20 Replies Latest reply on Apr 12, 2016 8:51 AM by Carm01
    installing AFP 21 everytime I turn-on my PC from being powered off.
    taga-hugis
      dell precision t3500, win7 ultimate,using AFP 21.
      Why do I have to always install AFP 21 everytime I browse the web? It is suppose to be a ONE-time INSTALL.
      pls. help.
        • 1. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
          maria__ Adobe Employee
          What browser is this on?
          Maria
          • 2. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
            taga-hugis Level 1
            browser is IE 11
            but when I use GOOGLE chrome, it has a built-in flash player & a built-in pdf viewer.
            Pls. help me resolve this. I know I can always just use google chrome, but
            at times I need to use IE 11
            thanks for your reply.
            • 3. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
              Please ensure you have Flash Player enabled and ActiveX Filtering disabled.  See Enable Flash Player for Internet Explorer and ActiveX Filtering in Internet Explorer.
              If Flash Player is enabled and ActiveX Filter is disabled, please provide the FlashInstall.log file to troubleshoot further.  The file is saved at the following location:
              • 32-bit OS: C:\Windows\System32\Macromed\Flash
              • 64-bit OS: C:\Windows\System32\Macromed\Flash AND C:\Windows\SysWOW64\Macromed\Flash
                • FlashInstall.log file from both locations is required on a 64-bit OS
              Upload the file(s) to cloud.acrobat.com using the instructions The specified item was not found. or to some other file sharing service of your choice that doesn't require a log-in to access. Post the link to the uploaded file(s) in your reply.
              Maria
              • 4. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                taga-hugis Level 1
                flash player - enabled in IE
                active x filtering - disabled in IE
                I have taken a picture of the FLASH INSTALL.LOG in the locations
                u have indicated namely in location system 32 & syswow64.
                however, do u have an email so that I can attach the scanned PDF &
                  show you the contents of this 2 locations:
                thanks.
                <deleted email address>
                • 5. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                  While a screenshot of the directory is nice, I need the actual log files.  Please upload the previously requested log files to cloud.acrobat.com using the instructions at The specified item was not found.
                  Also, these are public forums, posting your personal email address is not advised as it'll welcome much unwanted spam, as such, I have removed your email address from your post.
                  Maria
                  • 7. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                    I need the actual FlashInstall.log file to troubleshoot further.  The directory screenshots do show Flash Player is installed, but the log files will indicate if it's installed successfully or not.  I've highlighted the two log files in the screenshots you provided.  Please upload these two log files to cloud.acrobat.com and post the link your reply.
                    Thank you.
                    Maria
                    • 8. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                      taga-hugis Level 1
                      hi, maria,
                      I'm getting ACCESS DENIED message after clicking & trying to open FLASHINSTALL in system 32 &
                        syswow64, how do I proceed
                      • 9. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                        jeromiec83223024 Adobe Employee
                        Do you have administrator rights on the computer?  If not, you may need to ask for help from someone that does.
                        If you do, it sounds like the filesystem is corrupted, which would explain a lot about the weird behavior you're experiencing.
                        Before you mess with the filesystem, ensuring your backups are in order is wise.  Disk corruption can often be an early warning sign of impending hardware failure, and giving the disk a good workout might push it over the edge.  Better to be safe than sorry on that front.
                        Check your hard disk for errors - Windows 7:
                        https://support.microsoft.com/en-us/kb/2641432
                        Once you've repaired any problems with the disk, uninstall the player, download a fresh copy and then run the installer again.
                        Uninstall Flash Player - Windows:
                        https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
                        Download a new copy of the installer here:
                        http://get.adobe.com/flashplayer
                        • 10. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                          taga-hugis Level 1
                          hello Jerome,
                          yes, I do have admin rights to this PC?
                          In fact, that was the INITIAL step that I had to do bec.
                          I was likewise having admin problems w/ ADOBE acrobat pro.
                          but I will contact Dell again for this problem.
                          then will get back at you.
                          thanks.
                          martin
                          • 11. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                            taga-hugis Level 1
                            I have the logfile for the  sys32, but then I still get a "access denied" message when trying to view the log file
                            in sysWOW64, I contacted dell for this.
                            so here it is.
                            =O====== M/11.0.1.152 2011-10-16+05-50-34.765 ========
                            0000  00000010 "C:\Users\LILLIAN'S MARTIN\AppData\Local\Temp\install_flash_player_ax_64bit.exe" -dlm -install
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                            0002  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0003  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0004  00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0005  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0006  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_0_1.ocx
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_0_1_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_0_1_ActiveX.dll
                            0009  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0010  00000011 1
                            =X====== M/11.0.1.152 2011-10-16+05-50-37.940 ========
                            =O====== M/11.0.1.152 2011-10-25+17-39-09.011 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\BB92.dir\InstallFlashPlayer.exe" -iv 6
                            0001  00001039
                            =X====== M/11.0.1.152 2011-10-25+17-39-30.914 ========
                            =O====== M/11.1.102.55 2011-12-26+16-40-39.451 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\2B05.dir\InstallFlashPlayer.exe" -iv 6
                            0001  00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0002  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx
                            0003  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe
                            0004  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll
                            0005  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0006  00000011 1
                            =X====== M/11.1.102.55 2011-12-26+16-40-49.825 ========
                            =O====== M/11.1.102.55 2012-01-04+18-54-23.302 ========
                            0001  00001041
                            =X====== M/11.1.102.55 2012-01-04+18-54-23.421 ========
                            =O====== M/11.1.102.55 2012-01-04+18-54-36.067 ========
                            0003  00001024 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx 183
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe
                            0005  00001024 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 183
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll
                            0007  00001024 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll 183
                            0008  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0009  00000011 1
                            =X====== M/11.1.102.55 2012-01-04+18-54-39.218 ========
                            =O====== M/11.1.102.55 2012-01-10+05-59-42.120 ========
                            0000  00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe" -maintain activex
                            0001  00001039
                            =X====== M/11.1.102.55 2012-01-10+05-59-48.704 ========
                            =O====== M/11.1.102.55 2012-01-10+06-00-35.815 ========
                            0001  00001041
                            =X====== M/11.1.102.55 2012-01-10+06-00-35.956 ========
                            =O====== M/11.1.102.55 2012-01-10+06-00-45.484 ========
                            0009  00000011 1
                            =X====== M/11.1.102.55 2012-01-10+06-00-48.208 ========
                            =O====== M/11.1.102.55 2012-01-10+06-04-37.890 ========
                            0001  00001015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 5
                            0002  00000018
                            0003  00001015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 5
                            0004  00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                            0005  00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                            0006  00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                            0007  00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                            0008  00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                            0009  00001021
