1 Reply Latest reply on Mar 29, 2016 10:05 AM by Peru Bob
    Trying to use ADS Pyro A/V Link w/ PE14 and Windows10Pro
    Duke Green
      Hello. It has been some time and several versions ago that I used this device to capture VHS. I'm trying to use it again w/ no success.
      The 1394 is working properly and I got the device recognized by Windows, but it doesn't show up in PE options to capture.
      I tried going back to PE11 w/ the same results. It is there in Device Manager, but PE doesn't see it.
      I understand that drivers are not available, but using Firewire, apparently they are not needed.
      Any ideas?
      Duke
        • 1. Re: Trying to use ADS Pyro A/V Link w/ PE14 and Windows10Pro
          Peru Bob Adobe Community Professional & MVP
          Premiere Elements 14 doesn't support Firewire capture.
          You can use these programs for capture:
          WinDV   WinDV
          HDVSplit   HDVSplit 0.77 beta
          To capture in Premiere Elements 11, you need to enable the Legacy driver.
          This is for Windows 7, but may work for Windows 10:
          Solution 6: Use the Legacy FireWire driver (Windows 7 x64)
          • Click the Windows start button; type "device manager" into the Search box and select Device Manager
            Swivel open the "IEEE 1394 Bus host controllers" item
            Right-click on your listed 1394 controller; select "Update Driver Software"
            Click the "Browse my computer for driver software" button, followed with the "Let me pick from a list" button
            Select the option that has "(Legacy)" at the end of the name; click Next and let Windows install the driver
            Close out of dialogs and retry capture
            from here:
