17 Replies Latest reply on May 26, 2016 8:40 AM by moluapple
    Help with script: export to Live and Outlined versions
    Pete Stan Level 1
      Hi All,
      I am currently working on a script (editing one we currently use) that will allow me to export Outlined and Live version at the same time (using Illustrator CS4 and CS6). I've basic knowledge about scripting.
      See screenshot below, what I am trying to achieve:
      Here's what I've done so far:
      // Main Code [Execution of script begins here]
      var modUI = 'D';
      try {
        // uncomment to suppress Illustrator warning dialogs
        // app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
        if (app.documents.length > 0 ) {
        // Get the folder to save the files into
        var options, i, sourceDoc, targetFile;
        // Get the PDF options to be used
        options = this.getOptions();
        if (options != null) {
        // You can tune these by changing the code in the getOptions() function.
        sourceDoc = app.activeDocument; // returns the document object
        var fullName = sourceDoc.fullName;
        fullName = fullName.toString();
        var destFolder = fullName.slice(0,fullName.lastIndexOf("/"))
        // Get the file to save the document as pdf into
        targetFile = this.getTargetFile(sourceDoc.name, '_Live.pdf', destFolder);
        OLtargetFile = this.getTargetFile(sourceDoc.name, '_Outlined.pdf', destFolder);
        sourceDoc.save();
        // Save as pdf
        sourceDoc.saveAs( targetFile, options );
        for(q=0; q<sourceDoc.layers.length;q++){
        sourceDoc.layers[q].locked = false
        for(q=0; q<sourceDoc.pageItems.length;q++){
        try {
        sourceDoc.pageItems[q].createOutline();
        catch(e){}
        sourceDoc.saveAs( OLtargetFile, options)
        alert( 'Documents saved as PDF' );
        else {
        alert('User aborted')
        else{
        throw new Error('There are no document open!');
      catch(e) {
        alert( e.message, "Script Alert", true);
      /** Returns the options to be used for the generated files.
        @return PDFSaveOptions object
      function getOptions()
        var dlg = new Window('dialog', 'Script Information',[90,50,300,175]);
        dlg.include = dlg.add('radiobutton',[50,5,295,30], 'PDF 1.3 (Default)');
        dlg.include = dlg.add('radiobutton',[50,30,320,40], 'PDF 1.6 (Advanced)');
        dlg.buildBtn = dlg.add('button',[10,95,90,27], 'Create PDF', {name:'ok'})
        dlg.cancelBtn = dlg.add('button',[105,95,190,47], 'Cancel', {name:'cancel'})
        dlg.include.onClick = radioSwitch;
        dlg.cancelBtn.onClick = abortFunction;
        dlg.center();
        dlg.show();
        // Create the required options object
        var options = new PDFSaveOptions();
        // See PDFSaveOptions in the JavaScript Reference for available options
        // Set the options you want below:
        if (modUI == 'D'){
        options.pDFPreset = "Default"
        else if (modUI == 'I'){
        options.pDFPreset = "Advanced"
        else {
        options = null;
        // For example, uncomment to set the compatibility of the generated pdf to Acrobat 7 (PDF 1.6)
        // options.compatibility = PDFCompatibility.ACROBAT7;
        // For example, uncomment to view the pdfs in Acrobat after conversion
        // options.viewAfterSaving = true;
        return options;
      function radioSwitch(){
        if (modUI == 'D') {
        modUI = 'I'
        else {
        modUI = 'D'
      function abortFunction(){
        modUI = null;
        dlg.hide();
        return null;
      /** Returns the file to save or export the document into.
        @param docName the name of the document
        @param ext the extension the file extension to be applied
        @param destFolder the output folder
        @return File object
      function getTargetFile(docName, ext, destFolder) {
        var newName = "";
        // if name has no dot (and hence no extension),
        // just append the extension
        if (docName.indexOf('.') < 0) {
        newName = docName + ext;
        } else {
        var dot = docName.lastIndexOf('.');
        newName += docName.substring(0, dot);
        newName += ext;
        // Create the file object to save to
        var myFile = new File( destFolder + '/' + newName );
        // Preflight access rights
        if (myFile.open("w")) {
        myFile.close();
        else {
        throw new Error('Access is denied');
        return myFile;
      Any help appreciated!