                            0010  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0011  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0012  00000011 1
                            0013  00000012
                            =X====== M/11.1.102.55 2012-01-10+06-04-44.817 ========
                            =O====== M/11.1.102.55 2012-01-10+06-10-08.956 ========
                            0001  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0002  00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0003  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0004  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe
                            0007  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0008  00000011 1
                            =X====== M/11.1.102.55 2012-01-10+06-10-11.213 ========
                            =O====== M/11.1.102.55 2012-01-14+22-23-03.104 ========
                            0001  00001041
                            =X====== M/11.1.102.55 2012-01-14+22-23-03.227 ========
                            =O====== M/11.1.102.55 2012-01-14+22-23-12.032 ========
                            0009  00000011 1
                            =X====== M/11.1.102.55 2012-01-14+22-23-14.778 ========
                            =O====== M/11.1.102.55 2012-01-20+22-05-28.236 ========
                            0001  00001041
                            =X====== M/11.1.102.55 2012-01-20+22-05-28.384 ========
                            =O====== M/11.1.102.55 2012-01-20+22-05-30.604 ========
                            0001  00001041
                            =X====== M/11.1.102.55 2012-01-20+22-05-30.741 ========
                            =O====== M/11.1.102.55 2012-01-20+22-05-32.594 ========
                            0001  00001041
                            =X====== M/11.1.102.55 2012-01-20+22-05-32.754 ========
                            =O====== M/11.1.102.55 2012-01-20+22-05-37.290 ========
                            0009  00000011 1
                            =X====== M/11.1.102.55 2012-01-20+22-05-40.540 ========
                            =O====== M/11.1.102.55 2012-02-05+15-26-43.599 ========
                            0001  00001041
                            =X====== M/11.1.102.55 2012-02-05+15-26-43.715 ========
                            =O====== M/11.1.102.55 2012-02-05+15-26-58.222 ========
                            0009  00000011 1
                            =X====== M/11.1.102.55 2012-02-05+15-27-03.038 ========
                            =O====== M/11.2.202.228 2012-03-30+22-32-30.626 ========
                            0000  00000010 "C:\Users\LILLIAN'S MARTIN\AppData\Local\Temp\install_flash_player_ax_64bit.exe" -iv 8 -install -au 0
                            0002  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
                            0003  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.exe
                            0004  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.dll
                            0006  00000011 1
                            0007  00000012
                            =X====== M/11.2.202.228 2012-03-30+22-32-37.154 ========
                            =O====== M/11.2.202.233 2012-04-14+00-55-07.168 ========
                            0000  00000010 FlashPlayerInstaller.exe -install -iv 9
                            0002  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_233.ocx
                            0003  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_233_ActiveX.exe
                            0004  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_233_ActiveX.dll
                            0006  00000011 1
                            0007  00000012
                            =X====== M/11.2.202.233 2012-04-14+00-55-14.874 ========
                            =O====== M/11.2.202.235 2012-05-13+15-55-14.078 ========
                            0002  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_235.ocx
                            0003  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.exe
                            0004  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.dll
                            0006  00000011 1
                            0007  00000012
                            =X====== M/11.2.202.235 2012-05-13+15-55-33.001 ========
                            =O====== M/11.2.202.235 2012-06-02+17-15-03.605 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{38D0F30A-272B-4E7D-8E19-4351214F06E7}\InstallFlash Player.exe" -iv 6
                            0006  00000011 1
                            0007  00000012
                            =X====== M/11.2.202.235 2012-06-02+17-16-01.185 ========
                            =O====== M/11.3.300.257 2012-06-28+12-34-17.034 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{F3B881F7-4445-468B-977C-7912CE448A6D}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0002  00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
                            FlashUtil64_11_2_202_235_ActiveX.exe/ 2
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_257.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.dll
                            0006  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0007  00000012
                            =X====== M/11.3.300.257 2012-06-28+12-34-18.265 ========
                            =O====== M/11.3.300.257 2012-07-01+18-19-09.394 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{7B2F2D8B-722C-437C-A42E-82197129FA14}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0002  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0007  00000012
                            =X====== M/11.3.300.257 2012-07-01+18-19-10.551 ========
                            =O====== M/11.3.300.257 2012-07-01+18-20-42.990 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{514F27C7-0583-4957-BD7F-2119ABECE06D}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0007  00000012
                            =X====== M/11.3.300.257 2012-07-01+18-20-43.799 ========
                            =O====== M/11.3.300.257 2012-07-01+18-25-33.196 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{3376822C-E59A-48E0-AFD1-8299078DE4DE}\InstallFlash Player.exe" -uninstall activex
                            0001  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0002  00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                            0003  00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                            0004  00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                            0005  00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                            0006  00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                            0007  00001021
                            0008  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0009  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0012  00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
                            FlashPlayerApp.exe/ 2
                            0013  00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                            0014  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0015  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            =X====== M/11.3.300.257 2012-07-01+18-25-33.914 ========
                            =O====== M/11.3.300.257 2012-07-08+00-16-08.492 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{E2659F7E-C61B-4A44-B173-01613DAD2A1D}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 1
                            0003  00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0004  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_257.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.dll
                            0009  00000012
                            =X====== M/11.3.300.257 2012-07-08+00-16-09.522 ========
                            =O====== M/11.3.300.262 2012-07-08+00-17-24.758 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5C5B3A12-1411-4BE8-AD9C-A8909D3FCD72}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 1
                            0001  00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
                            0002  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0004  00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                            0005  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                            0006  00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
                            0007  00001036 Software\Opera Software/Last CommandLine 2
                            0008  00001036 Software\Opera Software/Last CommandLine 2
                            0009  00001036 Software\Opera Software/Plugin Path 2
                            0010  00001036 Software\Opera Software/Plugin Path 2
                            0011  00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_262.dll
                            0012  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_262_Plugin.exe
                            0013  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0014  00000012
                            =X====== M/11.3.300.262 2012-07-08+00-17-25.258 ========
                            =O====== M/11.5.502.146 2013-02-01+16-49-29.741 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{555F3A9A-915E-4315-AD03-1841AEA9AD51}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_146.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.dll
                            0006  00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                            0008  00000012
                            =X====== M/11.5.502.146 2013-02-01+16-49-31.558 ========
                            =O====== M/11.5.502.146 2013-02-01+16-58-55.641 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{D8FC21A7-620F-42C1-87AF-2EFD3B1FB997}\InstallFlash Player.exe" -install -skipARPEntry -iv 6 -au 4294967295
                            0008  00000012
                            =X====== M/11.5.502.146 2013-02-01+16-58-59.183 ========
