't mean to be a pain in the rear
                    thanks
                    Mark
                    • 7. Re: Sprite Movement
                      icemansiva
                      Hi Guys, im new here, i want to know what actually these codes do in Lingo..
                      on mouseEnter
                      cursor 280
                      sprite (2).member = “red”
                      end
                      on mouseLeave
                      cursor –1
                      sprite (2).member = “black”
                      on mouseUp
                      quit
                      end
                      on exitFrame me
                      sound playFile 1, “music/la_la_la_luv_song.mp3”
                      go to the frame
                      end
                      on mouseUp
                      puppetSound 1, 0
                      end