      Pete
        • 2. Re: Help with script: export to Live and Outlined versions
          Silly-V Adobe Community Professional
          Whoa , how did you create such a diagram?
          • 3. Re: Help with script: export to Live and Outlined versions
            Pete Stan Level 1
            Hi Silly-V,
            Yes I did! Always like to visualise and document my goal. Obviously going over the top with details sometimes (progress bar), but overall I think it's good to have a big picture!
            I have a general sense of the script but unfortunately my scripting abilities reached the point where I am not able to move on with some of the functions.
            Thank you for your interest though!
            • 4. Re: Help with script: export to Live and Outlined versions
              So you drew it all yourself in AI?
              How about your progress bar, is it not only going to show you only 1 file? Or are you talking about a saving-pdf progress bar, in which case I think one appears automatically anyways.
              • 5. Re: Help with script: export to Live and Outlined versions
                Pete Stan Level 1
                All in Ai, I am using it on a daily basis after all!
                The script will work only on the open file (single PDF). Once I finish working on the file (still keeping it open), I'll execute the script.
                The Progress bar will show the progress of  exporting to Live and Outline PDF of the single file.
                • 6. Re: Help with script: export to Live and Outlined versions
                  So your progress bar is just going to be the native progress bar Illustrator shows, right. So what's wrong with it so far? Looks like all the parts are there from a brief look-over.
                  • 7. Re: Help with script: export to Live and Outlined versions
                    Pete Stan Level 1
                    Hi Silly,
                    I see no progress bar anyways. Let's forget about the bar. I wanted to focus more on the code itself. There is an issue, it hangs when running it on Windows PC.
                    • 8. Re: Help with script: export to Live and Outlined versions
                      shri_kr
                      I am not so good at scripting but you can achieve this using a combination of script and actions.
                      1. create an action
                      2. use javascript to save the ai file to pdf using save as script
                      3. create outlined pdf using export option. This can be achieved through a free plugin called "Esko Dataexchange" and this saves the file as normalised pdf which is as similar to pdf
                      Hope this helps you.
                      • 9. Re: Help with script: export to Live and Outlined versions
                        Pete Stan Level 1
                        I don't want use any external plug-ins, especially if this procedure can be achieved by pure scripting. Especially when it comes to work on other machines (Mac or PC).
                        • 11. Re: Help with script: export to Live and Outlined versions
                          moluapple Level 4
                          A work version with no bar. make sure the "Default" and "Advanced" presets exist in your PDFSaveOptions presets list, and name are correct.
                          try {
                              if (app.documents.length > 0) {
                                  var options, i, sourceDoc, targetFile, OLtargetFile;
                                  showDlg();
                                  if (!options) {
                              } else {
                          } catch (e) {
                              alert(e.message, "Script Alert", true);
                          function showDlg() {
                              var dlg = new Window('dialog', 'Script Information', [90, 50, 300, 175]);
                              dlg.buildBtn = dlg.add('button', [10, 95, 90, 120], 'Create PDF', {name: 'ok'})
                              dlg.cancelBtn = dlg.add('button', [105, 95, 190, 120], 'Cancel', {name: 'cancel'})
                              dlg.Dbtn = dlg.add('radiobutton', [50, 5, 295, 30], 'PDF 1.3 (Default)');
                              dlg.Ibtn = dlg.add('radiobutton', [50, 30, 320, 55], 'PDF 1.6 (Advanced)');
                              dlg.Dbtn.value = true;
                              dlg.buildBtn.onClick = savePDF;
                              dlg.center();
                              dlg.show();
                          function savePDF() {
                              this.parent.close();
                              if (this.parent.Dbtn.value) {
                              } else {
                              var destFolder = fullName.slice(0, fullName.lastIndexOf("/"))
                              targetFile = getTargetFile(sourceDoc.name, '_Live.pdf', destFolder);
                              OLtargetFile = getTargetFile(sourceDoc.name, '_Outlined.pdf', destFolder);
                              //sourceDoc.save();
                              // Save as pdf
                              sourceDoc.saveAs(targetFile, options);
                              for (i = 0; i < sourceDoc.layers.length; i++) {
                                  sourceDoc.layers[i].locked = false
                              for (i = 0; i < sourceDoc.pageItems.length; i++) {
                                  try {