                            =O====== M/11.5.502.146 2013-02-01+17-02-19.005 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{3C188F34-7617-48A8-A724-9EBB0BBF8009}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.5.502.146 2013-02-01+17-02-21.061 ========
                            =O====== M/11.5.502.146 2013-02-01+17-03-20.400 ========
                            0000  00000010 "C:\Windows\TEMP\{A93E772F-71AA-4E5A-AE87-029CF9F78EA8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0002  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                            0003  00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
                            0004  00001036 Software\Opera Software/Last CommandLine 2
                            0005  00001036 Software\Opera Software/Last CommandLine 2
                            0006  00001036 Software\Opera Software/Plugin Path 2
                            0007  00001036 Software\Opera Software/Plugin Path 2
                            0008  00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_5_502_146.dll
                            0009  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_Plugin.exe
                            0010  00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
                            0011  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0012  00000012
                            =X====== M/11.5.502.146 2013-02-01+17-03-24.288 ========
                            =O====== M/11.5.502.146 2013-02-07+07-50-40.861 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A7797A90-0336-4EB8-9968-02E7923DE4C0}\InstallFlash Player.exe" -uninstall plugin
                            0001  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                            0003  00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                            0006  00001021
                            0007  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0008  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0010  00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
                            0011  00001036 Software\Opera Software/Last CommandLine 2
                            0012  00001036 Software\Opera Software/Last CommandLine 2
                            0013  00001036 Software\Opera Software/Plugin Path 2
                            0014  00001036 Software\Opera Software/Plugin Path 2
                            =X====== M/11.5.502.146 2013-02-07+07-50-41.111 ========
                            =O====== M/11.5.502.146 2013-02-07+07-50-55.633 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A39272A3-6533-4C32-9A4B-1306A6668F0C}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.5.502.146 2013-02-07+07-50-55.727 ========
                            =O====== M/11.5.502.146 2013-02-07+15-49-33.535 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{AB030500-1613-48BB-BFCA-BEB15359EE5D}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_146.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.dll
                            0008  00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                            0010  00000012
                            =X====== M/11.5.502.146 2013-02-07+15-49-34.873 ========
                            =O====== M/11.5.502.149 2013-02-09+19-41-52.035 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{3242C4E4-8D14-4B51-86AF-ACB1CBD9D47C}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_149.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_149_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_149_ActiveX.dll
                            0008  00000012
                            =X====== M/11.5.502.149 2013-02-09+19-41-53.784 ========
                            =O====== M/11.5.502.149 2013-02-09+19-52-08.675 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{BD644D68-1FF7-40E7-A134-EB46BAF24550}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.5.502.149 2013-02-09+19-52-11.949 ========
                            =O====== M/11.5.502.149 2013-02-09+19-54-32.141 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{801B3856-B76C-48A3-B8BD-6285EDDF7290}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0011  00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_5_502_149.dll
                            0012  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_149_Plugin.exe
                            0013  00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
                            0014  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0015  00000012
                            =X====== M/11.5.502.149 2013-02-09+19-54-33.140 ========
                            =O====== M/11.5.502.149 2013-02-10+22-59-39.833 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{ED34ECD6-884F-4AF0-AEF0-B85C7B9D1D2B}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            0009  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            =X====== M/11.5.502.149 2013-02-10+22-59-40.566 ========
                            =O====== M/11.6.602.168 2013-02-14+17-15-53.389 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{40C8612D-CD27-4C14-8FF0-0EB5311BCF38}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_168.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.dll
                            0010  00000012
                            =X====== M/11.6.602.168 2013-02-14+17-15-54.759 ========
                            =O====== M/11.6.602.168 2013-02-14+22-25-46.006 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5BAF3D9D-9744-4478-9CA9-E4DB1D9EF193}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_168.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.dll
                            0008  00000012
                            =X====== M/11.6.602.168 2013-02-14+22-25-49.857 ========
                            =O====== M/11.6.602.168 2013-02-15+07-10-28.978 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{89ABFA42-B587-43F9-8FFF-846646812008}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.6.602.168 2013-02-15+07-10-31.490 ========
                            =O====== M/11.6.602.171 2013-02-27+00-54-26.639 ========
                            0000  00000010 "C:\Windows\TEMP\{E0780D22-7970-48EA-8139-679D1B422DAC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.dll
                            0008  00000012
                            =X====== M/11.6.602.171 2013-02-27+00-54-36.265 ========
                            =O====== M/11.6.602.171 2013-02-28+19-58-17.047 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{032BACAE-EB22-4639-96F8-A9241E7887DD}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.6.602.171 2013-02-28+19-58-17.437 ========
                            =O====== M/11.6.602.171 2013-02-28+20-03-54.365 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A8EB33F5-4775-42CF-8304-D3C2254A528D}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 1
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.dll
                            0010  00000012
                            =X====== M/11.6.602.171 2013-02-28+20-03-56.506 ========
                            =O====== M/11.6.602.171 2013-03-07+01-28-51.373 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{0F4FCE78-DBC8-463C-8F77-D056900ECAC6}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0008  00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_6_602_171.dll
                            0009  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_Plugin.exe
                            0012  00000012
                            =X====== M/11.6.602.171 2013-03-07+01-28-52.561 ========
                            =O====== M/11.6.602.171 2013-03-07+01-30-29.777 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{CE0D195E-DBA2-4CCE-9A4B-81EFE2E0C41A}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0012  00000012
                            =X====== M/11.6.602.171 2013-03-07+01-30-30.783 ========
                            =O====== M/11.6.602.180 2013-03-13+17-19-15.012 ========
                            0000  00000010 "C:\Windows\TEMP\{1984871F-95F5-491E-BB86-9A929AE8DD04}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx 5
                            0004  00000018
                            0005  00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx 5
                            0006  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.dll
                            0009  00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                            0010  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0011  00000012
                            =X====== M/11.6.602.180 2013-03-13+17-19-16.806 ========
                            =O====== M/11.6.602.180 2013-03-14+01-19-09.789 ========
                            0000  00000010 "C:\Windows\TEMP\{8F0CC6D3-3897-4A0C-BEEE-CB73D1338064}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0008  00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_6_602_180.dll
                            0009  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_Plugin.exe
                            0012  00000012
                            =X====== M/11.6.602.180 2013-03-14+01-19-11.068 ========
                            =O====== M/11.6.602.180 2013-03-29+17-36-52.210 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{57641B56-FA47-442F-9405-D05B0971D5CE}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.dll
                            0008  00000012
                            =X====== M/11.6.602.180 2013-03-29+17-36-53.565 ========
                            =O====== M/11.6.602.180 2013-04-03+23-45-09.408 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{E90DA7AD-4D95-48CA-B331-3BDE6A803006}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.6.602.180 2013-04-03+23-45-10.968 ========
                            =O====== M/11.7.700.169 2013-04-19+00-00-00.099 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A55CA306-27A9-470D-9BB9-319776BE995A}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx 5
                            0004  00000018
                            0005  00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx 5
                            0006  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
