6 Replies Latest reply on Mar 31, 2016 7:11 AM by gkaiseril
    comb
    klothos
      is it possible to see the numbers with zero in front like 00 01 02 03 (comb with 2 characters)
        • 1. Re: comb
          Yes, but then you have to define the field's Format as None.
          • 2. Re: comb
            George_Johnson MVP & Adobe Community Professional
            Use either a format type of arbitrary mask (e.g., 99) or you could create a custom keystroke/format JavaScript if the arbitrary mask option doesn't behave exactly as you want.
            • 3. Re: comb
              Create the form field.
              Appearance add border of choice.
              Options select "Comb" set size to 2.
              Format custom Format Script:
              event.value = util.printf("%,102.0f", event.value);
              Custom Keystroke script:
              if(event.willCommit == false) {
              event.rc = isNaN(event.change) == false;
              Validation:
              if(isNaN(event.value) == true) app.alert("Please enter a numeric value", 1, 0);
              Close.
              Test the field in Preview.
              • 4. Re: comb
                klothos Level 1
                i made this
                var t1 = Number(this.getField("Textfield221").value);
                if (event.value>=1 && event.value<=98 && t1>=1 && t1<=7) this.getField("08").setFocus();var t1 = Number(this.getField("Textfield221").value);
                if (event.value=="00" && t2=="0") this.getField("Textfield231").setFocus();
                and as you told me i  choose format category None
                and it works
                • 5. Re: comb
                  klothos Level 1
                  hello i follow all your format steps and i run this this custom validation script
                  if(event.value=="0")this.getField("Textfield221").setFocus();if(event.value>"0")this.getFi eld("Textfield215").setFocus();if(isNaN(event.value) == true) app.alert("Please enter a numeric value", 1, 0);
                  it works when i type on "0" but then it is strange that i can not clear it.Always 00 apear.
                  • 6. Re: comb
                    I do not have that problem as long as I delete one or both digits.
