• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Same Site, different URLs, different execution times
Explorer ,
Feb 17, 2009 Feb 17, 2009
We have two URLs, http://www.ontrenduniforms.com and http://www.thechefzone.com that go to the same folder on the server. Other than the name and header records, the two IIS entries are identical as are the DNS entries. Since they share the same code, everything else is identical: cfm pages, application.cfm included, and database.
Near the top of the page is a timing quantity. Click on "Chef Coats" in the left menu and ontrenduniforms takes 20 times as long to load as thechefzone. The second time both pages are almost instantaneous. Ontrenduniforms will show a time that matches the first timing for thechefzone while the chefzone goes to zero. The third time, ontrenduniforms also goes to zero time.
Close the browser and do it again and the same thing happens all over again. It also doesn't matter which order they are loaded in.
We've placed the two domains in IIS in separate application pools and they are now each running in a different CF instance. That didn't help. There is nothing in the code that references the url. In fact, the images are referencing a third domain that is elsewhere. Hardly matters, since the difference in timing is during the server side execution.
What would/is causing this to happen. Are there any known issues?
TOPICS
Advanced techniques
Views
845
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
To clarify, the first time the feature is requested from either url
takes a long time to run, then all future requests are quick?
If that is so, then it is expected behavior if the code has been
optimized to use already generated results. So the first time the data
is requested it takes some time to put together. Once that has been
done, the same data is being returned over and over from both links as
it does not need to be generated again.
How or why this could be happening would depend greatly how your coded
is constructed and whether it is taking advantage of any intentional or
unintentional caching.
Votes
Translate
Translate
Report
Report
Explorer ,
Nope. Close the browser and begin again with either first. Ontrenduniformst always takes about 20 times as long the first time as thechefzone. I could see each of them taking longer the first time and being quick the second time.
But why would one be 20 times as long the first time as the other is the first time-- consistently? Both URLs in IIS point to the same folder and same document in that folder.
Starging from scratch, ontrenduniforms takes 20+ times as long the first time as thechefzone. This is true if one starts with thechefzone. It is true if one starts first with ontrenduniforms.
Votes
Translate
Translate
Report
Report
LEGEND ,
Then you are just going to have to turn on debugging and|or put
debugging tests into your code and see what, if any, path and processing
differences their might be between the two runs.
Votes
Translate
Translate
Report
Report
Explorer ,
Yeah, you are right. Been doing that, too, but it is a real pain, because of granularity. There are a lot of modules being called inside loops, so trying to tiime those things is difficult.
I was just hoping against hope that it was some known issue. This is one *WEIRD* problem. We have other stores with almost identical organization and no difference-- all using the same code base, so something is different.
My guess is that it is something totally obvious in our code and someone will feel like an idiot when we find it. One of those "Duh!" moments we all get to experience from time to time! It is just hard to imagine how either ColdFusion OR our code would even know there was a difference!
But, if anyone out there does know of something CF might be doing that could cause this kind of funnyness, ...
Votes
Translate
Translate
Report
Report
Advocate ,
Since it only happens the first time that page is requested per browser session, you can limit your searching down to anything that's session-specific.
Are you caching anything in the SESSION object? Are you writing anything to it that is then used in subsequent requests? Is the query that pulls up this data being cached somewhere? Any difference in the SESSION setups on these 2 sites?
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
That's what is weird. The only difference is that we have two IIS domains both pointing to the exact same folder with the exact same default document. They are both executing the SAME code, not just identical code. Thus any session setup would be the same. When reference needs to be made to URL information, it is always grabbed using CGI entries, such as CGI.HTTP_HOST. This must be the case since 99% of the code lives in component libraries used by all 130+ stores we host. The other 1% is the templates that generate the unique look and feel. This is a much much smaller universe of code that has been reviewed and makes no references to the URL.
Votes
Translate
Translate
Report
Report
Resources
Documentation