                            0011  00000012
                            =X====== M/11.7.700.169 2013-04-19+00-00-01.630 ========
                            =O====== M/11.7.700.169 2013-04-26+01-07-38.515 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{DB558C6D-C238-4B06-A41F-A3889DFAF6A2}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.7.700.169 2013-04-26+01-07-38.671 ========
                            =O====== M/11.6.602.180 2013-04-26+01-07-52.801 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{2F4BDB53-C3D6-49E3-A86A-AC6DBE1D74CC}\InstallFlash Player.exe" -uninstall plugin
                            0006  00001021
                            0007  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0010  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0011  00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
                            0012  00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                            0013  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0014  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0015  00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
                            0016  00001036 Software\Opera Software/Last CommandLine 2
                            0017  00001036 Software\Opera Software/Last CommandLine 2
                            0018  00001036 Software\Opera Software/Plugin Path 2
                            0019  00001036 Software\Opera Software/Plugin Path 2
                            =X====== M/11.6.602.180 2013-04-26+01-07-52.910 ========
                            =O====== M/11.7.700.169 2013-05-03+20-39-17.945 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{78BCC308-FA06-47BA-8DF1-CBE0B248E65C}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
                            0010  00000012
                            =X====== M/11.7.700.169 2013-05-03+20-39-20.227 ========
                            =O====== M/11.7.700.169 2013-05-03+20-43-50.080 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A861B639-8AFD-4440-8093-D003380F197E}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
                            0008  00000012
                            =X====== M/11.7.700.169 2013-05-03+20-43-51.629 ========
                            =O====== M/11.7.700.169 2013-05-03+21-41-54.772 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{875BB304-18B0-4F9D-A7F2-AD4116CA73E4}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.7.700.169 2013-05-03+21-41-54.834 ========
                            =O====== M/11.7.700.169 2013-05-03+21-47-05.019 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{462E6F8B-3372-4555-A1F4-AF84CD38C6B1}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0010  00000012
                            =X====== M/11.7.700.169 2013-05-03+21-47-06.518 ========
                            =O====== M/11.7.700.202 2013-05-15+15-09-05.703 ========
                            0000  00000010 "C:\Windows\TEMP\{AD0DC6EC-28C0-48F0-9A3A-BE16F0F5BDAA}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx 5
                            0004  00000018
                            0005  00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx 5
                            0006  00000013 C:\Windows\TEMP\{7EE2CAB0-CC94-405C-B5EB-A530E891BD47}\Flash64_11_7_700_202.ocx
                            0007  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
                            0008  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
                            0009  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.dll
                            0010  00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                            0012  00000012
                            =X====== M/11.7.700.202 2013-05-15+15-09-11.080 ========
                            =O====== M/11.7.700.202 2013-05-17+00-25-03.479 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{CFEA60CB-E103-471A-8A2F-2ACCA47FA3A4}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.7.700.202 2013-05-17+00-25-03.604 ========
                            =O====== M/11.7.700.202 2013-05-17+00-32-01.173 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{251760CD-0598-43AA-B34B-9600F2EBC683}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_202.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.dll
                            0010  00000012
                            =X====== M/11.7.700.202 2013-05-17+00-32-03.001 ========
                            =O====== M/11.7.700.202 2013-05-27+18-54-33.838 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{B8FF65BC-362A-4BA8-B0FB-303D8561FD9F}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_202.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.dll
                            0008  00000012
                            =X====== M/11.7.700.202 2013-05-27+18-54-35.301 ========
                            =O====== M/11.7.700.202 2013-05-27+19-10-02.539 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{359653CE-2AAE-4C20-8841-2923072C207B}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.7.700.202 2013-05-27+19-10-04.084 ========
                            =O====== M/11.7.700.202 2013-05-27+19-11-38.482 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{B923EADD-9E71-44FB-BD29-7705EA27C346}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.7.700.202 2013-05-27+19-11-38.560 ========
                            =O====== M/11.7.700.202 2013-05-27+19-19-58.880 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{221FFD41-A318-4589-A5F5-01D5C5D6DE27}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0010  00000012
                            =X====== M/11.7.700.202 2013-05-27+19-20-00.470 ========
                            =O====== M/11.7.700.202 2013-05-28+12-22-12.919 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{93AF455A-5B61-4AB4-A635-C98EA7D7E5A8}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.7.700.202 2013-05-28+12-22-13.029 ========
                            =O====== M/11.7.700.202 2013-05-28+12-34-26.110 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5B6C193F-A864-4B2F-A132-72461251A9DB}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 1
                            0010  00000012
                            =X====== M/11.7.700.202 2013-05-28+12-34-27.714 ========
                            =O====== M/11.7.700.224 2013-06-19+03-19-30.950 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{780A1B64-7843-405E-8EB4-C46C2632B4BE}\InstallFlash Player.exe" -install -skipARPEntry -iv 6 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_224.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_224_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_224_ActiveX.dll
                            0008  00000012
                            =X====== M/11.7.700.224 2013-06-19+03-19-32.307 ========
                            =O====== M/11.7.700.224 2013-06-27+18-29-29.800 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{8D283969-8B94-474B-B4B9-DFE2BAD6A2FD}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.7.700.224 2013-06-27+18-29-32.103 ========
                            =O====== M/11.8.800.94 2013-07-11+20-02-33.825 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{D6FA2887-AB71-47F1-B13F-CFB954281789}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_8_800_94.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.dll
                            0008  00000012
                            =X====== M/11.8.800.94 2013-07-11+20-02-35.422 ========
                            =O====== M/11.8.800.94 2013-08-09+05-54-16.359 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{4CE454A2-3B18-4806-9A4E-4E86A09EF14A}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.8.800.94 2013-08-09+05-54-18.634 ========
                            =O====== M/11.8.800.94 2013-08-22+22-31-26.594 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{7B0AB83C-6053-4A49-8D1F-23D24DD6D0ED}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/11.8.800.94 2013-08-22+22-31-31.752 ========
                            =O====== M/11.8.800.94 2013-09-08+06-00-36.504 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{0FAD4ADB-F82F-4F54-916A-BA7F060E1359}\InstallFlash Player.exe" -install -skipARPEntry -iv 6 -au 4294967295
                            0008  00000012
                            =X====== M/11.8.800.94 2013-09-08+06-00-39.530 ========
                            =O====== M/11.8.800.168 2013-09-11+14-09-04.089 ========
                            0000  00000010 "C:\Windows\TEMP\{7230A133-461B-413D-AA3A-81050E443231}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013 C:\Windows\TEMP\{80119277-16B9-46AE-B69A-6E45C62E28C7}\Flash64_11_8_800_168.ocx
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.dll
                            0007  00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                            0009  00000012
                            =X====== M/11.8.800.168 2013-09-11+14-09-09.034 ========
                            =O====== M/11.8.800.174 2013-09-14+03-09-04.992 ========
                            0000  00000010 "C:\Windows\TEMP\{3E732C46-DB27-42FC-B4CD-0ADA04E5F580}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013 C:\Windows\TEMP\{46DB2BCF-9294-4931-AF8D-64CA41D1E698}\Flash64_11_8_800_174.ocx
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.dll
                            0009  00000012
                            =X====== M/11.8.800.174 2013-09-14+03-09-09.531 ========
                            =O====== M/11.8.800.174 2013-09-19+13-33-47.136 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{1A1928CF-2C8F-487B-9D9E-7B821AE08E21}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.8.800.174 2013-09-19+13-33-47.261 ========
                            =O====== M/11.8.800.174 2013-09-19+14-40-16.516 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{949D11FB-4AE0-4875-AD37-6E6D3CD7C34A}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 1
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_8_800_174.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.dll
                            0010  00000012
                            =X====== M/11.8.800.174 2013-09-19+14-40-18.452 ========