                                      sourceDoc.pageItems[i].createOutline();
                                  } catch (e) {}
                              sourceDoc.saveAs(OLtargetFile, options)
                              alert('Documents saved as PDF');
                            @return File object
                              var newName = "";
                              } else {
                                  newName += ext;
                              var myFile = new File(destFolder + '/' + newName);
                                  myFile.close();
                              } else {
                              return myFile;
                          • 12. Re: Help with script: export to Live and Outlined versions
                            Pete Stan Level 1
                            moluapple this is working pretty well! However I realized, that sometimes when using Symbols together with Transform Effect: It won't outline as it supposed to
                            • 13. Re: Help with script: export to Live and Outlined versions
                              moluapple Level 4
                              Yes, always be careful when create outline of texts. It's more safe to using transparency flattener to outline text.
                              With CS6+ version . you can execute a action to outline all text using transparency flattener in your script. I'll show you how if use CS6+ is ok for you.
                              But with CS4, what you can play with script is to set the flattenerOptions of the PDFSaveOptions to outline all text, which limited to PDF 1.3.
                              • 14. Re: Help with script: export to Live and Outlined versions
                                Pete Stan Level 1
                                Sure, will be very helpful to see how it's done in CS6!
                                • 15. Re: Help with script: export to Live and Outlined versions
                                  moluapple Level 4
                                  try {
                                          showDlg();
                                          if (!options) {
                                      } else {
                                  } catch (e) {
                                      dlg.center();
                                      dlg.show();
                                      } else {
                                      //sourceDoc.save();
                                      // Save as pdf
                                      FlattenOutline();
                                  function FlattenOutline() {
                                      var set = 'script action',
                                          action = 'outline text';
                                      createAction();
                                          app.selection = null;
                                          sourceDoc.layers[i].locked = false;
                                          sourceDoc.layers[i].hasSelectedArtwork = true;
                                          app.doScript(action, set);
                                      app.unloadAction(set, '');
                                  function createAction() {
                                      var actionStr = '/version 3/name [13 73637269707420616374696f6e]/actionCount 1/action-1 {/name [12 6f75746c696e652074657874]/eventCount 1/event-1 {/internalName (ai_plugin_flatten_transparency)/hasDialog 1/showDialog 0/parameterCount 5/parameter-1 {/key 1920169082/type (integer)/value 100}/parameter-2 {/key 1919253100/type (unit real)/value 1200.0/unit 592342629}/parameter-3 {/key 1869902968/type (boolean)/value 1}/parameter-4 {/key 1869902699/type (boolean)/value 0}/parameter-5 {/key 1667463282/type (boolean)/value 0}}}';
                                      f = File('~/tmp.aia');
                                      f.open('w');
                                      f.write(actionStr);
                                      f.close();
                                      app.loadAction(f);
                                      f.remove();
                                    @return File object
                                      var newName = "";
                                      } else {
                                          newName += ext;
                                          myFile.close();
                                      } else {
                                      return myFile;
                                  Note that each layer will become one group due to flatten transparency.
                                  • 16. Re: Help with script: export to Live and Outlined versions
                                    Pete Stan Level 1
                                    moluapple works fantastic in CS6! I see that you are using key parameters. I also understand that you can call it through:
                                    app.executeMenuCommand('Flatten Transparency');
                                    Unfortunately MenuCommand won't work in CS4 which is a bummer!
                                    • 17. Re: Help with script: export to Live and Outlined versions
                                      moluapple Level 4
                                      That MenuCommand only open the UI dialog for you, which is useless in the script. I'm using action instead, also CS6+ only.
