6 Replies Latest reply on Apr 1, 2016 1:53 AM by tpk1982
    Object layer option for selective links
    tpk1982 Level 4
      I need to turn off 'shadow' layer for only selective images. I found this script from forum. But it will turn off to all graphics, not selected. I don't seem any error in his coding.
      Any one please help me to sort this problem.
      var myGraphics = myDoc.links;
      for (var i = myGraphics.length-1; i >= 0; i--){
          var myArt = myGraphics[i];
          var myStry = myArt.parent;
          app.select(myStry);
          var mySel = app.selection[0];
          try{
              var myGraphs  = mySel.parent.graphics[0].graphicLayerOptions.graphicLayers;
              for (a=myGraphs.length-1; a>=0; a--){
                  if(myGraphs[a].name =='Shadow'){//here you can as the layer name you want switch off the visibility.
                      myGraphs[a].currentVisibility=false;
                   if(myGraphs[a].name =='shadow'){//here you can as the layer name you want switch off the visibility.
              }catch(e){}
              app.selection = null;
      Regards,
      Karthi
        • 1. Re: Object layer option for selective links
          tpk1982 Level 4
          This is the method i tried:
          var input = ['Shadow','shadow']/*Names of Layers to switch on or off*/
              var onOrOff = false /*true = visible, false = not visible*/;
              var log="" ;
              var csv;
              var flagVisible = [];
              var fname = [];
              var fpath = [];
              main();
              function main(){
                  var currDocGraphics = app.activeDocument.allGraphics;
                  l = currDocGraphics.length;
                  var docname=app.activeDocument.name;
                  while(l--){
                      currImage = currDocGraphics[l];
                      if(currImage.imageTypeName == 'Photoshop'){
                          i = input.length;
                          while(i--){
                              try{
                                  var mylinkfile=currImage.itemLink.name;
                                  if( currImage.graphicLayerOptions.graphicLayers.itemByName(input[i]).currentVisibility==true){
                                      currImage.graphicLayerOptions.graphicLayers.itemByName(input[i]).currentVisibility = onOrOff;
                                      flagVisible.push(mylinkfile);
                                  } catch (e){ }
                  if(flagVisible.length>0){
                      alert("\nShadow layer is TURNED OFF for the following files:\n\n"+flagVisible.join("\n"));
                  else
                      alert("\nNo Shadow layer TURNED OFF")
          • 2. Re: Object layer option for selective links
            Ronald63 Level 4
            Replace line 20 to 24 by
            var myLayer =currImage.itemLayer;
            if( myLayer.name==input[i] && myLayer.visible){
                myLayer.visible = onOrOff;
            • 3. Re: Object layer option for selective links
              tpk1982 Level 4
              Hi Ronald,
              Your coding is turn off the layer palette of Indesign. But the question is regarding the name available in object layer option.
              Karthi
              • 4. Re: Object layer option for selective links
                Ronald63 Level 4
                Hi Karthi,
                Sorry for my confusion ;-). What exactly is your problem?
                • 5. Re: Object layer option for selective links
                  tpk1982 Level 4
                  Hi Ronald,
                  I need to check the name of 'Shadow' layer enabled or not in Object Layer Options. The coding what i gave is working fine and it will check and reset for all document images. But my requirement is, i need to check and do changes in only the selected images. I may select 2 or 3 images out of 20 /30 from the document.
                  Hope it is clear.
                  Regards,
                  Karthi
                  • 6. Re: Object layer option for selective links
                    tpk1982 Level 4
                    Hi Ronald,
                    I found the result myself.
                    function Main() {
                        var mySelection = app.selection;
                        for(var n=0;n<mySelection.length;n++){
                            if(mySelection[n].graphics.length === 1 && mySelection[n].graphics[0].imageTypeName === "Photoshop"){
                                alert(mySelection[n].images[0].graphicLayerOptions.graphicLayers.itemByName("Shadow").currentVisibility+"  --->"+mySelection[n].graphics[0].itemLink.name);
                    Main()
                    Thanks for your interest in this thread.
                    Regards,
                    Karthi