                            =O====== M/11.8.800.174 2013-09-19+15-47-03.889 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5C67CDD1-63DE-45A5-8065-3529ACD15EDE}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/11.8.800.174 2013-09-19+15-47-04.809 ========
                            =O====== M/11.8.800.174 2013-09-19+15-54-41.091 ========
                            0000  00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe" -refreshIEElevationPolicies
                            =X====== M/11.8.800.174 2013-09-19+15-54-41.128 ========
                            =O====== M/11.8.800.174 2013-09-19+15-54-39.547 ========
                            0000  00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{A22C2AA1-F7A8-4110-97B2-5EDEF46EE12F}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 1
                            0010  00000012
                            =X====== M/11.8.800.174 2013-09-19+15-54-41.770 ========
                            =O====== M/11.9.900.117 2013-10-29+04-25-49.638 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{C7A64E9E-79DF-414E-BF71-4F6861E14B98}\InstallFlash Player.exe" -install -skipARPEntry -iv 6 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.dll
                            0008  00000012
                            =X====== M/11.9.900.117 2013-10-29+04-25-51.464 ========
                            =O====== M/11.9.900.152 2013-11-13+14-38-05.464 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{4104715C-7C04-4C16-87F1-BEB23699DA42}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_152.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_152_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_152_ActiveX.dll
                            0008  00000012
                            =X====== M/11.9.900.152 2013-11-13+14-38-07.416 ========
                            =O====== M/11.9.900.170 2013-12-13+18-28-08.403 ========
                            0000  00000010 "C:\Windows\TEMP\{3EB4EB8A-9880-466D-B5D1-647E871A32FD}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013 C:\Windows\TEMP\{35D18599-A383-44DA-8ACE-FAD0CCB806FF}\Flash64_11_9_900_170.ocx
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.dll
                            0009  00000012
                            =X====== M/11.9.900.170 2013-12-13+18-28-12.880 ========
                            =O====== M/11.9.900.170 2013-12-19+17-51-32.938 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{4FC0134D-57DC-42E5-9145-48B20C8364B0}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_170.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.dll
                            0008  00000012
                            =X====== M/11.9.900.170 2013-12-19+17-51-35.048 ========
                            =O====== M/12.0.0.44 2014-02-05+16-28-06.703 ========
                            0000  00000010 "C:\Windows\TEMP\{891A06DD-B58C-4959-8787-502CF4F2176C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/12.0 2
                            0004  00000013 C:\Windows\TEMP\{C1CACE43-0771-40CD-A876-B67E9263DD96}\Flash64_12_0_0_44.ocx
                            0005  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_44_ActiveX.exe
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_44_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_44_ActiveX.dll
                            0010  00000012
                            =X====== M/12.0.0.44 2014-02-05+16-28-10.384 ========
                            =O====== M/12.0.0.70 2014-02-21+17-28-24.083 ========
                            0000  00000010 "C:\Windows\TEMP\{557550D4-26F3-40DC-8926-482F5D066FEB}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0004  00000013 C:\Windows\TEMP\{4ACDF1B6-4957-4FE6-AD1C-5007BE7B03E5}\Flash64_12_0_0_70.ocx
                            0005  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.exe
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.dll
                            0010  00000012
                            =X====== M/12.0.0.70 2014-02-21+17-28-29.652 ========
                            =O====== M/12.0.0.77 2014-03-12+20-28-03.471 ========
                            0000  00000010 "C:\Windows\TEMP\{44EFEC97-CC95-47F9-AA97-40F1E3320800}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013 C:\Windows\TEMP\{1A14465B-289E-4FE6-ADED-DDE0ED576A8C}\Flash64_12_0_0_77.ocx
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_77_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_77_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_77_ActiveX.dll
                            0009  00000012
                            =X====== M/12.0.0.77 2014-03-12+20-28-07.792 ========
                            =O====== M/13.0.0.206 2014-04-29+03-28-05.604 ========
                            0000  00000010 "C:\Windows\TEMP\{E406C5CE-37CE-46F1-BFDB-B63453FDE80F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/13.0 2
                            0004  00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_206.ocx
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.dll
                            0009  00000012
                            =X====== M/13.0.0.206 2014-04-29+03-28-09.047 ========
                            =O====== M/13.0.0.206 2014-05-04+07-05-06.420 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{36E3B719-F4B3-4E17-A5DC-3820989F5F02}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_206.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.dll
                            0008  00000012
                            =X====== M/13.0.0.206 2014-05-04+07-05-08.925 ========
                            =O====== M/13.0.0.206 2014-05-12+16-20-07.626 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{D7479207-5625-4C35-8208-14FD271374B7}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/13.0.0.206 2014-05-12+16-20-10.469 ========
                            =O====== M/13.0.0.206 2014-05-12+17-19-33.415 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{87F37EAF-60A3-4E29-BA79-BE9C0034A1C9}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 4294967295
                            0008  00000012
                            =X====== M/13.0.0.206 2014-05-12+17-19-35.631 ========
                            =O====== M/13.0.0.214 2014-05-14+15-28-07.897 ========
                            0000  00000010 "C:\Windows\TEMP\{5DC33B8F-7037-4070-9262-E64A204A7958}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_214.ocx
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.dll
                            0008  00000012
                            =X====== M/13.0.0.214 2014-05-14+15-28-12.314 ========
                            =O====== M/13.0.0.214 2014-05-28+21-49-16.233 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{DDF957D2-A6E0-427C-973E-4F8414107693}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            =X====== M/13.0.0.214 2014-05-28+21-49-16.373 ========
                            =O====== M/13.0.0.214 2014-05-28+21-57-18.869 ========
                            0000  00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.exe" -refreshIEElevationPolicies
                            =X====== M/13.0.0.214 2014-05-28+21-57-18.993 ========
                            =O====== M/13.0.0.214 2014-05-28+21-57-17.100 ========
                            0000  00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{6195CE86-21C7-4A5D-8995-1529AC935D4B}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0005  00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_214.ocx
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.dll
                            0010  00000012
                            =X====== M/13.0.0.214 2014-05-28+21-57-19.813 ========
                            =O====== M/14.0.0.145 2014-07-09+16-04-08.626 ========
                            0000  00000010 "C:\Windows\TEMP\{39DBFB32-3454-4654-997C-E2ED1928BAC9}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/14.0 2
                            0004  00000013
                            0005  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_ActiveX.exe
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_ActiveX.dll
                            0010  00000012
                            =X====== M/14.0.0.145 2014-07-09+16-04-13.212 ========
                            =O====== M/14.0.0.145 2014-08-29+06-04-07.428 ========
                            0000  00000010 "C:\Windows\TEMP\{15263746-9117-4EF9-A7AE-E87BCD6FEF48}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0011  00000014
                            0012  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_Plugin.exe
                            0015  00000012
                            =X====== M/14.0.0.145 2014-08-29+06-04-12.728 ========
                            =O====== M/15.0.0.152 2014-09-10+16-04-10.970 ========
                            0000  00000010 "C:\Windows\TEMP\{71ACFEE5-7C4E-4615-8846-383A23C2C9EC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/15.0 2
                            0004  00000013
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_152_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_152_ActiveX.dll
                            0009  00000012
                            =X====== M/15.0.0.152 2014-09-10+16-04-16.102 ========
                            =O====== M/15.0.0.152 2014-09-10+17-04-09.537 ========
                            0000  00000010 "C:\Windows\TEMP\{77A229CE-48AF-462D-9105-33005646E5DC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0008  00000014
                            0009  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_152_Plugin.exe
                            0012  00000012
                            =X====== M/15.0.0.152 2014-09-10+17-04-14.108 ========
                            =O====== M/15.0.0.167 2014-09-23+21-04-03.336 ========
                            0000  00000010 "C:\Windows\TEMP\{8310B800-1BA8-4DEF-81E8-1C6FA43380A7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_167_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_167_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_167_ActiveX.dll
                            0009  00000012
                            =X====== M/15.0.0.167 2014-09-23+21-04-08.437 ========
                            =O====== M/15.0.0.223 2014-11-13+23-04-16.688 ========
                            0000  00000010 "C:\Windows\TEMP\{DB86BC2A-F188-4BE1-9E1A-12A932575364}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_223_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_223_ActiveX.dll
                            0008  00000012
                            =X====== M/15.0.0.223 2014-11-13+23-04-21.010 ========
                            =O====== M/15.0.0.223 2014-11-14+00-04-12.588 ========
                            0000  00000010 "C:\Windows\TEMP\{529876E9-65BB-4C27-A1C9-DD718DC75398}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0008  00000014
                            0009  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_223_Plugin.exe
                            0012  00000012
                            =X====== M/15.0.0.223 2014-11-14+00-04-17.627 ========
                            =O====== M/15.0.0.239 2014-11-26+18-04-11.023 ========
                            0000  00000010 "C:\Windows\TEMP\{B3CD85FB-59D1-446A-A036-41D5124CF33D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_ActiveX.dll
                            0009  00000012
                            =X====== M/15.0.0.239 2014-11-26+18-04-16.427 ========
                            =O====== M/15.0.0.239 2014-11-27+01-04-07.819 ========
                            0000  00000010 "C:\Windows\TEMP\{22C5CB84-82CE-4323-B285-EA782AAAAD11}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0008  00000014
                            0009  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_Plugin.exe
                            0010  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_Plugin.exe
                            0011  00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
                            0012  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0013  00000012
                            =X====== M/15.0.0.239 2014-11-27+01-04-11.969 ========
                            =O====== M/15.0.0.246 2014-12-10+16-04-03.459 ========
                            0000  00000010 "C:\Windows\TEMP\{38BAB7DB-A4D5-4103-B8EE-EC809CE94905}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_ActiveX.dll
                            0009  00000012
                            =X====== M/15.0.0.246 2014-12-10+16-04-07.484 ========
                            =O====== M/15.0.0.246 2014-12-10+22-04-08.208 ========
                            0000  00000010 "C:\Windows\TEMP\{D241776F-A2DE-41F7-A2CF-4E49013B0976}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0008  00000014
                            0009  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_Plugin.exe
                            0010  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_Plugin.exe
                            0013  00000012
                            =X====== M/15.0.0.246 2014-12-10+22-04-09.909 ========
                            =O====== M/16.0.0.257 2015-01-13+20-04-03.951 ========
                            0000  00000010 "C:\Windows\TEMP\{A2A7D882-B856-4DDA-813E-18C1B8C4463D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/16.0 2
                            0004  00000013
                            0005  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_ActiveX.exe
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_ActiveX.dll
                            0010  00000012
                            =X====== M/16.0.0.257 2015-01-13+20-04-08.491 ========
                            =O====== M/16.0.0.257 2015-01-13+21-04-04.877 ========
                            0000  00000010 "C:\Windows\TEMP\{8C0DDDAC-9F6D-4030-8F9B-65E80EF079B7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0002  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
                            0003  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                            0004  00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
                            0006  00001036 Software\Opera Software/Last CommandLine 2
                            0008  00001036 Software\Opera Software/Plugin Path 2
                            0009  00000014
                            0010  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_Plugin.exe
                            0011  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_Plugin.exe
                            0012  00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
                            0014  00000012
                            =X====== M/16.0.0.257 2015-01-13+21-04-07.947 ========
                            =O====== M/16.0.0.287 2015-01-23+13-04-05.869 ========
                            0000  00000010 "C:\Windows\TEMP\{EA0D0964-1CC2-492F-8A7F-D566D2F78634}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_ActiveX.dll
                            0009  00000012
                            =X====== M/16.0.0.287 2015-01-23+13-04-12.842 ========
                            =O====== M/16.0.0.287 2015-01-23+14-04-05.688 ========
                            0000  00000010 "C:\Windows\TEMP\{2E961659-0942-4FE5-BB2B-7E6D128CEEB0}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0009  00000014
                            0010  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_Plugin.exe
                            0011  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_Plugin.exe
                            0014  00000012
                            =X====== M/16.0.0.287 2015-01-23+14-04-08.208 ========
                            =O====== M/16.0.0.296 2015-01-24+23-04-06.477 ========
                            0000  00000010 "C:\Windows\TEMP\{8F40CC6C-F162-41EB-B2E4-E07D6B564303}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_ActiveX.dll
                            0009  00000012
                            =X====== M/16.0.0.296 2015-01-24+23-04-12.826 ========
                            =O====== M/16.0.0.296 2015-01-25+00-04-05.294 ========
                            0000  00000010 "C:\Windows\TEMP\{CCC6767C-9C58-4E13-86E4-28A9916DB0B7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0009  00000014
                            0010  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_Plugin.exe
                            0011  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_Plugin.exe
                            0014  00000012
                            =X====== M/16.0.0.296 2015-01-25+00-04-07.712 ========
                            =O====== M/16.0.0.305 2015-02-06+00-04-04.637 ========
                            0000  00000010 "C:\Windows\TEMP\{CF9C563E-EEAD-4B58-B5C5-5A2113179ECE}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.dll
                            0009  00000012
                            =X====== M/16.0.0.305 2015-02-06+00-04-08.407 ========
                            =O====== M/16.0.0.305 2015-02-06+01-04-06.634 ========
                            0000  00000010 "C:\Windows\TEMP\{77C34F8E-B726-4677-A8FD-A7AB06475A82}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0009  00000014
                            0010  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_Plugin.exe
                            0011  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_Plugin.exe
                            0014  00000012
                            =X====== M/16.0.0.305 2015-02-06+01-04-08.414 ========
                            =O====== M/17.0.0.169 2015-04-14+18-04-49.141 ========
                            0000  00000010 "C:\Windows\TEMP\{83C36E48-DA45-4FD7-BEF4-BDC01EFE8073}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/17.0 2
                            0004  00000013
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_169_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_169_ActiveX.dll
                            0009  00000012
                            =X====== M/17.0.0.169 2015-04-14+18-04-57.931 ========
                            =O====== M/17.0.0.169 2015-04-14+19-04-07.271 ========
                            0000  00000010 "C:\Windows\TEMP\{8B7526EF-300E-4773-8575-164F5C88FFBD}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0009  00000014
                            0010  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_169_Plugin.exe
                            0013  00000012
                            =X====== M/17.0.0.169 2015-04-14+19-04-09.091 ========
                            =O====== M/17.0.0.188 2015-06-09+22-04-08.261 ========
                            0000  00000010 "C:\Windows\TEMP\{51E1D723-A288-4AA6-B1A0-DFFDB8A8564E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_188_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_188_ActiveX.dll
                            0008  00000012
                            =X====== M/17.0.0.188 2015-06-09+22-04-12.111 ========
                            =O====== M/17.0.0.188 2015-06-10+13-05-18.350 ========
                            0000  00000010 "C:\Windows\TEMP\{69B0FE01-440B-4158-9758-E7F0E45C4D96}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0009  00000014
                            0010  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_188_Plugin.exe
                            0013  00000012
                            =X====== M/17.0.0.188 2015-06-10+13-05-27.742 ========
                            =O====== M/17.0.0.190 2015-06-24+15-04-05.886 ========
                            0000  00000010 "C:\Windows\TEMP\{90E0BE4D-2285-4D36-A6B4-22865AB3461F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_190_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_190_ActiveX.dll
                            0008  00000012
                            =X====== M/17.0.0.190 2015-06-24+15-04-09.480 ========
                            =O====== M/17.0.0.190 2015-06-24+16-04-13.341 ========
                            0000  00000010 "C:\Windows\TEMP\{654DFFC2-985D-453A-B462-3F00DBAFBA3D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0009  00000014
                            0010  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_190_Plugin.exe
                            0013  00000012
                            =X====== M/17.0.0.190 2015-06-24+16-04-15.705 ========
                            =O====== M/17.0.0.190 2015-07-08+19-04-05.338 ========
                            0000  00000010 "C:\Windows\TEMP\{D385830E-49C6-4AC7-989F-63DE3F53E06F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013
                            0008  00000012
                            =X====== M/17.0.0.190 2015-07-08+19-04-08.888 ========
                            =O====== M/17.0.0.191 2015-07-08+20-04-11.869 ========
                            0000  00000010 "C:\Windows\TEMP\{CC5AB32E-2D1D-48BB-8442-C03A9E20E4F8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_191_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_191_ActiveX.dll
                            0008  00000012
                            =X====== M/17.0.0.191 2015-07-08+20-04-20.249 ========
                            =O====== M/17.0.0.191 2015-07-08+21-04-15.637 ========
                            0000  00000010 "C:\Windows\TEMP\{BE3A59B8-09D1-47D6-8641-4214DA9B2680}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0009  00000014
                            0010  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_191_Plugin.exe
                            0013  00000012
                            =X====== M/17.0.0.191 2015-07-08+21-04-17.807 ========
                            =O====== M/18.0.0.209 2015-07-14+21-04-06.024 ========
                            0000  00000010 "C:\Windows\TEMP\{F97DA19A-C42F-4BAF-AED4-E92D3C71CDBF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            0002  00001036 Software\Macromedia\FlashPlayer\SafeVersions/18.0 2
                            0005  00000013
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.dll
                            0010  00000012
                            =X====== M/18.0.0.209 2015-07-14+21-04-11.110 ========
                            =O====== M/18.0.0.209 2015-07-14+22-04-12.567 ========
                            0000  00000010 "C:\Windows\TEMP\{D23D8E56-3834-4DC5-B464-503C5ECFBA54}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
                            0004  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                            0005  00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
                            0010  00000014
                            0011  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_Plugin.exe
                            0014  00000012
                            =X====== M/18.0.0.209 2015-07-14+22-04-18.760 ========
                            =O====== M/18.0.0.209 2015-07-19+14-40-30.643 ========
                            0000  00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{B487AB8C-3CA3-4026-93DF-3DD46B2AEF00}\InstallFlash Player.exe" -uninstall plugin
                            0001  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
                            0003  00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                            0004  00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                            0005  00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                            0006  00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                            0007  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                            0008  00001021
                            0010  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            0012  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            0013  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0014  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            =X====== M/18.0.0.209 2015-07-19+14-40-30.767 ========
                            =O====== M/18.0.0.209 2015-07-19+14-40-41.734 ========
                            0000  00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{D9E1EE62-F196-4F3C-8688-EC373675CE44}\InstallFlash Player.exe" -uninstall activex
                            0007  00001021
                            0011  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0012  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0013  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            0014  00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
                            0015  00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                            0016  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0017  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0018  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            =X====== M/18.0.0.209 2015-07-19+14-40-41.859 ========
                            =O====== M/18.0.0.209 2015-07-23+18-33-08.257 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A5C027A3-7CA2-4510-A6E9-49CA99129A32}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0001  00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0003  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            0004  00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0005  00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0006  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0007  00000013
                            0008  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.exe
                            0009  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.dll
                            0012  00000012
                            =X====== M/18.0.0.209 2015-07-23+18-33-09.988 ========
                            =O====== M/18.0.0.232 2015-08-12+03-30-05.659 ========
                            0000  00000010 "C:\Windows\TEMP\{5D723855-4915-4403-9B1B-74E0B016BDC7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0002  00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                            0005  00000013
                            0006  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_232_ActiveX.exe
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_232_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_232_ActiveX.dll
                            0011  00000012
                            =X====== M/18.0.0.232 2015-08-12+03-30-07.916 ========
                            =O====== M/19.0.0.185 2015-09-21+21-30-04.740 ========
                            0000  00000010 "C:\Windows\TEMP\{7D883052-7624-43A4-A0FA-B53E3F658446}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00001036 Software\Macromedia\FlashPlayer\SafeVersions/19.0 2
                            0006  00000013
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_185_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_185_ActiveX.dll
                            0011  00000012
                            =X====== M/19.0.0.185 2015-09-21+21-30-07.002 ========
                            =O====== M/19.0.0.207 2015-10-15+15-30-03.370 ========
                            0000  00000010 "C:\Windows\TEMP\{819AB98A-6468-40D6-B738-14CEC6EC3235}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0005  00000013
                            0006  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_207_ActiveX.exe
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_207_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_207_ActiveX.dll
                            0011  00000012
                            =X====== M/19.0.0.207 2015-10-15+15-30-05.507 ========
                            =O====== M/19.0.0.226 2015-10-16+20-30-02.863 ========
                            0000  00000010 "C:\Windows\TEMP\{A3695225-1861-4DCA-A9E5-9ADAA3E2B228}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0005  00000013
                            0006  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_226_ActiveX.exe
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_226_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_226_ActiveX.dll
                            0011  00000012
                            =X====== M/19.0.0.226 2015-10-16+20-30-04.626 ========
                            =O====== M/19.0.0.245 2015-11-11+19-30-04.668 ========
                            0000  00000010 "C:\Windows\TEMP\{EAF5BECB-3F0C-4B03-993F-7C54DD2BB7ED}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0005  00000013
                            0006  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_245_ActiveX.exe
                            0007  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_245_ActiveX.exe
                            0008  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_245_ActiveX.dll
                            0011  00000012
                            =X====== M/19.0.0.245 2015-11-11+19-30-07.070 ========
                            =O====== M/20.0.0.228 2015-12-09+04-30-03.388 ========
                            0000  00000010 "C:\Windows\TEMP\{559EAE24-E10C-4626-A9BE-A2DA0323CDAF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/20.0 2
                            0004  00000013
                            0005  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_228_ActiveX.exe
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_228_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_228_ActiveX.dll
                            0009  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0010  00000012
                            =X====== M/20.0.0.228 2015-12-09+04-30-05.556 ========
                            =O====== M/20.0.0.267 2015-12-29+17-30-12.017 ========
                            0000  00000010 "C:\Windows\TEMP\{E041F681-975C-4DE4-BAD4-ABB4955D4E62}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0001  00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_267_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_267_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_267_ActiveX.dll
                            0008  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0009  00000012
                            =X====== M/20.0.0.267 2015-12-29+17-30-14.127 ========
                            =O====== M/20.0.0.270 2016-01-02+11-30-15.841 ========
                            0000  00000010 "C:\Windows\TEMP\{300B52AB-2684-44C8-8434-D362F07B7C35}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
                            0003  00000013
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_270_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_270_ActiveX.dll
                            0008  00000012
                            =X====== M/20.0.0.270 2016-01-02+11-30-19.148 ========
                            =O====== M/20.0.0.286 2016-01-19+22-30-04.965 ========
                            0000  00000010 "C:\Windows\TEMP\{6BDF4F82-5559-45FA-96FA-B54903AA3537}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_286_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_286_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_286_ActiveX.dll
                            0009  00000012
                            =X====== M/20.0.0.286 2016-01-19+22-30-09.003 ========
                            =O====== M/20.0.0.306 2016-02-10+15-30-10.217 ========
                            0000  00000010 "C:\Windows\TEMP\{0050D7A2-3FEE-4036-9080-12F77E37D143}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_306_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_306_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_306_ActiveX.dll
                            0009  00000012
                            =X====== M/20.0.0.306 2016-02-10+15-30-13.097 ========
                            =O====== M/21.0.0.182 2016-03-10+18-30-24.327 ========
                            0000  00000010 "C:\Windows\TEMP\{EE68BD9D-ACA1-4A65-83B2-E5A869973EE8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0001  00001036 Software\Macromedia\FlashPlayer\SafeVersions/21.0 2
                            0002  00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0003  00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0004  00000013
                            0005  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_182_ActiveX.exe
                            0006  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_182_ActiveX.exe
                            0007  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_182_ActiveX.dll
                            0010  00000012
                            =X====== M/21.0.0.182 2016-03-10+18-31-54.354 ========
                            =O====== M/21.0.0.197 2016-03-24+16-30-02.452 ========
                            0000  00000010 "C:\Windows\TEMP\{A3A36CF7-B1DC-42EC-BA76-164EC0095892}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
                            0003  00000013
                            0004  00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
                            0005  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
                            0006  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.dll
                            0009  00000012
                            =X====== M/21.0.0.197 2016-03-24+16-30-03.950 ========
                            =O====== M/21.0.0.197 2016-03-29+22-49-32.048 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{48BDBA3A-469C-4762-85E7-4CE89995B0C2}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0003  00000013
                            0004  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
                            0005  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.dll
                            0007  00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                            0008  00000012
                            =X====== M/21.0.0.197 2016-03-29+22-49-37.461 ========
                            =O====== M/21.0.0.197 2016-03-30+00-39-32.936 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{208A64A9-3C26-4353-836E-1DF8726DC3C4}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0003  00001015 C:\Windows\system32\Macromed\Flash\Flash64_21_0_0_197.ocx 5
                            0004  00000018
                            0005  00001015 C:\Windows\system32\Macromed\Flash\Flash64_21_0_0_197.ocx 5
                            0006  00000013
                            0007  00001024 C:\Windows\system32\Macromed\Flash\Flash64_21_0_0_197.ocx 183
                            0008  00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
                            0009  00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.dll
                            0012  00000012
                            =X====== M/21.0.0.197 2016-03-30+00-39-35.135 ========
                            =O====== M/21.0.0.197 2016-03-30+14-20-07.235 ========
                            0000  00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{ADDED4C9-1E56-4728-A015-44BBD39192E9}\InstallFlash Player.exe" -install -skipARPEntry -iv 8 -au 0
                            0003  00000013
                            0008  00000012
                            =X====== M/21.0.0.197 2016-03-30+14-20-09.918 ========
                            • 12. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                              maria__ Adobe Employee
                              I'm not seeing any obvious errors in the log file.  I would recommend performing a clean install.  See How do I do a clean install of Flash Player - Windows? for instructions.
                              Maria
                              • 13. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                                taga-hugis Level 1
                                maria,
                                I have followed & did the clean install, after doing the uninstall.
                                but when I went into the work schedule website,
                                it is showing me again:
                                    NEED ADOBE FLASH PLAYER. should I still send the logfile for sysWOW64 when dell helps me fix & view it? or are the sys32 file same as the sysWOW 64 file?
                                • 15. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                                  Sorry, I missed the your comment "...but then I still get a "access denied" message when trying to view the log file in sysWOW64, I contacted dell for this."
                                  and missed that this file was from the system32 location.  The file in the sysWOW64 location will have more information than this file.  If you can get into that location to get the file it'd be great.
                                  On a 64-bit OS, Flash Player installs to C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash.  If you can't access this directory it's possible Flash Player can't either, but if that was the case I would expect Flash Player installation to fail due to Access Denied error.  Please try the following:
                                  1. Click the Windows Start Orb button
                                  2. In the search field type: Windows Explorer
                                  3. Find Windows Explorer in the search results
                                  4. Right-click and select Run as Administrator
                                  5. A User Access Control dialog window will display:
                                    • If your user account is an Administrator, click Yes to launch Windows Explorer with Administrator permissions
                                    • If your user account is not an Administrator you'll need to provide the UserID and password for an Administrator account to launch Windows Explorer with Administrator permissions.
                                  After Windows Explorer launches as Administrator try to navigate to the C:\Windows\SysWOW64\Macromed\Flash directory.  If you can, post the contents of the FlashInstall.log file.
                                  Thank you.
                                  Maria
                                  • 16. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                                    taga-hugis Level 1
                                    hello maria, what does "ORB"  mean in start orbthanks.
                                    • 17. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                                      The Start button, as show in the screenshot.  The steps in the screenshot correspond with the steps in the instructions.
                                      Maria
                                      • 18. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                                        taga-hugis Level 1
                                        yes, still getting the access denied message for syswow64, even after following your
                                        steps clearly. I had referred the problem to dell and the technician pro-support likewise
                                        tried it and they were getting the same "access denied" message after trying to access
                                        the logfile of syswow64.
                                        any other solutions?
                                        thanks for your patience, ms. maria
                                        martin
                                        • 19. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                                          I wasn't sure if the suggestion would work, and unfortunately, it didn't.
                                          Since this is a Windows file system issue it's beyond the scope of assistance we can provide on the Adobe forums.  I recommend contacting Microsoft support at support.microsoft.com or seeking assistance at the Microsoft community forums at answers.microsoft.com for assistance.  This Microsoft tech note may also be of assistance https://support.microsoft.com/en-us/mats/windows_file_and_folder_diag.
                                          Once you resolve the issue with the Windows file system it'll most likely resolve the issues you're having with Flash Player.
                                          Maria
                                          • 20. Re: installing AFP 21 everytime I turn-on my PC from being powered off.
                                            Carm01 Level 4
                                            You could try and Fix Permissions for what its worth, and i did not see that you attempted to do a check desk for errors as mentioned earlier?
                                            How do I fix Windows permission problems with Flash Player?
                                            Best Regards
